Question about U-Line 75WC Wine Cooler
My wine cooler
The cooler temperature is not working
  • 286 Answers
If the unit is dead then its most likly a bad thermostat. Light usually works but no fan or compressor
Posted on Jun 15, 2009
Wine cooler frost buildup
Some dual temperature wine coolers build up frost in the rear and top of the main compartment. Check the defrost timer, located either inside the main compartment near the light, or outside on the back of the wine cooler near the compressor. Look in the owner's manual for the correct settings for the defrost timer and adjust yours as needed. Make sure that you have the wine cooler in a spot where the outside temperature remains at or near room temperature to reduce frost buildup.
Aug 11, 2012 | Danby DWC283BLS Wine Cooler
Tip
Benifits of Wine Coolers & Accessories
Wine Coolers are a great choice for many wine enthusiasts. Wine Coolers & Accessories can be placed virtually anywhere in the home and Wine Coolers offer either a single or dual temperature control zone. A wine accessory is generally any equipment that may be used in the storing or serving of wine.
http://www.jilliandistributors.com/products/wine/
on Aug 16, 2016 | Furniture
Do I need a wine cooler to store my wines or can I store them in a normal refrigerator?
The purpose of a wine cooler is to store wines at their proper temperatures in a proper manner. Wine coolers are set to higher temperature ranges than other systems simply because wine should not be kept as cool as other beverages.
Jul 31, 2012 | Furniture
It just stopt cooling (wgersdorf@yahoo.com)
Turn the temperature dial to the lowest temperature setting. Wait 24 hours for the wine cooler to reach the desired temperature. Also, turn the wine cooler off and inspect the fan. If the fan if it's running or not.
Lastly, check the compressor.
These are the areas that could make your wine cooler stop cooling; the temperatue settings (Thermostat), then Fan and the compressor.
Check these three areas and let me have a feed back.
Bye for now.
Mar 04, 2011 | Haier BC112G Wine Cooler
How to adjust the temperature of the wine cooler
How is temperature adjustment set for proper cooling,my Haier holds [9] btls of wine ,please help.
Jan 05, 2011 | Haier BC112G Wine Cooler
Chamber wc902 wine cooler which wont set temp
I have the same issue especially when there is a power outage. To reset it, press the preset until "1" appears, then adjust the temperature as low as it will go by repeatedly pressing the temperature "-" button. Usually works.
Oct 08, 2009 | Tower Chambrer WC601B 7 Bottle (6+1)...
Avanti WC492D wine cooler temperature control does not work
the wine cooler has to be at least 3" away from the wall, do not block the air flow to the condenser. or check power plug to outlet is it secure.
Feb 21, 2009 | Avanti WC492D Wine Cooler
How to reset the temperature on the danby silhouette wine refrigerator
This happened to me, I found that the cooler would not go below 70 degrees because the cooler had lost its coolant or wouldn't work. I do not know, but as it was under warranty, an appliance repairman came and said that it was worth fixing, so it was replaced with in a week. Normally you would just hole the button in until the desired temperature is selected. Once released the cooler would attempt to set this temperature. If it is not, then I suspect it too is broken. Good luck.
Jun 03, 2008 | Danby DWC283BLS Wine Cooler
U-Line 75WC Wine Cooler Logo
212 people viewed this question
Top U-Line Furniture Experts
John Tripp
John Tripp
Michael Galve
Michael Galve
Sal De
Are you an U-Line Furniture Expert? Answer questions, earn points and help others
