Question about Dryers
  • 11 Answers
SOURCE: Maytag Atlantis MDG7400AW Gas Dryer not drying clothes
This problem doesn't sound right, but you could have a bad moisture sensor.
Posted on May 20, 2007
  • 164 Answers
SOURCE: Maytag Atlantis MDG7600AWW Not Heating
the gas coils have a problem. as the dryer heats p the coils on the gas valve are failing causing the dryer not to heat. replace the coils and you should have no problem
Posted on Oct 23, 2007
  • 619 Answers
SOURCE: maytag atlantis will not turn off
the control panel wiring open need to reconnect.
Posted on Jan 01, 2008
  • 4 Answers
SOURCE: maytag atlantis dryer model # mde6400ayw
sounds like the timer is not completing the cycle in this mode will the dryer shut off if you manuelly advance timer in that mode
Posted on Nov 01, 2008
  • 1198 Answers
SOURCE: Maytag Atlantis Dryer squeals
Try for help and parts. You are going to need heat resistant grease, and probably snap ring pliers.
Posted on Apr 28, 2009
Not sure what model is other than maytag atlantis but my gas dryer has quit heating therefore does not dry...any suggestions?
check voltage to dryer, should be 220-240. check element, thermal fuse. could be in the timer but rare.
Jun 26, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis MDG6400AWW, timer stopped working
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
May 20, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
Maytag Atlantis MDE7400AYW timer has been replaced but the dryer won't stop drying on it's own. What is the reason? I have the same problem... the timer on mine doesn't seem to work. Any ideas?
The wire connections to the timer may have not been made correctly when it was replaced bypassing the OFF contact in the control circuit.  There should be a wiring diagram inside the front or back panel that you can check.
Jun 02, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag atlantis gas dryer, will start, heat up but then no heat
Try running it with the vent disconnected and feel the air coming out of the dryer. It should have good flow. If it dries good, your pipe may be clogged.
Mar 29, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag atlantis gas dry is not heating up its about 6 years old
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
Mar 28, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag atlantis dryer does not heat
Perhaps the thermal fuse is open. All thermostats and thermal fuses should be closed for continuity at room temperature on this dryer.
Go here for more Maytag Atlantis Dryer repair help:
Feb 01, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis MDE6200AYW will run, but no heat
Check to make sure that you have the proper voltage running to the dryer first. Next you may have a problem with your heating element or with your thermal fuse. Get your dryer opened up so you can see your heating element. Run the dryer and if you see the heating element come on and then turn right back off again then you have a bad thermal fuse. If it doesn't come on at all though then the heating element is bad. Both parts can be picked up at your local appliance repair shop. Just make sure to unplug the dryer before replacing the part. If you have any other questions let me know and let me know if this was helpful for you. Good luck.
Nov 22, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Dryer not heating up
you need to be getting at least 220v to the terminal block, if you don't check recepticle and the breaker
Jun 01, 2008 | Maytag Atlantis MDG6400AW Gas Dryer
Maytag atlantis electric dryer
Sounds like the moisture sensor has gone away. Not sure where it is located on this model, though.
Dec 01, 2007 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
277 people viewed this question
Top Dryers Experts
