Question about Aiptek A-HD 720P Flash Media Camcorder
Recording using A/V in jack - 18 seconds max allowed
When I record from our PS2, it records funky. First, if you let it record it will stop at 17-24 seconds or so. Then sometimes if I record small bits, it plays back with the audio ok, but the video is in slow motion and off track with the audio. It actually crashed during playback and I had to take out the battery to get it to turn off.
What's the deal? I want to record 30 min or so like it says you can...
Thanks
  • potterland Oct 20, 2008
    i can only record my tv for the xbox 360 for 8 seconds.
    i've used this camera alot and its done the job.
    i've tried to put the quality down, which shouldn't have been the problem(its in HD)
    I've tried new TV OUT cables
    Whats the deal?
  • stebbins Nov 09, 2008
    Sorry I didnt sign in, I posted the "guest" post... :)
Http://www.megaupload.com/?d=C7YSBOKD
firmware update fixes the issue
Posted on Feb 06, 2009
I have found it records TV programs pretty well, except for jerky motion every few seconds, but the video game problem is unique and inconsistent, meaning that with a PS2 it recorded fine a few times but failed almost every time at the 17-18 second mark. AND the tracking is out of whack as stated above. With the Wii, however it is seamless beauty with endless recording so it seems it is unique to the PS2.
I love this site by the way... thanks to all involved in this problem.
Posted on Nov 09, 2008
  • 37 Answers
Well there could be a couple things- A. there is a problem with the camcorder's software, which will need to be fixed by a LONG phone call with Aiptek Support B. You could be using the wrong component cables for your TV C. You could have the quality set TOO high for your TV's (The PS2 is NOT HD) I recommend DVD quality for this
Hope this helped, sincerely- animation508 (youtube username)
Posted on Sep 23, 2008
  • Luc Vincent Nov 06, 2008
    do you have the right type of SD card in? I would reccomend an SDHC card, as opposed to a normal SD card.
How to dub tape to tape
Hi Dale,
You're kind of light on details of the equipment you're going to use - so the best I can do is provide generic instructions. You'll need two devices - one must be able to perform playback for source media and the other for recording or copying duties. Inspect the jacks provided on the rear of both units. Most provide standard RCA type "Phono" jacks for left and right audio channels. Connect a stereo patch cable (with plugs that match the jacks of the playback and recording devices) between the left and right OUTPUT (or "PLAY") jacks on the source device and the left and right INPUT (or "RECORD") jacks on the recording device. Insert the source tape, cd, album, etc. in the device that will playback the original and insert a high quality blank media into the device that will provide recording capabilities. Begin playing the source. Set options such as tape bias, Dolby Noise Reduction, etc. on both source and recording devices to match media in each. Advance the playback source to a point that contain the loudest sections. Set recoding levels by monitoring the VU meters on the recoding device and vary the input adjustment levels so that only the loudest prortions of the program just begin to briefly "flirt" with the 0Db or red zone of the meter. Signals that cause the meter to indicate into this area and beyond begin to overload the amount of information that can be recorded on the blank media and often result in muddy audio quality during playback, later. You should also record the same section repeatedly with differnt options (bias, noise reduction, etc.) to actually hear the difference to determine which sounds best to you. Once levels are set, queue the playback device and start recording. In the case of tape, allow enough recording time to let the leader section of the tape to pass beyond the recording heads for several seconds or more. Once the desired amount of silence has elapsed, play the source program. Allow it to run to completion using both sides in the case of tape and then playback the entire new recording to make sure it recorded without any issues.
Apr 09, 2015 | Televison & Video
My answering machine message is out dated and needs to be changed how do you do it?
Recording your greeting
message
You can record your own greeting
message (max. 2 minutes). If you do not
record a greeting message, a
prerecorded greeting message is used.
1 {GREETING REC}
2 Within 10 seconds, press
{GREETING REC} again.
3 After the base unit beeps, speak
clearly about 20 cm (8 inches) away
from the MIC.
