Question about Cameras
Digi view v1501 how do i set up the frame?
I am unable to transfer from my memory card to the digi view frame as each time i select the suitcase icon and enter a message stating error appears. can anyonre supply a complete luddite with fool proof instructions?thankyou
Adig
  • 104 Answers
SOURCE: Memory Card Error after Airport Security
In suitcase? Checked baggage? Bad idea. Here's why. I damaged an LCD display that way. Not cracked or broken, but the baggage area is not a heated or insulated space. The temperature can reach well below -40 F (or C). Most electronics is not rated for such and my LCD on the device I put in my checked luggage shows the effect. Lesson learned firsthand....
Posted on Sep 15, 2005
mads_aye
  • 58 Answers
SOURCE: cannot transfer my internal memory photos into my sd memory card
if you insert the card and it would read the card immediately - not allowing you to see the pictures on the internal, that means the image storage is set to AUTO, you have to set it back to internal so you can copy them to card and just put it back to AUTO to reactivate the card
please follow this path:
insert card> turn on cam to auto> press review> "reading memory card" > press menu> scroll down to image storage> press ok to select> select INTERNAL MEMORY> press ok
scroll down to COPY> Copy pictures to memory card> scroll down to all> press ok
message to expect: "copying"
when it goes to back the menu screen
scroll to IMAGE STORAGE again and select AUTO> ok> "reading memory card"
you're supposed to see the copy of pictures from your internal and pics from your card if there's any
you can visit www.kodak.com/go/manuals
Posted on Feb 13, 2008
  • 6 Answers
SOURCE: Unable to operate remote of Pandigital picture frame
remove the memory card and see if the remote works wit hthe built in memory pics. if it doesnt pic up your card you will just have to try another card. The frames dont read cards larger than 1 Gb very well either - reguardless of how many pics are on the card.
Posted on Dec 11, 2008
  • 3 Answers
SOURCE: Not all jpeg images will load on 7'' Pandigital Photo Frame
I was having a problem too with my Smartparts frame. All the pics were from the same camera but some of the vertical (portrait) orientation shots wouldn't show right. Just a bunch of thin colored lines. After some phone calls I did try to "resize" the photos to the "resolution" of my frame (had to look that up too). My frame is 640 width by 480 high. So I took a shot and changed all the goofy photos to 480 width (since they were vertical) and let Photoshop change the the other number. Low and behold the buggers are showing up fine now. Well on to my next problem - focusing with the new D90. I think that one is going to be more challenging yet. Hope this helps you out.
Posted on Dec 30, 2008
Dipu007
  • 2110 Answers
SOURCE: transfer from computer to memory card
http://wwwuk.kodak.com/global/en/service/downloads/dln_ekn029310.jhtml?pq-path=3906/2308/2316
you haveto install driver from above link..and then try to transfer photos from camera to pc...
after that from pc you can transfer to photo frame...
Posted on Jan 07, 2009
Just want to know how to transfer photos from a NOKIA Lumia 521 to the 8" Aluratek Digital Photo Frame
Try sending the photos to a cloud service on the web, then transfer to a memory card that could be inserted into the Photo Frame. If the phone has a memory card you can get an adapter to upload to a PC then back to a memory card for the Photo Frame.
May 14, 2014 | Photography
How do i download pictures to tablet
Pandigital photo frames are an ideal way to display your collection of digital photos. You can view photos with or without a computer using just a memory card, but it's always a good idea to transfer the photos you'll want to view frequently to the internal memory of your frame. This is also a handy way to back up your favorite images.
  1. Transferring Photos from a Memory Card
    • Your digital photo frame's built-in software will recognize six types of memory card: CF I/II, SD, MS Pro, MMC and XD. Locate the slot on the back of the frame (to the left of the stand) that corresponds with your type of memory card. These are labeled as follows: SD/MMC/MSPro/XD, CF I/II, USB and mini USB. Insert your memory card into the appropriate slot, power on your digital frame, and it will automatically begin a slideshow using every available image on your memory card. Note that only JPEG formats under 16 megapixels are compatible.
    Transferring Photos from a PC
    • Use the USB cable that came with your frame. Connect the mini USB end to the mini USB port on the back of your frame; connect the large USB end to your computer's USB port. Double-click the "My Computer" icon on your desktop or in your Windows "Start" menu. You'll see that your computer has automatically assigned a drive to your digital frame---look for a device called "Removable Disk" followed by a letter (Removable Disk E:, for example). This is the folder that represents the internal memory of your digital photo frame; you will be dragging your photos into this folder.
      Next, open the folder in which you store your photos ("My Pictures," for example). Select the photos you want to transfer to your frame. Drag them to the drive associated with your digital photo frame---this is the "Removable Disk" drive you located within the "My Computer" folder. Every photo you selected will then be copied onto your digital frame.
