Our new air conditoner is not cooling our house ac is running no stop for 24 hours
  • 143 Answers
It is either broken or it is the wrong size.
Posted on Jul 26, 2008
My ac window units are not draining water and creating mold in my house
Check the drain tube between the evaporator side to the back of the unit. It may have a packing plug installed. If there is one remove it or clean the drain tube.
Jul 23, 2014 | Frigidaire FRA08PZU1 8,000 btu Window AC...
Outside fan not turning inside fan running
Very impressive!! This button you are referring to is a contactor. When your tstat calls for cooling it sends 24 volts out to the contactor therefore pulling the contactor in completing the circuit for the fan and compressor. Usually this doesn't work when a safety switch is preventing the 24 from getting to the contactor. Either it's not getting a signal from the tstat or one of your safeties are tripping (high or low pressure) or the float switch on your drain line at the air handler is wired in to only stop the condenser from working rather than the tstat. A multimeter would be extremely helpful for you to determine where the voltage is stopping. Check your drain first, I don't suggest your patented rock idea, it's not running because of a safety. Good Luck , let me know!!
Apr 30, 2017 | Ruud UBHC Air Conditioner
Haier air conditioner won't cool the room anymore
i bought the air conditionor new and it will not cool what can i do
Jul 05, 2012 | Haier ESA406K 6,000 btu ECO-Friendly...
MY AC WORKS FOR FOUR HOURS PER DAY AND BARELY COOLS DOWN THE HOUSE, NOT MUCH AIR COMING UP TO THE UPSTAIRS OF THE HOUSE. AFTER 4 HOURS, THE OUTSIDE UNIT SHUTS UP AND NOT MORE COOL AIR COMES IN. BEFORE THIS...
I am not understanding exactly what is happening with your unit. You say it only runs for 4 hours a day and then say that after 4 hours the outside unit shut off. But you don't describe the condition of the outside unit! Is there ice on your outside unit after it runs for four hours or is it so hot that the housing would fry an egg? Since it works for four hours and then stops working, I would guess that ice forms on the condenser grill which tells the thermostat that your air is much colder than it actually is. Then it takes time for the ice to melt off again. Am I close? If so this condition is usually caused by your unit being low on freon making everything work harder. But it could also mean that you have a leak in the system somewhere. But it shouldn't be much of a leak or it wouldn't run for the 4 hours.
I would recommend you charge it to the correct level and then check for leaks.
Aug 03, 2011 | Carrier 38CKC060 Air Conditioner
My air conditoner blows cold for maybe 15 minutes than warm
Are you using a "very powerful" AC to cool off a relatively small space? The AC has a thermostat, if the return air is meeting set point, the compressor would stop. The fan could still be circulating, hence the perception of warm air. What you should do is don't block the ventilation, and direct the cold air toward the ceiling. The cold air will sink (due to higher density) and create better circulation and temperature mixing.
Jul 19, 2011 | Whirlpool Heating & Cooling
Rudd furnace molel robd-150rbja worked good for 5 years now takes 24 hours to raise house temperature from 60 to 70 degrees burner fires properly then fan starts properly after about 5 mineuts of bott...
Get it looked at quick, before your exchangers crack, because the furnace not cooling them down after operation will lead to failure, and the replacement is not cheap, close to the cost of a new unit.
Dec 06, 2008 | Carrier 38CKC042 Air Conditioner
Getting cooler air
if you are desiring to have it 62 degrees in the house, the cool setting needs to be more to like 66 deg and the heat setting needs to be like 58 degrees. that would make it more around 62 degrees in the house.
change the heat setting first to 58 and then change the cool setting to 66. this gives your temperature 62 +/- 4 deg.
Jun 16, 2008 | Computers & Internet
Temp control moves on it's own
Mine was doing the same thing and it was really frustrating! I would come home and it would be 88* inside. I found out that this model air conditoner has had problems with moisture getting in the control panel and shorting it out when it's humid outside. I have the part number if anyone wants it. It cost me about $45 from Sears Parts.
Jun 09, 2008 | Maytag M6Y12F2A Air Conditioner
Heating & Cooling Logo
63 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
