Question about Aiptek A-HD 720P Flash Media Camcorder
File failed message
I just bought this camcorder from Amazon. "File failed" appears within seconds when trying to record. Then the camera acts like it has locked up. The mode button is not functional after I try to record. I have to take the battery out so the camera will reset. Any ideas about what may be causing this?
  • ryburnc Aug 12, 2008
    I found that I had a bad memory card, although it was new. I changed the card and the camera works great.
  • shawnw116 Jan 10, 2009
    "File Failed" message after approximantly 40-60secs of recording. This ONLY happens when I am recording onto a memory card. It has not happened when I was recording to internal memory. I suspect it is a bad memory card. Brand:Dane-Elec
Posted on Aug 12, 2008
I found that I had a bad, although brand new, memory card. I changed the card and the camera works perfectly.
  • 3 Answers
The same thing happens to me when I try to record thru the "A/V in jack". It appears (my first thought) that the camera is trying to record to the internal drive and it runs out of memory really quick. But then, when I play it back, (the small 15 seconds or so) the audio and video are not sync'd. Most of the time at least. Very inconsistent. It also locked up and froze for me too. I had to remove the battery to reset it. Once or twice it recorded normal, (once when I reset the default settings and another time just out of the blue) - I thought I had it solved but it went back to "File Failed" after about 17-20 seconds of recording on the next record session.
I have the thing packed up ready to take back, but am looking for a solution so I can keep it..
Posted on Jul 29, 2008
Sony HDR XR550 has developed a problem
Taken from page 22 usa manual
Notes
If you close the LCD screen while recording movies, the camcorder stops recording.
The maximum continuous recordable time of movies is about 13 hours.
When a movie file exceeds 2 GB, the next movie file is created automatically.
It will take several seconds until you can start recording after you turn on the camcorder. You cannot
operate your camcorder during this time.
Jun 23, 2014 | Light & Motion BlueFin Pro Series...
MOVIE FILE NOT RUN
Your camcorder can only play back movies recorded on that specific device, due to the way the software within the camcorder works.
PS - please don't shout when you post queries
Jul 16, 2017 | Panasonic Cameras
Error code 2881
Found error in image file, Error Occurred, error 0901, 572, 2881
The camera says found error in image file, repair data now. When you press yes it says "Error occurred. Please replace disc." or use ac adapter/charger, turn off power. It won't let you go to Disc Navigation to finalize it. While recording video on DVD-R media the battery power may have failed and camera shut off. When turned on the message shown on the lcd is Found error in image file, Error Occurred, error 0901.
Regards.
Jan 12, 2011 | Hitachi DZ-MV580E DVD Camcorder
Cant playback video files
after i got full hard desk on my sony HD (HDR-XR520) any vide i record i cant copy it and it doesn't appear on my computer and then the files on the camera when i play them they don't ply and i found a message said: No applicable files available, so please how can solve this problem? or it's an industrial bad side with this camera??
Apr 28, 2010 | Sony Handycam HDR-XR520 High Definition...
Operation problems with Panasonic HDC-SD5 camcorder
it's not very clear if it is a software malfunction or hardware,so i recommend to you to visit local service center.In my opinion this is hardware problem in rear operation unit .
Jul 27, 2009 | Panasonic HDC-SD5 Flash Media Camcorder
Importing Excel file into Act 2006 Version8
My advice is not specific to Sage, but exoprting Excel data.
Check there are no missing/ blank cells within the range, anything that is blank change it to 0.
Make sure the format of your range matches the character length allowed in Sage - Especially for text - if necessary check the no of characters using =LEN(B2) - Assuming B2 contains the text you are checking, where necessary trim the no of characters.
Change your format to CSV if possible, sometimes easier to import.
If you do the above and receive an error message or can narrow down the issue it will give me a better idea of why the import is failing.
Mar 23, 2009 | Sage ACT! 2006 Full Version for PC
Cannot copy files Parameter Incorrect
most likely the issue is that your trying to copy files over 4gb to fat32 disks, and this causes the parameter incorrect -issue. Try formatting the drive your copying to ntfs, this can handle +4gb files.
Nov 11, 2008 | JVC Everio GZ-MG360 HDD Camcorder
Aiptek camera
hmm.. this is a hard one. Well, you may have the SD car on Lock, but if that's not the problem, you either used up the memory, or need to upgrade the firmware Sorry I can't answer in great detail. I'll try to find some more information ASAP. Sincerely: (youtube user) animation508
Sep 16, 2008 | Aiptek A-HD 720P Flash Media Camcorder
Broken video management file/ recording failure
Although the instructions don’t make it clear, it seems to be important that the camera is turned off before you connect or disconnect the USB cable. The instructions do mention that you should not delete or rename files on the camera except in the EXT_MOV folder. The camera’s firmware is apparently quite fragile about file names and the presence of the extra hidden folders that both the Windows and Macintosh operating systems create when you delete something.
Apr 07, 2008 | JVC Everio GZ-MG37 Camcorder
Lost time/inaccessible files on flip
This may sound risky, but I did this and my Camera is working perfectly again... If you don't have any videos on it you need to salvage too badly this should do the trick.
1) Plug it in (obviously)
2) Go to My Computer and right click your video camera
3) Click Format
4) I clicked restore device defaults because it sounded safe (but may not be necessary)
5) Click start and begin the reformatting
After this i went from my incorrect 27:11 min. remaining on the camera to the full 60. Still records perfectly and the software is still on it and works correctly. Hope it helps some of you out there =)
Mar 09, 2008 | Pure Digital Flip Video Ultra Camcorder
Aiptek A-HD 720P Flash Media Camcorder Logo
Top Aiptek Video Cameras Experts
tomikles
Level 1 Expert
prouddad_1
Are you an Aiptek Video Camera Expert? Answer questions, earn points and help others
