First thing to try is clean the battery cable connections, and make sure they are tight. Sometimes, if they are a little bit loose, or dirty, it won't make good enough connection to turn the starter. If that doesn't solve it, the connection to the starter, or ground to the engine may be loose or dirty, or your ignition switch may need to be replaced. Good luck. I hope this helps you.
