Does not want to turn on
The problem is that when try to turn it on, it doesn't come on when I pull it up to the charger the first light in the front turns orange and the second turns green but still doesn't power on.
    Sergeant:
    Champion:
  • 244 Answers
It's look like you have problem with no post.
Try to re-seat your memory first. if it's still not working try to use 1 memory and try to put it in different slot.
if you have good memory, try to use it.
and if with your good memory still not working, your motherboard is bad
Posted on Jul 26, 2008
3 Suggested Answers
  • 68 Answers
SOURCE: My laptop won't turn on
Charlotte
Can you remove the battery? If so pop it out and leave it out for a couple of minutes then pop it back in and see what happens.
Regards
Nick
Posted on Oct 26, 2008
SOURCE: Dell inspiron 9300 wont power up/good battery and charger
check if your systemboar power is on or not, and also check if the fan is spinning or not. If not try and reset your processor.
Posted on Apr 20, 2009
The charger doesn't do anything. I've charged the charger then hooked it up to the battery (pos on pos, neg on neg) then tried to start the car. No reaction whatever. Is there something else I
It's possible you may have a poor connection from your car to your car battery. Check to make sure both battery terminals are on your battery tight. Tighten them if necessary, then try again. If either one was loose, that should fix the problem. Then there may be nothing wrong with your battery charger.
Jan 17, 2013 | RoadPro Road Pro 12 Volt Dc Portable...
My zoom g1xn suddenly stopped working. When i connect the power source, it doesn't turn on. . . When i tried batteries, i turned on but the display was flickering then it turned off. . . What is wrong?
Try another cord/charger. Check the AC jack in the machine. Is the battery charging with the cord/charger plug in? Has the laptop AC jack been pulled by the cord? Damaged?
Dec 11, 2012 | Computers & Internet
Motorola cellular w376g, battery won't charge
If possible test with another charger like a car charger if you have one
also try removing the battery plug in the charger and put the battery back in (don't touch the contacts/gold pins)
if it works with other chargers then the charger is bad
if it doesn't work with other chargers charging port/battery/phone is bad
May 27, 2012 | Cell Phones
I was using my psp while it was charging and the charging light turned off, so i naturally assumed that it was fully charged. But a few minutes later the battery died and it wont charge when i plug it in....
Have you tried to remove the battery and put it back in and try to turn it on. Try removing the battery and putting the charger in and starting the PSP. If it starts, it might be the battery. If it doesn't, it's either the plugin for the charger or the PSP is just dead. If it does start with the charger, try putting the battery back in, if it charges awesome. If it doesn't the battery might be dead.
Sep 27, 2011 | Sony PlayStation Portable (PSP) Console
My cobra microtalk cxt450 will not charge. and the charger lights are not on when i place them in the charger
pull the batteries out, slam them ******* a solid surface. put 'em in, let 'em charge. if that doesn't bring 'em back buy new bats.also, use a voltmeter to make sure the charger was getting voltage.
Sep 04, 2011 | Cobra Microtalk 100 FRS Walkie Talkie...
Hi, I've had my Acer aspire laptop for a few years now, but I haven't used it for over a year (Because I got a desktop). So when I've come to turn it on today, It won't work. The screen...
Start with pulling the battery and power, then hold the power button in for about 30-40 seconds. Then plug the power back in (still no battery). Try to power up the computer. If it boots, shut it down and put the battery in and try again. If it boots the issue was cleared. If it boots with the power cord but not with the battery added, you have a battery issue.
Hope this helps
Sep 01, 2011 | Computers & Internet
My Acer Aspire One D255 will not turn on. Light shows blue then immediately goes off. Won't boot on or anything.
Make sure that you have a charge. Try plugging it in and turning it on. If it still doesn't work then you might have a low battery, bad charger, or there could be a problem with the power supply. A bad charger and or a bad power supply would require replacements. You can probably find the charger at best buy or newegg.com. The power supply could probably be found at newegg.com. You might try taking it to a local electronics store and see if they have a different charger they can test it with, that way you would know for sure it isn't the charger.
May 03, 2011 | Acer Aspire One Netbook
I cant get any power and i have had the power chair for a few years orginal batteries and it ussed to work what do i do
lil plug in the charger for your chair and then turn on the power and see if qall the lights on the battery level light up if they do then the charger is putting voltage to charge your chair. unplug the charger and try turning the power on if it doesn't come on then you need to have the batteries replaced Hope this helps you
Apr 25, 2011 | Health & Beauty
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