4 To stop recording, press {STOP}.
Feb 11, 2011 | Panasonic KX-TG6021M Cordless Phone
Phillips cdr775/00 how do i record from laptop headphone socket into recorder i n=have tried my usual lead jack to two phonos it says start source when i do no signal comes into recorder analogue in
MANUAL RECORDING FROM COMPUTER HEADPHONE SOCKET.. FIRST RIGHT LEAD REQUIRED YOU NEED STEREO 3.5mm stero jack plug to lef right phono male leads... prepare for manual record place jack in computer headphone socket. check correct socket play track on computer their should be no sound. if sound present in wrong socket... if ok place phono left right into analogue aux inputs on cdr recorder.next make shure you have blank scratch free cd .next press ext(ernal) source repeatedly until the required input is selected i.e digital analogue optical etc..when auto track is on the disk will number automatically.with auto track on it their needs to be 2.7 second gap to rec number change. with the recorder stopped press rec type five times to enter in the manual record standby mode. manual start s to flash and the display shows REC EXT MAN followed by WAIT.after a few seconds press record . play the source track ie on your computer to set record level on cd recorder.. adjust audio card settings or volume control on pc etc .rotate easy jog/enter key until on the record /play level bar all the blue led are alight but not the red( clipping) display shows xx decibel eg 3bd. stop the source material (track on computer get ready to record ii.e to start track again..to start recording set you track going wilst pressing RECORD on the cd recorder, and immediatley the source material playing. the track number and recording time left appear in display . if check input message is displayed check the connections are correct etc .to stop recording press stop on cd recorder . update lights up and arrow goes out. after recording display will show UPDATE FOR SEVERAL SECONDS WRITTING TOC.. IF YOU WANT TO PLAY THIS DISC ON NORMAL CD PLAYERS YOU NEED TO FINALIZE THE TRACK . HOPE THIS HELPS..yammandan.
Aug 19, 2010 | Philips CDR775 2-Disc CD Recorder
How can I digitize cassette tapes using the Marantz PMD670?
Take a set of RCA Jack cords (4 jacks) and on the tape recorders "out" jacks attach one pair and on the PMD 670's "In" Jacks attach the other pair. Set the tape a few seconds before where you want to record , set your levels to where you want them, start the recorder then start recording with the PMD.
You may need to test record a few seconds to make sure the recording is at the level you want it to be. Plug in a set of headphones to the PMD and listen in from time to time to make sure it's recording OK.
There you go.
Best,
Dan
Jul 01, 2010 | Marantz PMD670 Desktop Digital Voice...
What would cause a mic jack on the mother board to stop recording sound all together from one second to the next?
Probably a program change the settings??Check in your control panel,sound devices,in recording tap(or in the taskbar in the volume control go to recording and make sure that the device is writting is the device you use and is not muted or something
Jan 07, 2010 | DFI LanParty NF4 SLI-DR Motherboard
HOW DO YOU BURN A DVD ON A SONY DVD RECORDER RDR
Make sure your Sony input signal is on L1 or L3 (the inputs in back of recorder) or on L2 which is for inputs for cameras(located in front).Once you get a signal, you're where you need to be. Choose your recording mode for recording speed (pull down the flap on the remote control for this button and also the input button).
Choose from between1 hour and six hours. To archive really important stuff, stick with the first 3 speeds. TV recording can be on 3, 4 or 6 hour mode.
Push the record/pause button once. This will put the recorder into the record/pause mode and then it awaits you pushing it again to start recording immediately. Just pushing record will force the machine into a 3 to five second delay before actually recording anything so you might mess up and miss the first few seconds of your input. Suggest you use a dvr-rw or dvd+rw to practice on.
When your recording is done, just push the pause again. It stops recording but allows you to add more on to the first recording without starting a new chapter if you want. Just continue to release the pause button to continue.
If you are satisfied that you are finished, then push the pause button to stop recording. Wait for the info to be written(flashing message on screen). When it stops, you may play the dvd.
Notice- since the dvd has not been FINALIZED, you may only play it back on this unit without finalizing. It will not play on other dvd players unless you finalize it first.
To finalize, look on remote for the TOOL button. Press it once. Now push DISC INFO once. Use arrow keys and enter button on remote for the following. Scroll down to FINALIZE and press enter.
Use arrow keys to scroll to OK. push the ENTER button. Finalizing should take between 30 seconds and 2 minutes.
