Computers & Internet Logo
Posted on Feb 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Msi notebook cannot access boot menu/bios due to invalid password
Anonymous
Level 3:
  • Master 2,296 Answers
  • Posted on Feb 24, 2011
Anonymous
Master
Level 3:
Answers
2296
Questions
0
Helped
833331
Points
6040
You can reset the BIOS password. To reset the BIOS read the information from this link: http://www.fixya.com/support/r7229632-reset_or_remove_bios_password
I cant reset my laptop password from bios is showing me invalid possword
That's because the password entered must be what the owner set it to be. BIOS passwords are used to prevent a thief from accessing and changing the BIOS settings.
Unblocking msi u270 bios password
The BIOs Cracker, a free or paid program can be found on line. That will allow changes to be made, however, any interruption can render the Bios useless and you may not access the Boot instruction set henceforth.
Unlock bios password on msi u100
If the boot sequence is wrong, then how can you even try and log into XP, what you're saying makes no sense.
You said, (every time I attempt to log in It prompts me to activate xp)
So it's booting to the hard drive, why would you need to change it ??????????????????
Removing the CMOS battery might and I mean might reset BIOS password, but that has nothing to do with XP and activation.
You can't upgrade until you get XP activated.
So you might as well install XP pro.
Do a search on google for a XP crack if you can afford to buy it.
I won't post how to crack it.
1helpful
2answers
Dell inspiron mini 10 bios password
Step 1:
BIOS is the first function run by a computer when turned on. It is known as "Boot Firmware," and it checks and initializes other components in your computer, such as your video chip, hard disk or sound card. Because this is the initial process in a computer, it can be troublesome for users who forget their BIOS password and need to access the BIOS. There are several main strategies to attempt when trying to bypass a BIOS password, including accessing the hard disk (which should contain the BIOS password), trying backdoor BIOS passwords (backdoor passwords are generic passwords created by manufacturers in case the user password is lost or forgotten), and flashing the BIOS (flashing is the process of overwriting the original data with new data).
Enter the CMOS start-up menu when you turn on the machine by pressing DEL, F2, or CTRL + ALT + DEL during the boot sequence. Go to STANDARD CMOS SETUP. Find control options for the hard disk. Change both TYPE and MODE to: AUTO. Reboot the system. You will now have access to the hard disk. From this menu, you should be able to find basic system passwords, including the BIOS password. b> Trying Standard Backdoor Passwords For AWARD BIOS, try the following passwords: "AWARD SW, AWARD_SW, Award SW, AWARD PW, _award, awkward, J64, j256, j262, j332, j322, 01322222, 589589, 589721, 595595, 598598, HLT, SER, SKY_FOX, aLLy, aLLY, Condo, CONCAT, TTPTHA, aPAf, HLT, KDD, ZBAAACA, ZAAADA, ZJAAADC, djonet." For AMI BIOS, try the following passwords: "AMI, A.M.I., AMI SW, AMI_SW, BIOS, PASSWORD, HEWITT RAND, Oder." For all other types of BIOSes, try the following passwords: "LKWPETER, lkwpeter, BIOSTAR, biostar, BIOSSTAR, biosstar, ALFAROME, Syxz, Wodj." b> Flashing the BIOS in Software Access MS DOS and type "DEBUG" at the command prompt. This will bring up the DEBUG menu. Type the following code for AMI/AWARD BIOS (note: the Os are the letter "oh," not the numeral "Zero"):
"O 70 17
O 71 17
Q" Type the following code for Phoenix BIOS (note: the Os are the letter "oh," not the numeral "Zero"):
"O 70 FF
O 71 17
Q" If the previous steps yield no results, try the following code:
"O 70 2E
O 71 FF
Q"
Enter password when turned on msi notebook
There are many password options on computers.Windows PasswordDisk Encryption passwordHDD password (Set in BIOS)BIOS config password (Set in BIOS)Boot password (Set in BIOS)
If you have your boot order to boot to CD/DVD before HDD then you can download the Hiren Boot CD, burn it to disc and use one of the BIOS password wipers available.
Alternate method, some laptops will be easier than others. You can open the laptop up and remove the CMOS battery for about 30 seconds to reset all BIOS settings to defaults. The battery will look like a watch battery but about the size of a quarter. or a round disc with a couple wires coming out. Google "CMOS battery for images" Start by openingn the back panels and you may get lucky and have easy access to the battery or you may need to remove either the front or rear body completely.
1helpful
Dell Ispriron E1505 has a display message, invalid configuration information Please run setup program but won't go into setup. Machine goes to preparing setup menu and then screen goes grey and machine...
Try removing both memory sticks and then booting up with just one installed. The bios should notice a shift in the amount of memory and prompt you to enter the bios.
Let me know if that works.
Acer Aspire One has Hard drive Password frozen
There should not be a password set in the BIOS unless you set it up with one. You can clear the BIOS to BRAND NEW state. Acer can guide you through this if it is under warranty. If it is not, write back and I will help you do this.
3helpful
2answers
Grey screen requiring admin password / how do I short the eeprom?
This removes bios password from any Dell machine. unrar it and Burn the Boot CD, and then Boot to it.
http://www.4shared.com/file/82179383/4262ad3d/DELL_Bios_Pass_Killer_2008_By_Virility.html
Password: www.dl4all.com
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
