Question about GE JGBS20 Gas Kitchen Range
I have a GE Range that has started acting up. it was working fine at 350, i had to have a temp of 425 and the temp went soaring to broil. the oven control knob would not turn the oven off, i had to pull the plug. do you have any clue as to why this happens or what need to be replaced.
    Habit-Forming:
  • 25 Answers
Yes, most likely the broil relay got welded shut. The company will want to sell you a whole new control board for about $200.00 -- but if you have any soldering skills, you can purchase a new replay for around $6.50.
Posted on Feb 17, 2018
SOURCE:
catriver
  • 878 Answers
SOURCE: Digital Control (for oven temp and clock adjustment) not working
Puzzeled, usually when there is a stuck or shorted keypad there will be an error code. First let's see if we can tell if we are in Centigrade or Ferenhiet. Press the bake and broil button together for 2 or 3 seconds. SF should appear in the display. Press the broil pad again and C or F will be displayed. Toggle to F and press start. See if that was the problem. If not try to increase the speed of the + and - keypads. Press bake and broil together for 2 seconds until SF displays. Press the + keypad increase the speed of the control. It should toggle from 1 to 5, 5 being the fastest. Press start and see if that works. If niether works..then have someone remove the keypad ribbon cable from the control board and clean the ends with an eraser. See if that solves the issue...Catriver..post back and let me know.
Posted on May 12, 2007
  • 58 Answers
SOURCE: Electric Oven not getting hot enough
there are relays on the oven control that turn the elements on and off, sounds like you need a new control
Posted on Mar 12, 2008
  • 26 Answers
Sir, I think the top oelement is for broiling ONLY. It should not turn on when baking. The clicking may be the oven heating up.
How far apart were the oven temp instrument and the digital?
Don't expect them to match...they are inaccurate.
1. Heat water until it boils. Place digital therm in boiling water until it comes up to 212deg. If it is not at 212 in boiling water, record the error.(this gives a rough calibration to the digital)
2 Turn on oven, set to 350 deg, place digital therm on rack. Wait until oven reaches 350 (on stove) and read the digital. Note the difference between the two
Posted on Mar 30, 2008
aborcass
  • 2651 Answers
SOURCE: temperature control
sounds like a bad bake ignitor(uneven heat,long cook times, long preheat times, perhaps even gas smell while cooking)
Posted on Oct 07, 2008
SOURCE: GE JBP30 oven bottom element not working after being replaced
I would be looking at the bake relay on teh coven control board. Using a voltage meter test the output voltage when energizing the bake feature. Be sure to remove the bake element wire coming from the bake element to the control. Test this terminal without the bake element wire attached. From the terminal with one meter probe to the neutral on the terminal block (where your cord attaches to), you should read 110 volts when energized and 0 voltge when shut off. What are you reading? If I can help further, I am here.....
Waiting to hear from you,
Eric Campion
Posted on Feb 15, 2009
Oven gives err message when set above 275 degrees
Your range has been reset to celsius from fahrenheit. It must be reset to fahrenheit.
Press bake and broil pads simultaneous for approximately 3 to 4 seconds.
When SF comes on, press the broil pad.
You should see the Letter C.
Press again and the letter F will come on.
Press start.
Your range shouldproperly set the temprature now!
May 03, 2012 | GE Profile JTP56 Electric Double Oven
Oven temp heats higher than set
The control board is bad. One of the relays has fused and you will need to replace the control board.
Jan 07, 2012 | General Ovens
My Frigidaire FEFL77ABF gets way too hot. When set at 350, temp soars to over 450. Have cleaned oven and tried resetting procedure, but neither worked. High temps are not consistent, so I can't...
Hi
This means a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 02, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
I have Range GE J34CFT 1 that is not heating up correctly
You have to start with putting an oven thermometer in the oven and comparing the oven temp with the temp that you set it to
Jul 21, 2009 | GE Kitchen Ranges
Broiler will work, but oven wont
Could be the bake igniter is bad and broil igniter is still good. may need to replace the bake igniter you will need a complete model number off range to determine the part number of the igniteryou may need.
Jan 07, 2009 | KitchenAid KGST307 Gas Kitchen Range
GE Spectra XL44 oes not heat to desired setting
The oven sensor ( WB21X5301) is suppose to tell the oven control when to turn on and off to reach and maintain oven temp, but before you go replacing it, try to observe how long it takes from the time you turn the oven on to the time the oven ignites. Ignition should be 30 seconds to about 90 seconds. If it is taking a very long time, replace the igniter (
WB2X9154
). Ignitors get weaker over time, and this should be looked at first, as both parts are not real cheap, so you don't want to just start throwing parts at it. Here is a trick you can try: On the JGBP90 (model you posted under) the broil ignitor is the same part number as the oven ignitor, so if the broiler, which is generally used much less than the oven, is working fine you can interchange the two ignitors to see if that solves your oven temp problem without having to buy a oven temp sensor first.
Nov 10, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven does not heat to proper temperature
1. Do both coils get red hot? Try with bake @ 400F, then with broil to be sure. I recently had a bad lower bake coil, but the oven got hot slowly since the broil top coil comes on periodically to even up the heat in the oven. Replacing the lower coil was easy, about a 15-min job, but I had to pre-tap the screw holes on the coil terminals since my oven had extremely short wires.
2. If the coils are ok, the problem may be with the thermocouple or control board.
Oct 02, 2017 | GE Profile Spectra JGBP90 Gas Kitchen...
My GE XL44 doesn't heat up to full temperature.
There are several things to check.
1) check the broil element
The broil element participates in the preheat and if the element isn't working it will take forever to reach temp.If the element is good 2)check the broil relay
If the relay does not activate when you press"broil" the control needs to be repaired.They are a few more things to check but you can start with the above.
We rebuild these controls.
Regards,
Howard http://www.appliancetimers.com
Apr 13, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Mar 30, 2008 | GE Profile Spectra JBP95 Electric Kitchen...
May 12, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE JGBS20 Gas Kitchen Range Logo
Top Kitchen Ranges Experts
Ismael Rodriguez...
Steve Allison
Steve Allison
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
