Question about Technics SCEH790 CD Shelf System
Error msg Every time i prees any button except the 'super sound EQ' on my sound processor i get an ERROR mesage appear.... how can i fix this problem?
    Problem Solver:
  • 19 Answers
If you are on radio then super sound eq is only functions allowed to use but while using the other functions they are all lit up and are allowed to be used.
Posted on Apr 10, 2011
Audio Output Non-Functional
Yes. Take it to the repair shop and have yet outputs fixed.
Feb 27, 2017 | Kenwood Stereo Graphic Equalizer - Ge-76
The cd player on my 2005 vw golf keeps spitting out cds immediatly and a message 'cd error' appears. this error msg with an error tone happens 4/5 times after starting the ignition - is there a simple way...
It sounds like something is jammed in the carriage or the carriage assembly is bent slightly. You will need to remove it and see if it can be straightened, if not, then replaced.
Mar 15, 2011 | Car Audio & Video
How do i connect my technics su7700 amp to my technics sh8020 equaliser
Like any sound processor, in the tape loop...
Receiver Tape Out (Rec) - to the External Processor (EQ, whatever) Preamp-, Rec or Line-In;
Receiver Tape In (Play) - from the External Processor (EQ, whatever) Preamp-, Play or Line-Out.
Feb 15, 2011 | Audio Players & Recorders
Looking to hook up an older model fisher EQ (EQ-961) to a newer Sony amplifier (STR-697).
Typically you would place an EQ or any processor2_bing.gif in a Tape Loop:
MD/Tape (or Video1) Rec/Out to EQ In; EQ Out to MD/Tape Play (or Video1) /In on the amp. Select MD/Tape (or Video1) on the receiver to place the EQ in-line with whatever source you're playing. Use it's ability to modify the sound sparingly.
Be advised, use of an external processor will only work for analog stereo sources and will likely DISable anything digital as soon as you activate the switch that puts it in the signal path.
Feb 23, 2010 | Audio Players & Recorders
I have a Yamaha HTR-5890 receiver and I am trying to hook up a Yamaha EQ-32 10 band graphic equalizer to the receiver. The frequency spectrum analyzer on the equalizer is working but the graphic...
must have the tape monitor to work the regular tape loop does not physically go back into the receivers processor.
only other solution is if the receiver has PRE out and ins use the PRE out to the EQ then back into the PRE in.
if you have the OUT but no in then the solution would be to go out of the EQ and into an external amp.
In my experience "young adults" like using EQ's to boast bass output.
If that's your goal a POWERED subwoofer is what you need.(check out polk audio direct on ebay)
Your unit is a 7.1 surround receiver the reason that it doesn't have the capability for an EQ is that it messes up the surround sound processor.
If the sound is not what you are looking for the issue more than likely is with the speakers. post a messege with what you want to achieve and I'll try to point you in the right direction.
Dec 29, 2009 | Yamaha HTR-5890 Receiver
Epson RX680 Scanner Error msg and noise
If you only purchased it on the 8/9/09 then it is still under guarantee so the cheapest fix is return it for replacement.
Aug 24, 2009 | Epson Stylus RX680 Color All-in-One InkJet...
Error 5 for ncr 7875 scale scanner
If the scanner read only two times is a problem with the communication protocol.
What protocol do you use?
Explain more about your problem with your calibration pricedure
Jul 29, 2008 | NCR 7875
Computer Clock Speed Message
Go to control panel then add hardware then once that is don't click on ive connect the hardware then see witch hardware isn't connected then press search from the software\are
Jul 08, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Reading lens error on nikoncoolpix l12
Hitting camera on desk once has partial fix.
When camera's batteries taken out & then put back in and the power on button pressed to switch camera on, the lens extends out & the camera now works.
BUT when the power button pressed to switch camera off the lens retracts AND a "Lens Error" msg appears on the LCD screen.
Just have to take batteries out to remove msg & start again as above but WITHOUT hitting the camera.
Thanks
Feb 07, 2008 | Nikon COOLPIX L4 Digital Camera
Connection between CD, EQ, SP technics
Each unit (the EQ and the Processor) should have left/right in/out rca jacks as well as L/R tape in/outs. The EQ or processor use the receiver's tape loop and then provide a tape loop to replace the one they've used on the receiver.
You plug the first unit (let's say the Sound Processor into your receiver/amp as if it were a tape deck (Processor's outs connect to reciever's tape ins (play) while the Processor's ins connect to the receiver's tape outs (record).
Then you chain the EQ off the Processor in the same way (EQ outs connect to Processor's tape ins (play) and EQ ins connect to the Processor's tape outs (record).
Last you connect the tape deck to the EQ as follows. Tape deck outs connect to EQ's tape ins (play) and the tape deck ins connect to the EQ's outs (record).
This will put both the Sound Processor and the EQ in the receiver's tape loop. In order to have all the receiver's source signals routed through them you may have to engage a Tape Monitor switch or button somwhere on your amp which will route the tape loop to your speakers.
Jan 09, 2008 | Technics RS-TR272 Single Cassette Deck
Technics SCEH790 CD Shelf System Logo
49 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
