Question about Soleus Heating & Cooling
Soleus PE1-09R-30 Leaking water from the bottom front ot the ac
4 Suggested Answers
SOURCE: leaking water from ptc ac unit in front .vents all open
make sure unit is has slight fall toward outside.
Posted on Jun 15, 2009
SOURCE: Soleus LX-140 leaking problem
We have a 1-year PE3-09R-03 that just started dripping water on the floor. The red "tank full" light never came on. I opened it up to investigate, and I believe the problems are caused by dust. The plastic float that trips the "tank full" switch appears to have gotten stuck due to the combination of water and dust in the tray. Once I loosened it up and cleaned the guide tube it rides in, it would trip the switch when the tank was full. The reason the tank was filling up was a little less obvious. There is a 2-piece plastic tray that sits underneath the evaporator and above the condenser. The tray is supposed to distribute the water that's dripping from the cold evaporator coils onto the warm condenser coils so it can evaporate and be blown out with the warm exhaust air (note that "evaporator" and "condenser" are referring to the refrigerant - the terms appear backwards when referring to what's happening to the water on the outside). The tray and its lid have a series of tiny holes that were - guess what - plugged by dust. The tray is relatively easy to remove, just two screws and a spring clamp on the overflow hose. The tray lid is heat-staked onto the tray, you should be able to clean it without separating the lid. I cleaned and reinstalled the tray and verified that water would flow properly. I then reassembled the unit and fired it up, and it's been running without a puddle for over a day in humid weather.
The unit has a filter for the recirculating room air, but there is no filter for the outside air loop. Adding a filter would obviously help keep the dust out, but it could also reduce the cooling efficiency of the unit.
DO NOT use one of these on a floor you care about without some sort of emergency catch tray underneath!
Posted on Aug 17, 2009
  • 266 Answers
SOURCE: Model: KFR-32GW/Ac Will not stop leaking
Possible one of two problems. first make sure the unit is tilted away from the inside slightly. Second there are very small drains that let water flow from the front coil to the rear of the ac if the unit has been dirty it can plug these holes. You can find the holes by pulling the ac out or just remove it and use a hose to clean it. You can buy coil cleaner at a hardware store just follow the directions.
Posted on Aug 08, 2010
  • 387 Answers
SOURCE: Friedrich Model SQ06J10 AC 'in wall'
I think 2 things will correct this problem. 1. be certain that the unit is tilted to theoutside about 1 inch or so. 2. be certain that the filter is clean.. Let me know if it does not solve it . have a great day
Posted on Jul 23, 2011
My portable ac says to add water, how do i do that
There are 2 issues.
The first is that there is a water container in which you must fill water so the compressor cools. This is housed usually in the side. There is an automatic push panel on the side of the unit which when pushed opens the door. The container sits inside which needs to be taken out and filled daily.
The other is the water that condenses because of cooling the air. This settleas at the bottom of the ac. Bend down abd you will see a drain plug and a rubber blocker. Unscrew the drain plug and pull the rubber. All the condensed water will flow out. It can be messay so preferably drain in the bathroom.
Nov 15, 2011 | Soleus KY-34 Portable Air Conditioner
Our unit is leaking water all out the front and bottom all of a sudden (it's been in use for almost 3 years).
The drain is plugged . you will have to pull the front cover of the unit to clean it. take some hot water to the drain pan after you get it cleared. and get as much stuff out of it as possible. the you should be in good shape again I would recommmend tht you do this yearly at the start of the cooling season hope this helps Let me know Jon
Aug 04, 2011 | Soleus KFIHP09 Air Conditioner
Friedrich room air conditioner Model SQ06J10: leaking water from front bottom right corner
make certain that it is tilted ot the outside about 1 inch or so .. service filter while your at it as well
Jul 23, 2011 | Heating & Cooling
My unit is only 2 months old and its making a squeeling grinding bearing kind of noise in front of the the unit and its on the bottom where youu can feel the grinding on the outer casing. What could it be?
I had the same issue with my Soleus PAC unit making a squealing, grinding noise.
I took the unit apart to locate the issue and found out that the water pump on the lower right side was the issue.
I removed the water pump and used warm water and a little bit of dish washing soap along with a qtip to clean the water way.
Squealing stopped.
Not sure if this is the same issue with your unit - but it can be a starting point.
Just be sure to unplug the unit while working on it. Also be careful not to puncture the coolant lines.
Good luck.
Jul 22, 2011 | Soleus PH3-10R-03 10000 BTU Portable Air...
Have a Soleus LX-140 portable air conditioner. Water was leaking out the right side of the machine. Opened the casing and found a clear hose, one end attached to the plastic tray above the condenser and...
I have an LX-100, and had the same problem, so I am guessing that the designs are similar. There should be a pump in the condensate pan at the bottom of the unit -- on mine, it was near the front, right next to the overflow float switch. There should be an outlet on top of the pump, which is where the hose needs to be attached.
It looks like the pump pushes condensate up into that plastic tray, which lets if flow over the heat exchanger, both cooling it and evaporating the water. With the hose detached, you're probably noticing degraded cooling performance and a lot more condensate in the holding tank than there should be. At least, that was the case for me. Good luck.
Jul 05, 2011 | Soleus LX-140 Portable Air Conditioner
Model: KFR-32GW/Ac Will not stop leaking water from the front of the unit. Coils have no ice. Shut off unit for 30 min the leaking stops but resumes when AC is turned back on.
Aug 08, 2010 | Heating & Cooling
Portable AC leaking
depending on where you live. do have high humidity. then you have excess amount of water that might make condensate. like very cold can of can of coke.
Jul 11, 2009 | Soleus PH310R03DB Portable Air Conditioner
My Unit is running but is saying it is full
yes you do need to drain the water that has built up. there is a little hose with a plug in it located at the bottom rear under the exhaust hose. but be sure to drain it somewhere so that you don't ruin your floor. the water of course builds up from the ac's condensor. It doesn't take all that long to get full either.
Jul 06, 2008 | Soleus KY-34 Portable Air Conditioner
Jun 09, 2008 | Soleus KY-34 Portable Air Conditioner
Heating & Cooling Logo
165 people viewed this question
Top Soleus Heating & Cooling Experts
Chris Hall
Chris Hall
Harjeet Singh
Gil Shultz
Are you a Soleus Heating and Cooling Expert? Answer questions, earn points and help others
