Question about Philips Magnavox 9P6034C 60" Rear Projection Television
60 IN WILL NOT WORK WHEN GETS COLD
  • Philips Master
  • 3,459 Answers
This is any easy fix. Goto www.magnavoxhelp.com to get a repair kit. Its a common problem on some of the older Magnavox projection TV sets.
Posted on Jul 31, 2008
My programable thermostat is not working properly. Every time it gets real cold, it stops running and the temp. in the house drops to below 60. Where do I start for a solution ? It's a Lux thermostat.
If it only doesn't work when it get real cold, the problem is probably not the thermostat. Make sure your filters are clean. If a filter gets dirty some furnaces will overheat and cycle the heat on and off, and when it gets real cold, it can't keep up.
Jan 19, 2011 | Heating & Cooling
It will not get cold, everyting turns on, fans-light
you need a new rtc overoad contactor on your units compressor which is located in the rear of the unit,remove the spring wire that secures it to the compressor body and unplug and reverse procedure to install
Jan 17, 2010 | Haier HRT02WNC Compact Refrigerator
This VinoTemp vt 60 just quit working. No
if the evaporator coils are warm, you have a leak and no refrigerant.
Aug 25, 2009 | VinoTemp VT-60 Wine Cooler
Warm in freezer and refrig
On some Amana refrigs , the defrost thermostat has to close before the fan will come on . The coils will get cold and since the bimetal clips onto the coils , it will get cold as they do . When cold enough , bimetal closes and the fan will come on . Are the coils getting cold ? If so , then the compressor is working . You could also have a bad fan motor instead of bimetal . Recheck to see if you hear the fan in freezer now .
Aug 15, 2009 | Amana 23.1 cu. ft. Side-by-Side...
AIR CONDITIONER ONLY BLOWING COLD ON ONE SIDE AFTER DISCONNECTING BATTERY
Turn your AC off. Turn the car off Crank the car turn ac on drivers side to 60 passenger side to 90 press auto wait 1 minute turn AC off (very important) turn car off turn car back on switch driver's side 90 passenger 60 press auto wait one minute turn AC off( very important) turn car off turn car on AC 70 both sides press auto your ac should be blowing cold If not, you have an expensive problem
Aug 25, 2008 | GMC Sierra Cars & Trucks
PHILLIPS 60 IN
Shrinking and expanding or no audio/video is fairly common problem.Goto www.magnavoxhelp.com to see if they have a  repair kit.
Jul 26, 2008 | Philips Magnavox 9P6034C 60" Rear...
No cold air
if unit is more than 5 yrs old dump it!!! most frigidaire models just dont last...that is why they are so cheap...get it???
Jun 09, 2008 | Frigidaire FAH085N1T Air Conditioner
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
24 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
