Question about Philips Magnavox 9P6034C 60" Rear Projection Television
PHILLIPS 60 IN
WHEN IT GETS COLD THE SOUND OR NOTHING WIIL WORK UNTIL IT HEATS UP
  • HappySpleen May 11, 2010
    When it heats up dose the picture shrink and expand for a bit?
  • Philips Master
  • 3,459 Answers
Shrinking and expanding or no audio/video is fairly common problem.Goto www.magnavoxhelp.com to see if they have a  repair kit.
Posted on Jul 31, 2008
We have a new a/c and the system has heat strips. For a/c. we have had the thermostat set on AC at 72degrees. Now that it is getting colder and may need some heat in the house, do we switch the...
If your thermostat has an emergency heat setting this means you have a heat pump system.
Yes you need to set the thermostat to heat for heating the house.
The emergency heat setting should never be used unless your outside unit is not functioning.
The emergency heat setting overides the heat pump (the outside unit will not be energized).
The emergency heat setting will run the auxillary heat (heat strips) only.
When the thermostat is set in the heat position the heat pump will run to heat your house.
If the heat pump can't keep up (extreme cold) then then the auxillary heat will kick in to augment the heat pump until it satisfies the thermostat settings. If your room temperature gets 2 degrees below your thermostat setpoint, your auxillary heat will kick on. Example, say you are going to be gone a couple of days and you turn your heat down to 60 degrees. When you return and it is 60 degrees in your house, you turn the thermostat up to 70 degrees. Since you are turning the temperature up 2 degrees or more (10 degrees in this case) from the 60 degree room temperature then the heat pump will come on and the auxillary heat strips. The unit will continue heating like this until the temperature in the house gets to 69 degrees and the heat strips will turn off and the heat pump will continue to run until the 70 degree setpoint is reached.
Hope this helps.
SeagullAC
Sep 15, 2011 | Heating & Cooling
Cold dryer
if the dryer runs normal for the first 15 to 30 minutes you have bad gas coils located on the top of the gas valve,take out the 2 phillips screws,remove the top cover and change out the gas coils.when the coils are failing they will work until they heat up then they stop letting the gas come into the dryer,when they cool down then they will work again.change out the gas coils part number 279834
Mar 27, 2010 | Kenmore 73952 Gas Dryer
Heater only blows cold air untill your at 60 MPH
Sounds like heater core still plugged,and/or has air in system.I have had good luck with back flushing ( rinsing in reverse of normal flow) with a mixture of cascade dish washing detergent and water. This ("new and improved" Dex-cool antifreeze/coolant) sure does gum up and eat certain gaskets. When you have it refilled find a mechanic that has a vacuum operated filler. These are the greatest way to refill with no air pockets. Also could be the temperature blend door being incorrectly opened/shut though I doubt it.Hope this helps and please rate me!!
Jan 18, 2009 | 2002 Ford Taurus
Cold water filling problem
sounds like a bad fill valve or control(timer) check to see if there is sedimant in the filter at the hose where it enters the machine.But i don't think that is the problem.
Nov 03, 2008 | Kenmore 24032\24036 Top Load Washer
Sound but no picture 60in phillips television
I beleive you can get a chip to fix this problem from www.magnavoxhelp.com.
Aug 19, 2008 | Philips Magnavox 9P6034C 60" Rear...
Phillips 60pp935217
I have a phillips HDTV monitor model 60pp935217, i don't get an hd picture but i do have sound. Please help.
Apr 08, 2008 | Philips 60PP9352 60" Rear Projection...
Phillips 60 inch tv
There is nothing you can do to repair the convergence problem it sounds like you have. If it is the older PTV set with crts it will probably cost $200.-$300. for the average repair of this nature.
If it's a DLP model, no convergence in those. Most likely a Light Engine. $500.-$800
Mar 12, 2008 | Televison & Video
SOUND BUT NO PICTURE
try resoldering the vertical output IC. have seen bad solder on that model make the picture tubes blank as a safety feature when vertical deflection drops out.
Mar 12, 2008 | Philips 60PP9202 60" Rear Projection...
60" Phillips Magnavox
You need to re-solder the circuit board that contains the STK convergence modules. They're on the center circuit board attached to an aluminum heat sink that's about 8" long and 6" tall, about dead center in the circuit board. You may be able to recreate the problem (hour glass effect) by gently moving the heat sink (which the modules are connected to). This gives the hour glass effect on the picture and the advanced convergence screen. This is an indication that the modules pins aren't solidly connected (meaning soldered) properly. Remove the circuit board and clean the old solder off & resolder the modules pins to the circuit board reconnected the board and then retest by again pushing on the heat sink. This is a caused by a minimum effort (a.k.a. minimum cost) solder job, probably done in some 3rd world sweat shop. The "factory" job was good enough for 3-4 years but the heat (and these modules do create a lot of heat) and stress created from repeated use eventually takes it's toll, weakens the pin connections and our problem occurs. take the appropriate cautions working around the high voltage of the set & use a non-conduting piece of wood to push the heat sink when we doing tests. Best of luck, hope ya fix it.
Jan 10, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
26 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
