Question about HP PSC 1210 All-In-One InkJet Printer
Cradle printer has been working perfect, but I addressed an envelope and it jammed. I removed the jam from the back, but now it says the cradle can't move. I don't know what the cradle is...is it possible for me to fix?
  • country gram Aug 01, 2008
    Printer is a HP hps 1210 all in one. The message says "the cradle can't move". I don't know what that means..or if it is something that can be fixed easily.
    Country gram
  • carl reive alberto
    carl reive alberto May 11, 2010
    what is the exact model of your printer
  • 181 Answers
You need to clean the rollers in the back panel of the printer and reset the cradle or carriage if you can. The cradle is what moves the cartridges back and forth inside the printer.
Unplug the printer while it is powered on and remove the back panel. Get a damp cloth (not too wet) and wipe off the rubber rollers in the printer as well as on the panel. Replace the panel and Open front panel where cartridges are and move them all the way to the left and back again to the right. Make sure there is no paper or anything in the way blocking the printer from printing.
Plug printer back in and it should come on by itself and initialize.
Print a page from your computer. It should now only feed a single sheet at a time and the cradle should move freely.
If not then the cradle itself may have been jolted and misaligned. You will need to replace the unit if that is the case. You should call and see if you can repair or upgrade the unit at a discounted price. If you want to speak to someone in English tell them you want mac support - they are in Canada.
Posted on Aug 07, 2008
How do I print envelopes? It just jams when I
when you load the envelop, you should make sure that you adjusted the tray to lock the envelopes in place, or otherwise, they will move and cause a jam
Sep 22, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
I have a paper jam on my HP 3210 Photosmart All-in One
When you open the back door there's a guide that pulls down and on either side of the fuser there are levers to release the pressure from the rollers, if you can see any of the envelope from there you should be able to gently and evenly pull it thru. Otherwise a shop repair to remove the rest and fix whatever caused the jam.
Sep 04, 2009 | Brother HL-2040 Laser Printer
Paper pickup not moving
Have you set the margins?????
If you push the left margin over, it may help.
Jun 08, 2009 | Konica Minolta magicolor 2400 Laser...
#10 envelope stuck in machine
Please try these steps:
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Apr 26, 2009 | Office Equipment & Supplies
Paper jam in lexmark all in one x7170
It insists there is a Cartridge problem on the Printer............ In this Case take out the Paper from the Paper Feed Tray........ Unplug the Power Supply from the Printer.......... Remove both the Cartridges from the Printer.......... Now take a size 10 Envelope fold it so that it should become like a thin long strip........ Now Insert that Envelope on the left side corner of the Printer and move it from right to left and left to right as fast as u can for about 10 times.......... Now Insert the Ordinary Papers onto the Printer and insert both the catridges and Move the Catridge Carrier which holds the Catridge Back and Forth for abt 20 Times as fast as u can.............
Turn On the Printer........
Good Luck...........
Apr 05, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Even thought there is NO paper jam, I still get an error message:
Please try this solution :
Feb 19, 2009 | HP DeskJet F4280 All In One Printer InkJet
Carriage jam
Nov 04, 2008 | HP Officejet 7210 All-In-One InkJet...
Paper jam message
Good luck...
Oct 27, 2008 | Lexmark X3470 All-In-One InkJet Printer
"shadow" print on letterhead and envelopes
CLEAN YOUR DRUM WITH COTTON SWAB. (AND BLOW OUT PRINTER1.gif IF YOUR DARING.)
Jan 02, 2008 | Brother HL-2040 Laser Printer
HP PSC 1210 All-In-One InkJet Printer Logo
96 people viewed this question
Seeker5211
Seeker5211
