Cars & Trucks Logo
Posted on Feb 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Jaguar s type 2000 over heats when stop in traffic,
Anonymous
Level 3:
  • Master 463 Answers
  • Posted on Feb 20, 2011
Anonymous
Master
Level 3:
Answers
463
Questions
Helped
182714
Points
1499
Here a two of the most common causes for overheating;
1. Low coolant.
2. Faulty thermostat.
Make sure your coolant level is up to the FULL line on the coolant reservior, ( do not fill completely up or you cauld cause the check engine light to come.)
Check to see if the thermostat is working.
How to test the thermostat in most vehicles;
Make sure the heater is off, start the engine and let it run for 6 to 8 minutes, ( this will allow the
engine to reach, " normal operating temperature "), from the inside of the vehicle turn the heater
temperature on high and turn the fan speed on high.
1. Listen very closely for a click sound from the engine, ( most thermostats make a click when
they open )
2. Watch your temperature guage, it should begin to lower as the coolant starts to circulate.
3. Usually within a few minutes the radiator fan will kick.
I hope this helps you.
Donnie
2000 jaguar s type no heat
On this vehicle the heater control is electricaly operated valve by the engine so check this valve is working and it has power when heat control is turned on.
2helpful
2000 Jaguar S type 3.0 Blows only cold air on full heat. Just replaced heater control valve with no change. Also flushed and replaced thermostat. Car operating temperaure is fine. Both heater hoses are...
Check the little pump below the brake booster for running and the coolant valve for movement.
Both hoses to fire wall should be hot.
Check for air lock in system.
Blend doors on this vehicle stop working....common complaint.
To verify Blend door movement, turn on ignition with engine off.
Run temp to max and the min..... listen under glove box for ( sliding ) motor noise as door swings from hot to cold.
This is a digital system needing a Jaguar scanner for diagnosis.
Jaguar s-type 2000. is the heater core and the A/C in same airbox
i believe you have to remove the dashboard to get to it!
FAN OF A JAGUAR S-TYPE 2000 HAS ONLY ONE SLOW
check the blowermotor resistor, this is what controls the blower speed and is a very common problem.try replacing the resistor, that should solve your problem. good luck.
Jaguar 2000 S type. Traction control fault light
the little teeth on the front axles maybe hanging up give these websites a try www.autozone.com and www.alldatadiy.com if all fails stop by your local Jaguar dealership in the parts department and they can print you out pictures and diagrams wish you the best Michigan Man.
1helpful
My 2000 jaguar s-type transmission is acting up
your fluid needs topping up, auto matic transmissions actually use the oil to drive, not friction plates as in normal manual transmissions
3helpful
2000 jaguar s-type heat does not work from the driver side vent.
Hi there is a, dual valve down on the right side of the radiator to split the heat to each side. are the pipes hot where they enter the car be careful       D
Top Jaguar Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Jaguar Expert? Answer questions, earn points and help others
