Question about Frigidaire Heating & Cooling
Cooling has stopped
The compressor kicks in but the unit is not cooling. I cleaned the filter, and vacumed the unit. After removing the unit from the wall sleeve I noticed water in the catch basin. I removed the water, and cleaned the coils. The fan speed changes when going from low to high. Could the unit have a leak after three years of running ok? What can I do to determine the cause and possible re-charge the unit?
  • 143 Answers
Apparently the freon has escaped or the metering device for the freon is plugged up. Either way, it's expensive. Check your warranty for "sealed system" repairs.
Posted on Jul 27, 2008
What causes compressor to work fine then shut down and not come back on for an extended amount of time?
Sometimes these AC's need to be removed and given a damm good cleaning with a spray hose, and any filters replaced. Clean the internal fan(s).
This can sometimes fix overharting of the compressor or misleading air temp sensing..
Jul 08, 2015 | Frigidaire FRA296ST2 Air Conditioner
Hi... my dehumidifier compressor will not turn on, the fan runs fine and the time 2 hr/4hr cycles work, but the compressor wont kick on, the filter is clean and the unit is no more than 2 yrs old. Any...
Sounds like the compressor is inoperative. Most, if not all new units have no means of recharging the freon if it leaks out. If the coils are not cooling, the compressor is not operating and the unit will not dehumidify.
Jun 26, 2011 | LG LD65EL Dehumidifier
Want to check for leaks and recharge a dometic rv roof unit 2007 compressior kicks in and out and not cold
They are a sealed unit, and you would have to get a Refrigeration tech to install valves to do so, which usually costs close to replacing upper unit (roof unit).
A few things come to mind in your case.
- Are you getting proper 120 AC Voltage?
- Has unit been cleaned recently, as in filter, evaporator, condenser ? Any of these plugged can cause it to shut down.
- is it freezing up due to improper flow from discharge ducts, as in have you closed too many ? Remove filter at ceiling and have a look at coils/fins, at front for frost forming on them when it shuts down.
- How long does it run before compressor kicks out, and how long before it comes back on?
- Does it feel cool when compressor kicks in?
Get back to me with more info if you can, so we can narrow it down better.
Feb 14, 2011 | Dometic Rooftop RV Air Conditioner
I have GE AJES12DCBM1. Recently after one of the storm, it stopped cooling. Fan motor comes on. Compressor is also kicking on but it kicks off within a minute or two. Is it possible that the capacitor may...
Check inside and outside coils for cleaning with coil cleaner spray
Check capacitor(remove and take to appliance parts dealer. They will checkit)
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
Sep 03, 2010 | GE J AJCS08AZ Air Conditioner
Unit runs but will not cool. Fanruns fine but when turn dial to cool the compressor kicks in for about a second or two the kicks out. Fan works on cool but it will not produce cool air at any temp...
you may need to install a hardstart kit if you can get to the compressor.
go to your nearest appliance parts store to get the part and the instructions are usually on it. If not ask the parts man.
Aug 08, 2010 | Heating & Cooling
Unit does not cool. Original unit was replaced because of defective compressor. Replacement unit worked in store but now does not cool and alternates blowing cool and warm air.
Is this a window unit? Sounds like the compressor may be cutting on and off. That would cause the alternating air temp you are feeling. Make sure the condenser fan is running. If it isn't running head pressure will build up on the compressor until it shuts down. Then the pressure will equalize and the compressor will kick on again. Also check your filters and the condenser coil to make sure it is clean. Let me know what you find.
Jul 08, 2010 | Frigidaire Heating & Cooling
Room a/c works great for hours and then compressor just stops
the unit may be knocking off on defrost if the coil is getting v cold,
check for full airflow over the indoor unit/evaporator coil, check filters fan operation and coil condition. Likewise it may be overheating so check the same on the outdoor unit/condenser clean coil and fan operation.
Unlikely but the unit may be under performing and slightly short on refrigerant, not providing enough suction cooling to the compressor motor so the internal over temp klixon would cut it off for short periods, to cool the motor.
Jul 05, 2010 | Samsung AW1203B Air Conditioner
My freezer is not freezig and the refrig is not getting cold. There is a notice coming from what I assume to be the compressor in the back of the refrig at the bottom.
Check Relay and overload on compressor terminal. sometimes due to faulty relay overload tripping which makes tik tik sound. before replacing relay need to start compressor directly.
Nov 17, 2009 | Roper RT14DKX Top Freezer Refrigerator
Heating & Cooling Logo
48 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
