Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
My dyson C07 ANIMAL is making a loud clatter noise when I push the head down. I have removed the sole plate and the brush bar is cracked so I removed it, but I understand the clutch maybe a problem also from reading other people's comments..how can I tell if it's a clutch problem also? Or... could it be just the brush bar being cracked that's causing the loud noise?
  • Dyson Master
  • 1,545 Answers
The noise is likely the clutch if you have a cracked brush bar. If so replace the brush bar, also replace the belts in the clutch or the clutch if the belts are stretched out.
Posted on Sep 13, 2017
SOURCE: Dyson 17 Brush Belt Broken
there is also an updated beater bar that accepts a wider belt, dyson sent it to us for free
Posted on Jul 03, 2008
  • 61 Answers
SOURCE: Dyson Animal DC14 brush will not rotate. Removed
If this model takes a clutch then it is stripped and needs to be replaced.
Posted on Apr 15, 2009
  • 7 Answers
SOURCE: My Dyson Animal 14 beater brush will not turn.
It MAY be a clutch issue. I had a similar problem with my DC07 Animal recently a posted a solution elsewhere on this site, but here's the summary. To reset the clutch on my model, recline the vacuum, turn it on it's side and slowly change the carpet/bare floor knob from one setting to the other about 6 times. This apparently reset the clutch and now it works fine. You may also wish to call DYSON. They're very helpful and walk you through troubleshooting before recommending servicing. Their number is 1-866-693-9766. They'll need your model and serial number (located on bottom of uinit).
Posted on Apr 18, 2009
  • 5 Answers
SOURCE: Replace dyson 07 animal brush roll assembley
The end caps of the brush assembly which contain the bearings are only a push fit onto the spindle (quite tight). Remove these and the brush bar will pass through the drive belt loop. To achieve this the belt has to be stretched slightly so care has to be taken not to over-stretch what might be a belt getting to the end of its life. When refitting the end caps do not forget to aline them properly so they fit into the sole plate recesses correctly.
I cannot see at the moment how to replace the drive belt on the DC 07 without significant dismantling (that will probably be my next job) I do not see the use of the Dyson tool you offered.
Posted on Oct 27, 2009
DysonInfo
  • 107 Answers
SOURCE: Dyson dc14 Animal motor brush replacement
By the time the brushes are shot, so is the armature. You need a motor.
Posted on Nov 30, 2010
Has suction, but why isn't it picking up?
Good evening Amy
You can see the full manual for the DC14 here
https://www.dyson.com/medialibrary/Files/Dyson/Support/downloads/US/Floorcare/manuals/dc14_opmanual_usa2007%20pdf.pdf The troubleshooting section addresses this problem on several fronts, though the executive summary boils down to:
  1. Re-check that there aren't obstructions in the lines.
  2. Make sure that all of those bends and junctions are fully snapped into place (this has been the one that gets me the most with my DC-07 after I clean it)
  3. Make sure that the filters are clean, clean them if necessary, or replace them
  4. Since you mention replacing the brush. make sure the brush is snapped in flush with the soleplate. In my experience, the eccentric assemblies at the end of the brushbar holding it into the head are really easy to get mounted not-quite-right for alignment, leading to the soleplate not closing properly. Take another look to see if one or both of them are mis-aligned.
  5. make sure the vacuum is reclined. Full upright shifts suction to the handle for the accessories.
  6. Make sure that the accessory hose isn't clogged and doesn't have a hole in it. You'll want to stretch it out fully to check the walls for holes.
    I hope this helps!
    Good Luck
    D
Nov 14, 2015 | Dyson DC14 Animal Bagless Upright Cyclonic...
Sounds like the beater bar hits the front plastic makes a loud awful noise
Hi Cathy,
Your DC33's brush control is designed to make a ratcheting sound to warn you if something is jamming the brush bar. You should be able to resolve this by making sure the cleaner head is free of any obstructions, and removing any threads or hair from around the brush bar. For guidance in doing this, please follow the steps shown in our online Support guide:
http://www.dyson.co.uk/support/dc33/dc33-multi-floor/dc33-maintaining-your-dyson-machine/how-to-remove-a-blockage/from-the-brushbar/removing-debris-from-the-brushbar
This should resolve the issue, but if you're still concerned about the machine after following these steps, please give us a call on 0800 298 0298 (UK), or 1-866-693-9766 (US), so we can provide further assistance.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Apr 27, 2012 | Dyson DC33 Animal Bagless Upright Vacuum
The belt on my Dyson is making a terrible loud grinding sound after I removed the brush roller.
