Question about Gateway MT6705 Notebook
BLACK SCREEN NO BOOT ON HARD DRIVE OR O.S.
I HAD MY MT6705 CHANGED FROM VISTA TO XP.AFTER FEW MONTHS IT STARTING TO SHOW BLUE SCREEN AND THEN ONE DAY ITS ALL BLACK AFTER THE LOGO SCREEN.I TRIED TO BOOT UP ON OS NOTHING WORKS,EVEN THE HARD DRIVE NO BOOT AT ALL.I WAS IN MY COUNTRY (PHILIPPINES) FOR VACATION,WHEN IT ALL HAPPENED.I ALSO HAVED IT CHECK WITH THE TECHNICIAN THEY TRIED ALL THE TESTS LIKE CHANGING HD,CD ROM,ETC. PLEASEEE HELPPPP IM LOSING MY MIND!!!! LOL
  • m4rty08 Jan 02, 2009
    I KNEW THAT BUT EVEN THOUGH I USE IT BACK HERE IN U.S. WITH JUST THE
    BATTERY ONLY IT WORKS BUT IT STILL WONT BOOT UP!!! ITS STILL
    BLACK..WHEN I HAD IT CHECKED OUT IN THE PHILIPPINES THEY TRIED EVERY
    TEST...BUT I HAVENT TRY MYSELF BECAUSE THE FACT IS I DONT WANT TO WASTE
    MONEY BUYING PARTS WHEN I DONT REALLY KNOW WHATS THE MAIN
    PROBLEM....I'VE BEEN A COMPUTER FREAK FOR 5 YEARS BUT I HAVENT
    ENCOUNTER THINGS LIKE THIS!!! IT'S A PAIN IN THE YOU KNOW WHAT!!!
  • m4rty08 Jan 03, 2009
    well guess what even that wont work at all...its really complicated with all these problems...nothng boots up with this crazy laptop!!! thanks for your helpanways and concern...
    Novelist:
  • 176 Answers
US has 110volt power outlet while other countries like Philippines have different power outlet outlet voltage of 220v. You cant use the same power adaptor that you use in the US but if you use a power regulator like a UPS device it wont have a problem
Posted on Jan 02, 2009
  • Ed Deguzman
    Ed Deguzman Jan 02, 2009
    Will it even POST or not ? If it does the POST then its the OS that you need to reinstall.
Drive connected to HP Desktop running Vista Pro after one week and several re-starts PC would not boot on start-up showed scary blue screen with with drive connected without black screen then blue....
> after one week
Western Digital warranties the disk-drive to work for at least one year.
If it does not, then exercise the warranty to get a replacement, at minimal cost to you.
Try connecting it to a different PC, to see if your PC's "blue-screens" happen without it being attached.
Nov 18, 2010 | Western Digital My Book Elite...
Blue screen
Check booting in other computer, this will show if CD faulty. If not, CD drive may be faulty. If CD not faulty & can boot from USB drive you can copy CD to USB drive and install that way.
Apr 19, 2010 | Acer Aspire M5641 PC Desktop
I bought lenovo G550 last week. It came with Windows Vista. I want to install Windows XP on it. I have found that lenovo has driver for windows XP so that will make my life easy :-) But when I try to...
you are most likely getting a BSOD with a stop error code of 0x0000007B which is caused by the Windows XP CD that you are using doesn't have the SATA Hard Drive controller driver needed to recognize and utilize the hard drive. If Lenovo has XP drivers for this model then they should have a SATA driver (roughly 394k) that will need to be loaded FROM A FLOPPY DISKETTE during the boot to XP. (XP Requires the driver to either be slipstreamed into the CD or loaded from a floppy diskette. Trying to load the controller driver USB or a different CD will not work)
http://www.digitgeek.com/how-to-slipstream-sata-drivers-into-xp-cd/
Jan 11, 2010 | Computers & Internet
Can't get computer to turn on (compaq presario 5000)
Either your Hard drive (hd) crashed or your hd cable or port is faulty. if your software is corrupt boot with a boot disk (assume you are using XP or Vista), press R on the blue options screen. you will be given a black dos prompt screen. Type in fixboot and type Y for an answer.
Oct 26, 2009 | Compaq Presario 5000 PC Desktop
Model:MT6705 won't boot says operating sys not found How do I fix this?
You may have lost your connection to your hard drive.
Try to remove and reseat your hard drive.
If the unit has been dropped or taken a good hit, you may have to replace the drive.
Oct 22, 2009 | Gateway MT6705 Notebook
When my gateway MT6705 tries to boot, blue screen
Many times this error occurs when I have swapped a hard drive and used the wrong IDE cable to connect it. If your computer uses an Ultra Direct Memory Access (UDMA) hard disk controller, and you use a standard 40-wire connector cable to connect the UDMA drive, you may experience this error. Make sure you are using the correct IDE cable.
Also, if your BIOS settings are configured to force the faster UDMA modes, this error may occur. In this situation, restart your computer and enter the BIOS and load the "fail-safe" default settings and reboot.
If neither of these issues are the cause for the Unmountable Boot Volume, then the issue most likely is caused by a damaged BOOT.INI file in the root directory of the boot drive or file system corruption.
Follow the steps below to correct these file system issues:
1) Start your computer with your Windows XP CD-ROM, or with Windows XP boot disks
2) When the Welcome to Setup screen appears, press R to Repair the installation using the Recovery Console
3) If you have a dual-boot or multiple-boot computer, select the Windows installation you want to access
4) Type the administrator password when you are prompted, if no administrator password is set then just press Enter
5) At the command prompt, type CHKDSK /R and then press Enter
6) Once CHKDSK has finished checking and repairing the hard drive, type EXIT and press Enter to restart your computer
Oct 18, 2009 | Gateway MT6705 Notebook
Windows XP Blue Screen
change your ide cable or sata.
Reset your bios settings pull cmos cell from motherbord for minute so all settings are defaults.
Also boot your computer with winxp disk then if you able to enter in setup then go to recovery console mode and run "chkdsk /r' command .
Also check your harddisk is master set jumper in master position .
Aug 18, 2009 | Computers & Internet
Black screen w/blinking cursor
So.. you can select safe mode? Or you turn it on and it is resuming into the blank screen?
If the latter. Unplug the power, pull the battery out for 20 seconds or so. Then put it all back together and try booting up.
Apr 19, 2009 | Toshiba Satellite A100-S8111TD Notebook
Formatting problem
Does the new drive have XP on it already?
If not just boot from the XP disc and you should be able to do it from there.
Feb 12, 2009 | Gateway MT6705 Notebook
Laptop restarting
Although it could be the hard drive, it could be any number of things as well. First, when the computer starts up, press the F8 key to bring up some options. Select disable automatic restart. This should allow the computer to stop at a blue screen so we can get some information from it. Do this and report back what that information says and we'll go from there. Thanks.
Jun 14, 2008 | Toshiba Satellite P35-S609: Pentium 4-3.2...
Gateway MT6705 Notebook Logo
188 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
