Question about Garmin GPSMAP 235 Sounder GPS Receiver
Garmen 240 fishfinder
Display showed a depth of 17,000 ft and then the graph disappeared. Speed, battery, and temp still displayed. In a test bucket of 1ft it reads 1.6+.
Unit or transducer problem?
  • chucklehead1 Jul 27, 2008
    Boat was not moving in ~30 ft when it read 17000 prior to the graph going blank.
    No clicking sound can be heard.
    Thanks for the info on test bucket depth.
    Just fyi the unit now reads 8ft in the bucket, seems to be climbing since I truned it on a few hours ago.
  • 113 Answers
A test bucket wont work, A 200 khz transducer will generally not work in anything less than 2' of water, due to surface clutter. If the transducer is working, you should hear it make a ticking sound.
When you got the 17000 foot reading was your range set to auto?
How is the transducer situated on the boat? Sometimes turbulence and bubbles from the hull can cause erroneous readings, including unrealistic depths, or no depth at all. Stop the boat and turn off the engin e and anything electrical to see if problem repeats itself. If it only crops up when the boat is moving then it is most likely the transducer location.
Posted on Jul 26, 2008
  • Paul Hyde
    Paul Hyde Aug 19, 2008
    For some reason I didn't get notified that you responded.
    No clicking sound in the transducer means it is not getting power from the sounder. This could be due to a damaged transducer cable, a loose plug, or an internal problem in the display. Go down to your local marine supply and ask to buy a transducer for test purposes. plug it into the transducer socket on the 240 and listen for the ticking sound. If it's not ticking the problem is in your 240 and it needs to be sent out for service. Most big retailers will let you return a transducder if it hasn't been installed.
How do i find water depth
Water depth should show automatically on your sonar page.
if it does not then either you have selected "stop sonar" under your sonar options or you have opted to turn off the depth displayou so the numbers don't show up.
if you areally viewing your GPS or split screen sonar/GPS page, sometimes the depth display is not visible on these pages unless you specifically instruct the unit to display it.
Lowrance HDS 5 Gen2 Fishfinder GPS Chartplotter
Here is a link to Lowrance where you can download a pic version of the operators manual.
Go to page 11 "overlay data" this will give you a step by step of how to add data or readouts to different screens.
Aug 27, 2014 | Lowrance HDS 5 Fishfinder GPS Chart...
Garmin 300c fishfinder will go from correct depth to 0.0 ft while traveling.Have to turn it off and restart. It is on Hurricane deck boat 198. It is located between engine and leveling tabs.
My experience as a user is that turbulence around the transducer can cause mine to flash and the depth to remain static.Is your fault affected by speed? Sounds to me that you have a faulty connection causing the transducer to "not register". I'd check connections and also the integrity of the transducer. Hope that helps...
Best of luck
May 28, 2014 | Garmin FISHFINDER 300C NIC ()
Just purchased and Eagle Fishmark 320 used. Will not display depth reading - just shows 0'0"? I have reset to factory settings. We have had in lake,same thing. Right now in 5 gallon bucket of...
Hello! Do you have the PDF users guide for your unit? I'm looking at a copy in the troubleshooting section...I don't want to cover information you have already looked at or tried...Since I do not know if you have that manual I'll give you a few items to check...
Measure the battery at the units power connector...Must be at least 11 volts DC...In portable mode it uses 8 D cell batteries= 12 volts
Make certain the Transducer is securely connected...
Did you use the in-line fuse supplied with the unit?...
Try the Manual Depth Range...First turn off Auto Depth Range...From the sonar Page Hit MENU...Down-arrow to Auto Depth Range...Hit ENT...Hit Up-Arrow to Depth Range...Hit ENT..
And the Depth Scale Range appears...Up-Arrow or Down-Arrow to select a different depth range...Hit Exit...The minimum depth the unit can read is 5 feet...
If you do not have the PDF guide, here is the link...
Let me know how you make out....Guru....Saailer
Sep 11, 2011 | Eagle Fishmark 320 Portable Fishfinder
When we are deep water (500 ft or deeper) the fish finder will display 3.5-10 ft. and won't show the fish or shows tons of fish. Are we able to set the depth that we would like to see eg: if we are...
Im not familiar with your particular unit but you should be using a low frequency transducer for water over 500'; something like a 50 kHz transducer or a dual frequency transducer like a 50/200kHz for detail with the high freq. but increased depth range on the lower frequency. As far as setting it to 250 ft, you should be able to use the range feature and adjust the maximum to 250'. typically the factory default is automatic so it will caonstantly adjust the range based on the maximum current depth.
May 22, 2011 | Standard Horizon Standard Ff520 Fish...
My fish finder isn't showing depth or temperature anymore. I was fishing one day and my temp started blinking and went away, then my depth began blinking and went away. Soon after this my screen wasn't...
Yes... or it is unplugged... or the wire is broken...
Typically you hear a clicking sound at the transducer when it is powered and running but in your case all function is missing from the display and temp and depth is off of the transducer..
Sep 04, 2017 | Humminbird Fishfinder 550
Eagle Fisheasy No screen display and only beeps
You could have blown the is supposed to be in water before you turn it on. A 5 gal. bucket inside the boat would be fine for when out the water. Put the transducer in the 5gal bucket with water and try again. You may have to get another. sorry.
Dec 20, 2009 | Eagle Fisheasy 250ds Fishfinder
My fishfinder will not continue to read shallow depths as well as in shallow depths when drifting and occasionally running across the water. My unit is a lowrance 522c color gps/fishfinder.
Hello. Your observation is spot on and it is actually a characteristic that is always true when using sonar. Yes, your Lowrance uses the same sonar as a nuclear powered submarine does. The two factors you focus on, water depth and boat speed are perhaps, the two biggest factors when it comes to the quality of the fishfinder. The boat's engine should be in gear at an idle or just above. Experiment with your boat to find the best throttle location for good arches. Usually, a slow trolling speed works best. The depth of the fish can determine if the fish will arch on the screen. If the fish is in shallow water, the fish is not in the cone angle very long, making it difficult to show an arch. Typically, the deeper the fish, the easier it is to show an arch.
If you would like a complete tutorial on Lowrance sonar, go to this link. Enjoy.
Nov 20, 2009 | Sport & Outdoor - Others
Furuno 4100 depth sounder shows depth twice what it really is
check your gain setting try auto gain and try manually gaining back to see if it resolves, if yes, send unit in to furuno, if no, ducer is probably at fault.
Aug 01, 2009 | Furuno Ls4100 5" Mono Lcd Fishfinder Temp...
No depth reading while on plane.
Depending on your transducer type, you may have a liquid filled type that simply needs refilling. If this is the case check for leaks and get it redone. If not it could be transducer placement or cavitation under the hull.
Jun 18, 2008 | Raymarine A65 Combo GPS...
Garmin GPSMAP 235 Sounder GPS Receiver Logo
295 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
