Question about Ruud UBHC Air Conditioner
    An expert who has answered 500 questions.
  • 540 Answers
If it says 70-amp, then you need all the protection it needs , when all your electrical apparatus kicks in and **** 57 amps guess what the fuse is suppose to do, blowout! NOW DO YOU SEE WHERE I"M GOING WITH THIS!
Posted on Sep 01, 2008
I have a electrical problem in my 200 AMP murray braker box.It was put in around 1975.It looks like the 200 AMP main breaker is arcing.When the fridge starts the lights go dim..Will another braker work?
The best answer I can give is a new breaker might solve the problem.If the arcing has not damaged the bus bars where the main breaker is connected. Be sure to check to see that all connections are tightened properly. If you are using aluminum wire be sure to use a deoxidizing compound. Tighten the aluminum connections, wait a while, and recheck tightness.
Hope this helps.
. Bob
Nov 06, 2013 | Cutler Hammer "CUTLER HAMMER" ARC FAULT...
Cant find curcuit braker on my 97 saturn
It should be connected in series with a circuit. Since a circuit breaker acts as an "over current" switch it will be connected just an on/off would so as to "open" the circuit during an over current condition. This will remove power from the circuit.
Jul 15, 2012 | 1997 Saturn SL
All the power windows stopped working all at once, it is not the curcuit braker
It has a breaker but most of the time it's the main switch "driversdoor". The breaker will reset itself.
Sep 27, 2011 | 1996 Isuzu Trooper
I have a thermosol AF 240 steam generator it is wired to a 50 amp GFCI breaker. It has worked for about a month, but now the breaker pops immediately. Checked for wires touching, replaced breaker, but...
Is the wire compatable for a 50 amp breaker. Also unit souuld be on its own dedicated curcuit, also how many amps is the service in the building, if your only at 100 amp it will not work.
Mar 06, 2011 | Thermasol Steamshower Generator AF Series...
A 60 Amp breaker (three phase) powers an 125 amp main lug 3 phase panel is that k or do i need a bigger braker. the wires are #8 THHN.
The breaker that feeds the panel and the wire are what determines the rating. The panel has to be at least as high as the breaker. It can be more, and no problem.The problem I see is that the wiring is undersized for the 60 amp breaker. You should have #6 wires or change the breaker to a 50 amp. If that is not enough for your load, you must change the wiring. It also depends on the type of wire. THHN will have the largest amperage, but if it is TW, it will be lower. Rule of thumb would be #10-30 amp, #8-40-50 amp, #6-50-60 amp, #4-70-90 amp and #2-95-135 amp. There are other factors, such as derating etc. but if you wanted to increase to 100 amp, I would run #2 thhn. Hope this helps.
Mar 05, 2011 | Siemens Murray 125 Amp Circuit Breaker...
The red 20amp braker at the bottom of my box keep berking with only a small amont of things pluged in. Any part of the house THE SAME BRAKER brakes . is that right? The same braker?
sounds to me that the breaker is getting weak,try replacing breaker with new one,if it still trips then you have electrical problem in a circuit.
Dec 20, 2010 | Sylvania Circuit Breaker - Zinsco/ RC 20...
Indicator lights flash but no movement
Tripped breaker or blown fuse. Breaker will be 50 or 70 amp located at rear of chair where joystick harness plugs in. If there isn't one there you have fuses and will need to take the seat off to locate batteries. Inline with the batteries are two 50 or 70 amp automotive type fuses or a fuse "block" mounted to the battery. If they're burn't they will need replaced.
Jun 15, 2010 | Invacare Pronto M51 Power Wheelchair
Poping the curcuit braker
Your compressor is bad .Need to replaced, a way to test is unplugged the compressor and see if it stays on
Dec 28, 2017 | Amana ABB2223DES Stainless Steel Bottom...
Ruud UBHC Air Conditioner Logo
53 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
