Question about Canon PIXMA iP5300 InkJet Photo Printer
Error message 5C20
My printer is new and gives me Error 5C20 message , any solution please,
  • 1 more comment
  • Anonymous Mar 27, 2014
    What does this error code mean?
    makes a loud noise
  • Cynthia Medeiros Apr 21, 2014
    I am having the same problem with my Canon ip3600 - it's making a loud noise, won't print. Just moved it. Any help is appreciated!
Error message 5C20
Posted on Aug 24, 2008
Erorr 5c20 printer canon ip 3600
why canon pixma ip3600 service error 5C20
Nov 22, 2013 | Epson Stylus Pro 3800 InkJet Printer
Ditto with the 5C20 error and symptoms. I have a cleaning sheet, but, I cannot get to the Menu to run the routine, because it goes directly to 5C20 and locks. Question: how can I invoke the Cleaning...
Try this and it may feed the paper after you finish: Most likely this is a print head issue. The print head is what the cartridges sit in inside of the printer. To attempt to resolve it, do the following:
(1) Open the printer and wait for the carriage to slide over
(2) Remove the ink cartridges from the print head.
(3) Use cotton swabs dipped in hot water to thoroughly clean the print head and each ink cartridge.
(4) Repeat this until there is no ink residue coming off on the cotton swab.
(5) Once finished, allow to dry and replace the cartridges
(6) Try to print something now
If that does not work then you have one of two possibilities:
(1) One of the ink cartridges is defective and causing the error
(2) If it's definitely not that, then the print head will need to be replaced.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 11, 2011 | Canon MX7600 Office All-In-One Printer
My canon ip4500 printer has just came up with service error 5c20 what do i do?
This is a pump roller error. Needs a new board.
I have attached link to the Simplified service manual for your printer.
Part numbers included and ALL Epson Service codes for that model.
www.gondack.com.ar/media/useruploads/files/ip4500-ssm.pdf
Jan 26, 2011 | Canon iP4500 Photo Printer
Code d erreur 5c20....l imprimante ne fonctionne plus
Pump roller sensor error or Error Code 5C20
Condition: The pump roller position cannot be detected.
Problems and Solutions:
  • Replace Purge drive system unit
visit this link for more info
http://pcmediks.blogspot.com/2010/11/canon-pixma-error-codes-and-solution.html
Dec 28, 2010 | Canon PIXMA MP620 All-In-One InkJet...
Printer error 5c20 on start up , new out of box
Error 5C20 means the logic board is not able to initialize the printer - most likely because it can't move the rollers and carriage as part of the initialization sequence. This is a serious problem and it is unlikely you can fix it yourself. You should return it for a refund as too many of these printers are having the same problem.
Nov 21, 2010 | Canon Office Equipment & Supplies
ERRO 5C20
To resolve this error we need to reset the Printer.
Please follow these steps to do the same:
1.On the operator panel, press the button. (The display will go blank.)
2. Unplug the power cord and plug it back in after 30 seconds to ensure that the device resets itself.
2.Then press the button.
3.Once the printer has restarted, please try to print a test page.
Error 5C20 means the logic board is faulty - most likely because it can't move the rollers and carriage.
This is a serious problem and in case a power recycle reset procedure does not fix it you will need to get the printer serviced.
Sep 10, 2010 | Canon PIXMA MP980 All-In-One InkJet...
CANON PRINTER MP610 ERROR MESSAGE 5C20
That's a purge drive error, indicates you need a new purge assembly, the part that cleans and prime the printhead, on the right side. It could also have a paper scrap or something blocking it's operation.
Aug 25, 2009 | Canon PIXMA MP610 InkJet Printer
Canon Pixma MP810 Error messages 6A00, 5110, 5C20, 5100
Pixma pro 9000
service error 5110 after paper jam.
BEST QUICKEST WAY TO FIX THE PROBLEM!!!!
DUST BLOWER ALL OVER THE AREA INSIDE
AND TURN IT BACK ON U SHOULD HAVE SOLID
GREEN LIGHT FOR SURE!!!!!!!!
DAMN I CAN'T BELIEVE I BROUGHT THIS SAME PROBLEM
TO SERVICE CENTER THE FIRST TIME!!!
NO MORE WORRIES!!!
Oct 25, 2008 | Canon PIXMA iP5300 InkJet Photo Printer
Canon PIXMA iP5300 InkJet Photo Printer Logo
3,569 people viewed this question
old marine
old marine
