Question about Refrigerators
Ice maker (WR30X0328 can10) causing freezing water mess
Hello sir: I have the GE Performance side-by-side. Recently I changed the water filter and then all of a sudden the ice maker started leaking water somewhere and it freezes up all over the freezer making a big mess of icicles all over the place. I don't know how changing the filter would have caused the problem.....of perhaps it was just a coincidence.
Is this a sign that I should replace the ice maker or is there another alternative. thanks
Reginald
  • mattp746 Sep 05, 2008
    I have the same problem with my GE Profile Ice Maker. It leaked water out of the right front side of the ice maker after changing the filter. Then it stopped working. My water on the front of the fridge stopped also. I pulled the filter and inserted the filter bypass insert. Nothing works? Is the ice maker gone? Is the water on the front broken?
SOURCE: GE top freezer ice maker leak
I have the same problem -
Posted on Aug 11, 2008
SOURCE: Kenmore / GE side by side defrost drain keeps freezing up
Remove back of unit and check defrost heater has not become detached, otherwse the is only two possibilities, one a defrost fault and although you say the defrost tube is clear the only reason it does not flow is due to a restriction, what can happen is that the water backs up the drain pipe and then freezes before the water in the external tray can evaporate. Regards Advisor
Posted on Aug 24, 2007
  • 12 Answers
SOURCE: Ice Maker leaking water in freezer and won't stop making ice
The filter should be before the fridge and should not affect it it sounds like the water valve from the fridge is defective .Other possibility is the icemaker head is defective and needs changing.
Posted on Mar 10, 2008
  • 531 Answers
SOURCE: GE Profile Side By Side Melting Ice but still freezing lower half
you have adefrost problem
Posted on Apr 02, 2009
SOURCE: Ice Maker Freezing Up and Ice not dispensing
Check your ice cube tray to see if it is warped. Mine was. I took the tray off and dipped it into boiling water and remoulded it to the original shape and re-installed it. So far no problems. The tray gets warped because of the ice cube release mechanism. The tray is rotated around until it meets a block on one corner which creates the twisting motion we used to do on manual trays. Over time it tends to warp the tray. Good luck
Posted on Apr 28, 2009
Freezing Water line
Hello
The problem here is your water valve. It does not shut off all the way and allows very slow water flow through the water line. It is so small that it freezes in the supply tube causing a blockage. When your ice maker calls for water the pressure from the blockage pops the line out causing your leak.
You need to replace your water valve. Dual valve at the back of the fridge.."water inlet valve")
Jul 18, 2017 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker stopped making ice
Here is a check list to use to verify ice maker is good or bad or if something else is causing the problem.
1) Has the water filter been changed recently, or does it need to be changed? The filter being old can cause a reduction on water and lower performance of anything else that requires water.
2) Check the temperature in the freezer. Even though things are frozen in there, the ice maker requires that the temperature be at least 10 degrees F to even cycle. Ideal would be around the 0 degree mark.
3) Check the fill tube where water comes into the ice maker. From time to time this will get blocked due to water freezing in the tube itself.
********* If the first three checks all pass, either the water valve is bad and not allowing water to come to the ice maker, or the ice maker itself is not calling for water **********
Depending on the age of the machine it might not be a bad idea to change the water valve and the ice maker together.
May 30, 2012 | Frigidaire Refrigerators
The water dispenser in my refrigerator ice maker is leaking
if you have recently changed your filter, had the water turned off, or disconnected from the ref this is a common problem. you have air in your water line. fill 5-6 large cups of water or until it stops spurting and your drip should go away
Apr 23, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My ice maker quit working when I replaced the water filter.
Your model Maytag comes with an electronic ice maker and if you just recently changed the water filter the water should be dispensed for 2 or 3 minutes or until any air that may be trapped in the lines is removed. If air is sill present in the filter the ice maker opens the water control valve for about 7.5 seconds. If air that is what the ice maker will get until the air is completely purged from the system. If you fill that you have past that point then pour tap water into the ice maker and let freeze. After the water freezes the ice maker should cycle and dump. If not the the ice maker core may need replaced. If yes it dumps then the air may not yet purged or the water control valve for the ice maker side may be defective. This is one of those wait and see repairs. I will send you a link to the copy of the service manual and page 71 begins addressing the ice maker. Thanks, Sea Breeze
Dec 22, 2009 | Maytag MSD2650H Side by Side Refrigerator
Ice maker on side by side refirgerator will not quit making
Hello there
Please try these few tips ok?
  1. It may be turned off. Check the Ice maker shutoff arm located at the top of the ice bin. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, simply lower the wire.
  2. Is there water in the ice cube tray? If not check for water to the water valve. If you have water then it could be either a failed fill valve or ice maker control module is not activating the water valve.
  3. Check for pinched water supply line (behind the fridge)
  4. Do you have an inline water filter? If so, when was it changed last? To test if it is plugged, check for water both before and after the filter system.
  5. Sometimes the water inlet tube that directs water into the ice cube tray freezes over; this can often be thawed out by simply using a hair blow dryer and warming the area (be careful not to overheat the plastics as they can warp or crack). Then adjust the freezer to a slightly warmer setting and make sure water is not constantly dripping from the inlet tube, as it will only freeze over again.
  6. If it continues to drip we may need to replace the water control valve.
  7. The ice maker head assembly may have broken parts. Look to see if the gears are broken.
  8. Check to see if the small plastic arms that rest against the ice rake are broken.
  9. If the ice maker head assembly is modular and you've found broken parts,
Nov 08, 2009 | GE Refrigerators
GE side by side with ice and water in door
This is a problem with my GE side by side also. It only happens occassionally and there doesn't seem to be any fix. I've had GE repair service here more than once. It seems that the insulation in the door is insufficient to keep the water line from freezing up. Small wonder GE is part of this awful financial mess.
Dec 17, 2008 | GE 23.1 Cu. Ft. Side-by-Side Refrigerator...
I have an internal icemaker that does not make ice. PN wr30x0328
The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees. In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Jul 11, 2008 | GE Refrigerators
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Apr 30, 2008 | Whirlpool ED2FHEXN Side by Side...
Water dispenser not working but ice maker does
The water line freezes inside the freezer door. There is now an add-on water line heater you can install to thaw the line.
Mar 01, 2008 | GE 24.6 cu. ft. Side-By-Side Refrigerator...
GE Ice Maker not working.....Water in the door is working......
the fill tube that runs into the back of the icemaker is most likely frozen up in the cabinet. use a blow dryer to warm it up and you should be back in business..
Dec 20, 2007 | Amana ASD 2624 Side by Side Refrigerator
Refrigerators Logo
1,500 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