      After the files are copied, disconnect your digital frame properly. If you don't, your frame's internal memory could be damaged. Look for the system tray in your desktop's lower right-hand corner. Left-click the icon that shows a gray box with a green arrow on top of it. Select "Safely Disconnect Hardware." A dialog box will appear, asking you to select the device to disconnect. Select the digital frame and click "OK." When the dialog box appears, click "Close." You'll see a message in the lower right hand portion of your desktop telling you it's safe to disconnect your frame.
    Copying Photos to Your Frame's Internal Memory
    • You can use your frame's remote control to copy photos from your memory card or computer to the photo frame's internal memory. Connect your photo source (computer or memory card) and have your frame's remote control handy. Access the "Home" screen on your frame using the "Home" button on your remote control or by pressing the "Home" button on top of the frame. Next, choose "Photos" and press "Enter." You'll see all your photos in thumbnail form. Scroll through them with the up and down arrows. Press the "+" key to mark photos you want to copy (use "-" to de-select a photo). When you've selected all the photos you want to copy, press "Set Up," then "Copy Photo," "Enter," "Selected" and "Enter." A dialog box will ask you to confirm your selection; with the cursor on "Yes," press "Enter." The photos you selected will be copied to the frame's internal memory.
Dec 04, 2011 | PANDIGITAL 7270FW Tablet
How do I clear the pictures from my memory card? When I transferred the pic to my computer it asked if I wanted to clear the card but I wanter to be certain they were, in fact, transferred before I...
You can clear ALL pictures from the card by formatting it. In fact, the memory card should be formatted EVERY time you finish downloading pictures from it. This will prevent later problems.
To format the card in the L20, press the MENU button, select Setup (the wrench icon), then select "Format card" (the memory card icon).
Jan 13, 2011 | Nikon COOLPIX L20 Digital Camera
I can't transfer photos from Adobe to digital frame
The Kodak S510 does not have a built-in internal memory. You can hook it up on your computer using a USB cable with a USB OTG connector and copy the pictures from your computer to the inserted memory card or a USB flash drive in the frame.
Also, make sure that your photos are in JPEG format.
Feb 07, 2009 | Kodak EasyShare One Digital Camera
Can't transfer photos from computer to digital frame
Copying pictures from EasyShare software:
1. Install EasyShare software (free download at www.kodak.com/go/sw)
2. Connect the USB cable.
3. On your computer, open EasyShare software. Select the pictures in My Collection and drag them into the Picture tray.
4. In the menu bar, select File and then Copy to the Kodak Drive letter.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, and USB devices.
5. Select the frame source to which you are copying.
6. Select Best for Digital Picture Frame to reduce the resolution of the pictures you are copying. Full resolution is unnecessary and quickly fills up the frame's memory.
7. Click Copy. Pictures are copied to your frame.
8. Unplug the USB cable and on the frame check the pictures that were just copied.
Jan 17, 2009 | Kodak EasyShare M853 Digital Camera
I cant transfer pictures from my PC to a Digital Frame
either transfer to a usb pen or a standard digital card and then insert in photo frame good luck
Dec 20, 2008 | PANDIGITAL (DPF802) Digital Picture Frame
I'm trying to transfer pictures from my computer to the picture f
You can start copying pictures to SV811 digital picture frame if you get the message “Use PC interface to copy files.” Here are the steps:
Copy pictures, videos, and music between your frame and computer, using your computer's normal file copying tools:
1. Connect the USB cable from the frame to your computer
2. On your computer, open My Computer or Windows Explorer.
3. Navigate to the pictures you want to copy. Then drag and drop them to the new location.
4. Unplug the USB cable to view your copied pictures.
1. Install EasyShare software (free download at www.kodak.com/go/sw )
8. Unplug the USB cable and press “Home” icon to navigate to your copied pictures.
Dec 20, 2008 | Kodak EasyShare SV811 (8858946) Digital...
Coby DP-887 Digital Picture Frame: Unable to transfer pictures to internal memory
The Coby DP-887 does not have built in memory so one cannot "load" pictures onto it. It is a viewer in every sense of the word. If you load pictures on a flash drive or memoory stick and plug that into the Coby DP-887 then you'll be able to view pictures or video.
Dec 22, 2007 | Electronics - Others
Transfer from internal memory to new memory card
Go to Playback Mode (with memory card inserted)
Press Menu/Ok (center botton)
Copy
Internal Memory to Card
Then choose "All Frames" or select which ones
Sep 21, 2007 | Fuji FinePix S5700 Digital Camera
Cameras Logo
174 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