Warning- if titles or chapters are to typed in, it must be done BEFORE finalizing. Finalizing afterwards cannot be done.
Erasing can be done in part or all if using an RW+ or RW- disc
Dave
azsnoopy1@cox.net
Nov 19, 2009 | Sony RDR-GX300 DVD Recorder
Foot pedal won't work with hands free microphone
The 3750 won't let you control the telephone record jack. The only way you can get a mic to work using the Tel Rec jack is by pressing and holding the 'Tel Rec' button for about 1 second. But this isn't compatible with the hands-free operation.
If you're looking to do hands-free recording, it uses the built-in conference mic. Press and hold the 'Conf Rec' button for about a second and it should start recording. This built-in mic is located on the right-hand side of the machine near the front by the headset jack.
If you want to control the machine via a foot control while in Conference Record mode, you'll have to change the 'Foot Control Dictate' setting in the menu. Here's how:
1) Press and hold the 'Erase' & 'Search' buttons for about 5 seconds until the menu appears.
2) Scroll through the options until you get to 'Foot Control Dictate' and set this to 'Yes'.
3) Press 'Stop' to exit the menu.
4) Press the 'Conf Rec' button to enter record mode.
Now you should be able to control the start/stop of the record function via the foot control.
Hope this helps...
Apr 13, 2009 | Dictaphone 3750 Desktop Cassette...
I can't remember how to record my outgoing message ?
here you go...
message
message (max. 2 minutes and 30
seconds). If you do not record a
greeting message, a prerecorded
1 {MENU}
2 {V}/{^}: “Answering devicei
{OK}
3 {V}/{^}: “Record greetingi
{OK}
4 After the handset beeps, speak
from the microphone.
5 To stop recording, press {OK}.
6 {OFF}
If this helps you solve it, plz rate this fixya. Thank you kindly.
Feb 01, 2009 | Panasonic (KX-TG1032S) Phone
My stiletto records for about 18 minutes then stops
Daylight savings time change a few months ago messed up the timer recording schedule - you must now fix it. Daylight savings time changes will always mess up this recorder. You must reset your recording schedule.
For more info on fixing, go to:
http://shop.sirius.com/edealinv/servlet/ExecMacro?nurl=control/StoreItem.vm&ctl_nbr=2640&siId=1745656&catParentID=7874&scId=7874&oldParentID=&cid=SL100PK1
2 other remote possibilities:
If no signal is present at the time the recording is scheduled to start, the recording will be skipped.
Make sure you have followed all instructions on pp. 55-58
-Tha Mp3 Doctor
Jun 03, 2008 | Sirius STILETTO 100 MP3 Player
Camera stops recording video
When recording movies in the SHQ image quality mode, I am restricted to 15 seconds of recording time per movie. Why?
In SHQ mode, the FE-230 records movies with VGA resolution (640 x 480 pixels) and a frame rate of 30 frames per second. Recording this much data, this quickly, requires a large amount of camera memory and a very quick write time.
Olympus’ Type M+ and Type H xD-Picture Card media are high-speed cards and are able to process this volume of information with no loss in quality. Other commercially available media, including Type M and Standard type xD-Picture Card media, are not able to do so. For this reason, this model limits movie recording in SHQ mode to 15 seconds when using media other than Type M+ or Type H cards. The 15-second restriction guarantees that the camera will be able to process the data properly and produce a smooth, error-free movie during playback.
Keep in mind that there is no restriction on movie recording length, other than the capacity of the storage media, when recording in the HQ (320 x 240 pixels) mode.
I'm not sure if you are recording in SHQ or not. Try switching to HQ (press menu, then select image quality). It solved the problem for me. Btw I got the solution of the Olympus FAQ page on their website.
Nov 25, 2007 | Olympus FE-230 Digital Camera
Aiptek A-HD 720P Flash Media Camcorder Logo
125 people viewed this question
Top Aiptek Video Cameras Experts
tomikles
Level 1 Expert
Larry Stiles
Larry Stiles
Michael Galve
Michael Galve
Are you an Aiptek Video Camera Expert? Answer questions, earn points and help others
