Question about Compaq V700 17" CRT Monitor
Dead Monitor Hi, I bought my parents an HP computer for Christmas and now, only 7 months later, the monitor stopped working. w1907 monitor. I've read some comments on here but don't understand what the solutions are saying. I don't know anything about inverters etc. Can a monitor be fixed or replaced since it's only 7 months old? I think that's an extremely short lifespan for a monitor, especially since it's used only a few times a week for short times. Thank you the monitor is dead
  • sadik_zaki Jul 26, 2008
    the monitor is dead
  • Compaq Master
  • 6,993 Answers
Hello, welcome to Fixya!
Your monitor is having a power fault because it is not switching on. The monitor might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
First, remove the unit's power cord from the wall, wait for about 30mins, then plug it back in. If it doesn't power on, plug it into another outlet, to make sure there electric current entering into the rmonitor.
If plugging into another power outlet doesn't power it on then it confirms that the receiver is having a power fault.
When electric current comes from the power outlet into the monitor, it goes straight into the power supply board which then circulates the current into the unit. So if the monitor doesn't power on, the first thing is to make sure there is power entering into the monitor.
So check the power cord, if it is a 3-pin plug, it must have a fuse in it. check the fuse if it is not blown. if fuse is intact, then power supply board should be checked.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter and continuity tester in order to read the components on the power board. Once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect and solve the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Regards.
Posted on Jan 05, 2012
The monitor is dead
Posted on Jul 26, 2008
I found a tablet pc settings option in my control panel on windows 7 pro and it reports that my hp w1907 can be used with pen input. Is there something I need to install to allow this? It doesn't...
The pen input is not available on the HP W1907 monitor. I have three of them and Win 7 tells me the same thing but there is no firmware in this monitor that supports pen input. There are other models that HP puts out that do and the driver is the same so the option appears in Win 7 by default. Sorry to give bad news. (trust me, I was excited at first followed by the Aw ****!)
Aug 30, 2011 | HP Compaq WF1907 Monitor
Iam using HPw1907 Monitor. THe backlight of the same goes off for every 10 min . What is the solution ?
You can adjust power settings that control monitor. if you using Windows 7 you can modify your display settings in Control Panel / Power Options screen. For additional help you can read this guide.
Mar 20, 2011 | HP w1907 LCD Monitor
My HP W1907 monitor needs a driver update. Told access is denied
yes the monitor bad , which means your lcd lamps gone ....
May 09, 2010 | HP w1907 LCD Monitor
I have an hp w1907 monitor i start up puter and after about 15 miniuts the monitor goes black i turn the monitor off and about 5 minutes later i turn it back on and works fine for about another 15 minutes
You could have a faulty inverter board. The inverter supplies high voltage to the CCFL lamp/s, these lamps are mini fluro tubes approx 1,5mm dia. and the length of the screen.
Check the inverter output/inverter board and you maybe able to get parts from
www.lcdparts.net
Dec 13, 2009 | HP w1907 LCD Monitor
How do you clean the monitor?
You can buy specific kits for cleaning flat panel displays at either your local computer store or most electronic stores that sell accessories for computers. Read the instructions carefully to ensure that you don't spray any fluid onto areas that should not be made wet.
Oct 05, 2009 | HP w1907 LCD Monitor
No Input Signal, Monitor Going to Sleep
if you have twisted od bent the cord to much the wires could have broke inside the cord.
Jul 31, 2009 | HP w1907 LCD Monitor
Hp w1907 - web pages too large for monitor. I
You need to increase the resolution of your desktop.
Goto Display Properties->Settings
Jul 18, 2009 | HP w1907 LCD Monitor
Volume pop up in the middle of my screen
no photos of said window presented? i cant see them?
must be OSD? the monitor brain on screen display (menu)?
even with the DVI cable pulled?
only a monitor stated, w1907, no PC
some monitors have button lock
read the manual ?oops HP deleted it...
it tells you to push the menu key on the monitor for 10 seconds
and it unlocks. (4 buttons right side left button is MENU)
doom?
that power deal sounds super bad, like the power supply is bad.
if the monitor fails by its self not plugged it to a PC
then the monitors is bad.
try a reset on it? ( power off for 1hr, or off then plug in with power button held? or power on with menu held (wild guesses but common practice)
ok found your manual page 4-8 shows menu page advanced
list line in list factory reset.
but if the keys are dead, and power lamp failing
the power supply is no good or worse. worse is always possible.
and expensive
ever see the support page, read the guides
https://support.hp.com/us-en/product/HP-w1907-19-inch-Widescreen-LCD-Monitor/3709665/model/3709666
its over 10 years old now. 2007?
walmart has larger one for $50
cheaper that parts or repair this.... vastly
Jul 27, 2017 | HP w1907 LCD Monitor
Dead Monitor
I do not what type of inverter you have is it true wave? some inverters are cheep as they are not a true waves and they do effect the life of the Tv/Computers, etc. Tv still covered take it back and do not tell them that you connected it to inverter
Jul 25, 2008 | HP Compaq WF1907 Monitor
Compaq V700 17" CRT Monitor Logo
150 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
