Question about Sony Playstation 3 (PS3) Console
Ps3 Eject Fault
My ps3 6 months old, cod4 loaded disc not recognised and will not eject owned the game since it was new no problems. I know the ps3 is under guarantee any ideas re this fault please.
Many thanks
Matt
  • 344 Answers
Hello.
I would call Sony. This problem is due to a faulty Blu-Ray drive, dust or abuse. When the optic sensor is faulty or dusty it can not tell if there is a disc inside the unit or not. So the blue light will flaash and you will hear multiple beeps, but the disc will not come out. Without actually testing the unit myself, it's very hard to diagnose the exact problem. But Sony should fix it for you. Hope this helps. Good luck!
Posted on Jul 28, 2008
Game disc dosent pop up and when click on stuff it freezes
  • 1
    Press the "Eject" button on the PlayStation 3 console and hold it for at least 10 seconds; if your PS3 has the "force eject" feature included it will eject the disc regardless of whether the console is frozen or not. Turn off the console and turn it back on before inserting new discs.
  • 2
    Unplug the power cord and any other cords from the PS3 console if the "force eject" feature does not work and you own a PS3 Slim. Turn the console upside down so that you have access to the bottom of the console.
  • 3
    Locate the small compartment door on the bottom of the console. Remove the door by pulling it up and off the console; a blue screw and a small hole should be visible inside the compartment.
  • 4
    Insert a Phillips-head screwdriver into the hole. Turn the screwdriver in a counterclockwise direction to manually eject the disc. Once the disc is removed, replace the compartment door and turn the PS3 console back to its correct position before reconnecting the power cable and any other cables you previously removed.
  • Jan 29, 2012 | Sony Playstation 3 (PS3) Console
    Problem with the disk drive, the console isn't recognising it and it won't eject, think its stuck
    One thing you could try is to turn the console off that the back of the PS3. Turn it back on so it is in standby. Hold down the disc eject button and then press the power button on the front. This should force the disc to be ejected from the PS3. Hopefully this will solve your problem but if it does not please reply here and I will do my best to help you some more.
    Aug 09, 2010 | Sony Playstation 3 (PS3) Console
    Game is in Ps3, wont eject, says no game in the xmb screen
    if the disc is spinning with some clacking noise then its all right,use the manual eject button 3 to 4 times.Now the disc should be sited on the disc plate.If you think that this works but not through the software then update the firmware.On new slim PS3 disc stuck,it doesnt void your warranty.
    Thanks for using Fixya
    Jul 02, 2010 | Sony Playstation 3 (PS3) Console
    The drive will not eject games, and will not read games once removed. The drive just makes a whirling sound and I have to hold the ps3 @ an angle just to eject games. And now the drive won't accept...
    Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The most common reason for the PlayStation not ejecting discs is a bad drive.
    Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This drive should fix any issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your PlayStation including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your PlayStation going again!
    May 27, 2010 | Sony Playstation 3 (PS3) Console
    Put a playstation 1 game in my ps3 an it wont eject out it beeps twice
    Currently the problem i see here is that you may want to get your disc out first and then check if your PS3 is working fine
    Here's what you need to do to eject the disc:
    Hold Eject button down for 6 seconds (while PS3 is on)
    This should force eject the disc, let me know if this helps
    I am not sure which version of PS3 you are having and which ps1 game you are playing, so please check about backward compatibility of your game here
    Nov 23, 2009 | Sony Playstation 3 (PS3) Console
    Playstation 3 Error Code 8001050
    8001050B - Will not play demo hard drive games, when blue-ray disc is inserted - Cause unknown
    8001050D - An error occured during the start operation; Ps3 game swapped using the eject function and then play pressed quickly - ps3 game inserted again
    More error codes on
    http://boardsus.playstation.com/playstation/board/message?board.id=ps3&thread.id=1857127
    Aug 04, 2008 | Sony Playstation 3 (PS3) Console
    PS3 stopped playing discs
    what is up with PS3 anymore? Of course, all these systems are used or as-is but still...
    I bought mine at a reputable pawn shop and it played for almost a month and it stopped playin metal gear 4 and college 9...Downloaded he new system update and nothing
    Jul 30, 2008 | Sony Playstation 3 (PS3) Console
    Playstation 3 will not load any games
    i went to mi mates house wid cod4 and when i got home tryed to play on it and it wont load up onto the home page .... any ideas
    Apr 07, 2008 | Sony Playstation 3 (PS3) Console
    My ps3 won't eject a disc it beeps and the it makes this clicking noise
    I have my COD4 also cd that won't eject and does not appear on the xmb screen nor the blue light is on.
    Feb 27, 2008 | Sony PS3 40GB Best Sellers Bundle Console
    Sony Playstation 3 (PS3) Console Logo
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
