Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
**** tv ghosting red, blue, green. Red, blue green lines at top of screen
  • 1 more comment
  • Anonymous Jul 26, 2008
    While watching the TV it shut off for 30 secondes when it came back on the color was off, words on the screen showed ghost all three colors
    havent done anything to correct yet
    may try adjusting color tube alignment will post results.
  • matthoward Jul 27, 2008
    i have the same problem please help!
  • jsandlin Jul 30, 2008
    After watching the TV for about a half an hour the TV shut off and back on again. After it came back on the three colors were way off and it looks like maybe a verticle problem because the picture is bowed inward in the middle of the picture (top and bottom).
    Genius:
  • 1,030 Answers
This is an indication of convergence failure. on this set first question i need to ask is IN you setup menu do you have the convergence option. if not this is an indication of a special fuse that has failed. if not it can be more.
Posted on Jul 29, 2008
I have a projection tv that the pictures ghost and the red and green and blue do not line up on the screen. There is allso lines across the top of the screen and are red,blue,green. Looking at the screen...
You have a convergence problem. I have a tip which explains what this is, how to repair it and where to get the parts at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics . Let me know if this is not the problem or you need more assistance.
Thanks for using FixYa and for the generous rating.
hardrocko
Jun 13, 2010 | RCA HD52W59 HDTV Projection Television
Color is distorted. Green, red, and blue ghosts
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Jul 15, 2009 | RCA P52950 52" Rear Projection Television
Red and blue ghosting,
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 12, 2009 | LG RU-52SZ51D 52" Rear Projection...
Watching TV and top 1/3 screen ghosted by colors
on this type of tv each gun is controled by hor.and ver. chip together. it is on the board that controls the convergence of the tv. some manufactors have recalls on problems like this. i dont know if this one does but it may. you can check with mitsub. i do know that this part is about 250.00
Jan 02, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Green cruve line
Good Day;
Suspect Convergence IC's STK4274, part Number 2003191. Replace all three IK04(red), IK05(green), IK06(blue).
Good Luck, big IRISH.
Aug 30, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
Ghosting in red ,blue & green
Sounds like an allinment problem with the color projection you can allin yourself via small screws on color tubes in rear. but be careful as tv needs to be on to do it.
Jul 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Convergence Problem RCA HD52W59
you need to test all cables then make shure it is not your tv.
Jun 20, 2008 | RCA HD52W59 HDTV Projection Television
Blue, red and green ghosting, curves in picture
convergance amp ic bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 30, 2007 | Mitsubishi VS-45609 TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
120 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
