Question about Archos 104 MP3 Player
Read hard disk error keeps coming up, computer does not recognise the [player
Acer laptop 5290 won't boot up.. keeps saying "disk read error occurred" cannot get anywhere but to that screen saying that.
Posted on Dec 20, 2008
My acre aspire 5517 keeps getting a disk read error occurred and I keeps repeating it over and over what do I do?
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Apr 17, 2013 | Acer Aspire Computers & Internet
I'm getting a screen that says "A disk read error
this problem caused by error connection at hard disk, your hard disk can not read by your computer
to fix this problem you need to open your laptop then disconnect your hard disk from laptop, and connect again
and turn on your laptop
the problem like this usually found at computer with sata hard disk connection
i hope this helpful
Apr 04, 2011 | Acer Computers & Internet
WD HD Media player damaged my hard drive??
Hi Dear! This problem could be solved through a software. You should use Western Digital Disk Manager, your WD hard disk will work properly after using that your WD hard disk pass all test of the software. When it will pass all test it will work properly and in other condition if it will not pass then you should try again so that the software will fix the error and it will made workable.
Thank You
Jul 24, 2009 | Western Digital My Book Premium ES...
"disk error" occurs when disk is inserted
the drive cannot read data from the disk, follow these instutions:
if you are using vista, right click on "computer" then select "manage" then select "device manager". look down the list until you find CD/DVD and click on the + icon next to it, then right click on the CD/DVD and select un-install (make sure that there is a disk in the drive, preferably a movie or music CD) then restart the computer, when the computer restarts vista will detect the drive and install the drivers again, look in computer to see if the disk has been recognised
let us know how you get on
and please remember to rate us
regards
Nov 28, 2008 | Televison & Video
SD Card Error
I had a similar problem and after a bit of tooling around, I was able to get this to work for me. There are a couple of steps. Basically the problem is that the memory card wasn't properly disconnected from the player at some point so it's reading filesystem errors on it as a result. (Kinda like pulling out a USB key from a computer before you've "safely removed hardware". While your computer will tolerate this, your zen will not.) Here's how to safely remove disconnect your SD card after copying files to it.
1. First, if possible, reformat your SD card. This is not critical, but is a good practice so that you can sart from scratch with a totally fresh card.
2. Next, plug in your SD card to your player and turn it on. Navigate to the memory card menu, and place the memory card in "removable disk".
3. Plug the Zen into your computer, and go to "my computer". There should be a new disk called "removable disk" which is now shown along the rest of your hard drives. (Kinda like when you plug in a USB key drive. You're essentially doing the same thing here.)
4. Copy your files to the "removable disk".
5. VERY IMPORTANT: When you are done, right-click on the removable disk and choose "eject" fromt the menu that comes up. When a popup appears saying that your hardware is safe to remove, you can unplug the zen from the computer.
6. Now navigate to your memory card using your zen player, and choose "browse". It should come up now without any error.
Jul 08, 2008 | Creative Labs Zen Digital Media Player
Problem reading disk
my burner on my xps 400 computer does not recognise a blank disk so it keeps asking to put in a blank when there is one there it does seem to recognise factory cd s any suggestions?
Apr 28, 2008 | Dell Dimension XPS 400 PC Desktop
Go gear not working
Install and run Device Manager from the product CD.
Select the repair option, and follow the on-screen prompts.
NOTE: ALL FILES LOADED ON TO THE PLAYER WILL BE LOST.
If this doesn't work then it may be that the hard disk is faulty. There is an easy way to find out. The following procedure allows the player to connect to the PC as a removable drive. If the Pc reads the drive, then the drive is ok.
Connect the HDD1630 to the mains adaptor and the PC.
Before the computer has a chance to recognise the player, press "Power" and "Vol +" to reset the player.
As soon as the player resets (screen goes blank) press and hold "Vol -" until the PC recognises the player as a removable drive.
Try to access the player through "My Computer" as you would the main hard disk.
Feb 07, 2008 | Philips HDD1630 MP3 Player
NEED HELP RIGHT AWAY
You should reformat your disk so that the error goes away, in the menu please find the format the disk, or connect the stuff to the computer then format it using the computer. (all files will be deleted during formatting)
If this not work you can replace the disk of your stuff.
may this help! regards, melnavz
Feb 06, 2008 | SanDisk Sansa e250 MP3 Player
Yellow triangle
CLICKING HARD DISK is usually a sign of a problem with the hard disk. If this is the case it will have to be replaced.
The HDD16X0 series use a standard 6Gb Microdrive which are readily available, and much cheaper than the official Philips replacement. The new drive would need to be "Repaired" using the Philips Device Manager.
Nov 18, 2007 | Philips HDD1630 MP3 Player
It won't come on properly. Somethings very wrong. Please help!
Check the hard disk as follows:
Connect the HDD to the mains adaptor and the PC.
Jan 21, 2007 | Philips GoGear HDD6330 MP3 Player
Archos 104 MP3 Player Logo
262 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
