Question about Acer Aspire 3000 Notebook
Acer aspire 3000
How do i remove keyboard ?
  • 1 more comment
  • shadowworks Aug 10, 2008
    I need to replace my keyboard, and its on its way, I also am upgrading to dvd burner and adding ram, so I'm guessing that I'll need to take it apart... Ive had to replace the CMOS battery, nut even then I couldn't get it entierly apart, if you have a diagram or real good instructions email me at shadowworks_2000 at hotmail dot com so I can get it done without trashing the thing.. thanks.
  • nke63 Aug 27, 2008
    I have removed every screw I could find and am still unable to get to the keyboard. There are three screws under the monitor hinge that I can't get to and maybe those are my problem...Any ideas?
  • rschmu Nov 04, 2008
    Ditto....how to get the power cover removed? Replacing the keyboard after that should be easy.
There are 3 screw behind the laptop, on the back of the screen hinges. Remove them then open the laptop, and with your finger nails, lift the power cover closest to the screen, it will then raise and you will be able to remove the keyboard.
Posted on Apr 05, 2009
How do you remove the power cover?
Posted on Aug 27, 2008
Check this guys...
first, take out the 4 screws on the front of monitor...
lay monitor down away from keyboard as far as you can without going too far...
remove the casing from monitor..
remove black cover with the power button stuff...
then you should get to the silver cover...
the silver i think is kinda like snaps i thinik... there are 2 measly screws under the silver plastic I will try to find better directions,,, i didnt know it at the time but i ended up getting the how to with the keyboard.... LOL.. if you need more on this issue or maybe more on this laptop I kinda know know some how toos beings that i replaced a few things and upgraded mine, so i'll do my best to help... shadowworks_2000@hotmail.com ( NO SPAM) subject (help me with acer laptop) or I WILL DELETE EMAIL AND NOT READ IT!!! sorry i dont mess with spam ****... i got better things to do..
Posted on Apr 09, 2009
    Sergeant:
    Champion:
  • 244 Answers
You need to remove the power cover first ( power cover = where you can see power button)
and then you can see screw that hold keyboard, remove the screw and you can remove keyboard
Posted on Jul 26, 2008
    Problem Solver:
  • 11 Answers
Hi Friends,
Problem with
Acer Aspire Notebook Or Laptops? Just visit the sites..
For any Software problem you can visit a link by just Click Here .
For any Hardware problem with this Notebook you can Click Here
Posted on Jul 22, 2010
How can i remove the acer aspire 3000 keyboard
Posted on Apr 17, 2009
SOURCE: Acer Aspire 3000 keyboard failing
thanks alot mate, couldnt figure out why the mousepad worked without the battery by myself. Thx alot
Posted on Nov 18, 2007
  • 244 Answers
SOURCE: acer aspire 5610 keyboard replacement
1. you need to remove the power cover (if you see the power button, that what i mean).
2. after you remove that cover, you will see 2 screw that hold the keyboard. Remove both screws.
3. Remove keyboard and replace it with new keyboard.
Posted on May 08, 2008
  • 244 Answers
SOURCE: Acer Aspire 1640z keyboard removal
I don't have the diagram but i can give you direction.
1. remove the power cover first (where power button is), it might have 3 screw that hold, if there is 3 screw on the power cover, remove it first.
2. after your removed the power cover, you can see the screw that hold keyboard. remove that screw and you can remove the keyboard.
Posted on Aug 04, 2008
SOURCE: Keyboard broken on my Acer Aspire 5520
For the Acer Aspire 5520 I'm working on, (Acer Aspire 5520-5156, mode nol: ICW50)
Remove the three black screws under the battery, not the silver screws.
VERY carefuly pry off the power button cover. It will make 'snapping' sounds and if you where gentle nothing will be broken.
The keyboard has no screws holding it and can be slid toward the screen and very gently pryed out, taking care not to tear the ribbon cable, as mentioned before.
When the keyboard is out the cable can be released by gently pulling the cable lock on the header toward the cable, the thin (black in this case, it's usualy a different color than the white connector) plastic part of the connector I just use my fingernails, one index finger on each end slowly pulling till it releases.
Pull the cable out using the pull tab. You can just pull the flat cable out with the pull tab without releasing the calbe lock but you stil need to release the cable lock to properly put in the new cable, then push the cable lock back tight to the connector.
Posted on Aug 14, 2009
poole72
  • 71 Answers
SOURCE: How do I remove keyboard on acer aspire 5510
Underneath your laptop there should be to screws with a small logo of a keybord remove the screws then gently lift the keybord with caution as there maybe some retaining clips holding it in place, then remove the cable by sliding the retaining clip out,
Posted on Dec 02, 2009
My Acer 5732Z running under windows 7 has a keyboard & mouse prob
First thing to try to uinstall and reinstall the software for your touchpad. Go to Acer and get the latest drivers and or software. Sometimes, just removing the driver and letting windows find it again in device manager is enough to fix it. hopes this helps.
Normally though. keyboard and touchpad are seperate entities. which made me think of the motherboard as that is the only constant between the 2 but, if your touchpad is buggy maybe it is causing issues elsewhere.
Mar 11, 2010 | Acer Aspire 3000 Notebook
Acer Aspire 3000 key jammed on keyboard
Hello !
Remove the key carefully.
With compressed air, clean in and around the area of the key.
If necessary, use Blu-Tack or other adhesive. Put a very small dab and press the key.
Hope this helps.
Sep 19, 2009 | Acer Aspire 3000 Notebook
Acer aspire 3000
HERE is a link to the repair guide for the Acer Aspire 9410. With this, you should be able to find the correct method or removing the original keyboard and replacing it. If you have a replacement from Acer, you should have been given instructions on how to replace it manually.
Dec 20, 2008 | Acer Aspire 9410 Notebook
Acer 3000 series laptop
If you mean that you're manually trying to remove the battery then you will have to remove the keyboard for that. Just did it the other day on a client's notebook of 3000 series. There's one screw holding the dvd drive in place which you will see as soon as you raise the keyboard.
May 14, 2008 | Acer Aspire 3000 Notebook
Acer aspire keboard replace ment
What is your question? Do you want to know how to replace the keyboard or where to find a replacement keyboard?
This disassembly guide might help you out: http://www.eserviceinfo.com/download.php?fileid=16546 but the pictures are pretty small. Essentially you need to remove a few screws from the bottom of the laptop which will let you carefully pry the panel above the keyboard up and off. Then you will see the two screws holding the keyboard in place. After you remove them you will see where the data ribbon from the keyboard connects to the motherboard. This can be removed by carefully popping the small plastic tab up; the ribbon will slide right out. The replacement keyboard can be installed via the same method.
You can find replacement keyboards on ebay: http://search.ebay.com/search/search.dll?from=R40&_trksid=m37&satitle=aspire+3000+keyboard&category0=
Mar 27, 2008 | Acer Aspire 3000 Notebook
Aspire 3000 Keyboard Lag
Try running an Antivirus and Antispyware application.
One of your other programs is interfering. (as it disappeared in safe mode)
Try deleting things out of the Startup in the Start button menu.
Mar 12, 2008 | Acer Aspire 3000 Notebook
Acer Aspire 3000 Notebook Logo
887 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