The sound is the clutch mechanism. That is a safety feature. It sounds like you have trapped the belt when you reinstalled it. If not, the brush roller bearings may be seized?
Take it apart again, spin the brush roller in your hand. Make sure it is free. When you reassemble it, before you refit the sole plate, turn the brush a few times with your fingers to make sure the belt finds its home on the roller. Only then refit the sole plate. Turn it again when fitted before you run it to make sure the brush is turning freely.
Then, make sure the clutch is engaged, see this article for more on clutches: DC14 clutch and brush roller
Feb 02, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
When i set the floor setting to carpet, it makes a nasty rattling noise. doesn't do it on bare floor setting
There is one major difference between the hard floor setting and the carpet setting - the brushbar doesn't spin on the hard floor setting. Hopefully this is a simple problem - the rattling noise suggests there may be something trapped behind the brush rollers. You can inspect this by removing the sole plate from the vacuum. Doing this may allow any trapped objects to fall out without need for any further inspection:
To remove the sole plate:
1. Lie the dyson on it's side so you can access the underside or sit on a chair, turn the vacuum upside down and hold it between your knees.
2. Using a coin or a large flat-bladed screwdriver undo the two yellow fasteners on either side of the "sole plate" which covers the brush rollers.
3. Pivot the back edge of the sole plate upwards and remove it
Any loose debris can now be easily removed, While the sole plate is removed, it is a good opportunity to inspect the brushes and remove anything else that may be stuck to it.
Replacing the sole plate is the exact reverse of the removal process. Before replacing the sole plate, ensure that the brush bar is correctly and fully inserted.
There are other possible reason for the rattling noise, but your description leads me to believe that this should cure the fault. Inspect the brushbar first and then post back if you need further assistance.
Regards,
BElectric
Dec 15, 2010 | Dyson DC33 Bagged Upright Vacuum
Oct 25, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Very loud click/catching noise - Dyson DC07Allergy
Take the sole plate off the brush bar (with a coin or a screw driver)compartment and check for blockages near the brush bar and make sure the brush bar spins round freely.
Its sounds like the clutch is slipping (it does this to protect it self from burning out when something is stopping the brush bar from turning)
A quick test is when in upright position turn the brush bar knob to off
(usally in drive postion) then try the user position again - the brush bar should not be turning and they should be no noise
Aug 23, 2009 | Dyson DC07 Allergy Blue/Turquoise Bagless...
My dyson D17 is making an incredibly loud noise, like grinding, when the bottom brush rotates.
Remove the bottom cover plate and rotate the brush by hand. Look for things that make noise like stones caught in the brush path, bad brush bearings, bad drive belt.
Aug 02, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Brush bar does not turn & makes a loud noise
You need to clean your roller and replace the clutch assembly that drives the belts. poorly designed vacuum with many flaws.
May 27, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Make terrible noise when you click the lever to lover the back to use
That means that your brush is locking up. Lay the vacuum on its front and tilt the foot back. Remove the sole plate and make sure nothing is blocking brush from spinning. Then make sure that the end caps of the brush are facing up or toward the back of the unit which ever way you look at it. If thats all fine there is something that is jamming your clutch.This is harder to remove and will probably need to be replaced. They are not that expensive as you can probably get it for 60 bucks.
Nov 03, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
My dyson is making a loud horrible noise
Hi.
Check the brush roller can be moved by hand & that it is not snagging on something.
If it is difficult to rotate remove sole plate by turning the 3 plastic screws to unlock position lift plate off & clean brush roller & check you can turn it after this.
If brush roller is free to rotate the chances are the clutch is faulty & will need to be replaced.
Go to this site http://dysonmanuals.llc.nu/
It has manuals that cover clutch replacing on all Dyson models.
Sep 01, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
96 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
