SOURCE: Wine cooler gets too cold (freezes)
Check your thermostat setting, if the setting is ok then something wrong with your thermostat control.
SOURCE: Haier Wine Cooler
Hi LinnieMcAdam,
I'm Harvey the Master Plumber.
Your question is: Where can you find a 10 Watt replacement light bulb for your Haier Wine Cooler?
I usually have success at the hardware store. Start there. Then you can try the store where you bought it or call Haier.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
SOURCE: water seeping out the bottom of my wine cooler
there should be a drain pan that you will periodically remove. Condensate (water) is a normal byproduct of all refrigeration devices. Also look for a drain fitting that you can run to a waste line.
SOURCE: Cuisinart Wine Cooler
If you call (Cuisinart’s service center (800) 726-0190), they will send you a brand new unit for $10.00.
Happy Holidays,
AC Freeborn
SOURCE: uline wine cooler 2075wc doesnt work, light goes on ????
If nothing runs but the light is on then change the thermostat. #2767-1 and you can find a part from a distributor. To find one visit www.u-line.com and under customer service you will see parts locator
