FixYa.com
Tags:
Sony KP-51WS500 51 in. Rear Projection Television
Screen slowly turns blue... (by 2 users)
posted by mcanirlin on Jul 26, 2008
Like when a little kid holds thier breath... starts out great when you turn it on and in about 10 minutes the green gun is dark and the screen is all blye. How do I tell if it's the gun or the cicuit behind it? Can I switch the red and green guns just to test it out?
Thanks,
I'm holding my breath now......
Comment by mcanirlin, posted on Jul 27, 2008
This is truly amazing. I got this TV from Craig's list for free because the screen turned blue. Noticed that the color was a little over driver...retrace lines. Found the post on FixYa that told how to get rid of the lines and guess what? Pictures not blue anymore. Seems that if the color is over driven too much, the entire set tuns off. If it's overdriven a little too much it can shut down one of the guns. In my case it was the green gun. So, before you replace a gun, turn all those screws on the bottom row CCW and reset the set. I'll bet my set isn't the only one with this issue. THANK YOU FixYa. I'm going back to watch my TV now.....
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by shannonrenae, posted on Aug 24, 2008
okay same problem here but my screen slowly turned blue and now is constant blue but you can hear what is playing. I called around and no help and I was informed I needed to change the tubes..red and green..only I cant find the parts anywhere and I really REALLY want my tv back before the NFL season is in full swing..btw I am a woman so please speak lamemans terms to me if solution available and yes I also had the squigly lines before the screen starting fading but I tried the flash focus and nothing happened and I cleaned out the back ..help HELP before the season starts.
Best Solution
posted on Aug 12, 2008
FixYa! (100)
mufugaman
Rank:Apprentice Apprentice
Rating: 100%, 1 votes
I had blue lines showing up on my screen, then the other night my screen started to flutter the blue, bright to dim and back. So I followed this link to resolve the blue lines and the blue flutter was resolved as well. Hope this helps.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Projection Televisions problems?
Sony KP-51WS500 51 in. Rear Projection...
screen goes gren
after a couple minutes after i... Answer This...
Red Flash and TV shuts off
I saw a couple threads that you... Answer This...
Stanby light
Hi, TV works well. Good pisture... Answer This...
Concave TV screen
My Sony TV Model # kp-51WS500... Answer This...
your sony KP-51WS500
did you get it working? and... Answer This...
Repair Service
Find Projection TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
