Question about Philips Televison & Video
I have a PHILIPS MAGNAVOX N0270UD, i watched a video Cassette in the VCR player all the way to the end. my TV then shut off automatically I tried turning my TV back on and it stayed on and worked perfectly for about 5-10 seconds and makes a noise that sounds like it is trying to eject. so, Basically i cant use my tv and was wondering if i have to push something for it to work. It is a pretty old tv. Thank you.
I figured it out. you have to turn it on and keep pressing eject and lift the tape UP 5 times.
Posted on Jul 27, 2008
My VCR/DVD combo wont play a VHS tape when inserted. Each time I insert a VHS tape, it shoots it right back out and sometimes unravels the tape around the apparatuses inside the VCR. It won't reco
the tape coming back out and unravels the tape means the loading mechanism is the problem----when a tape goes in it loads the tape down, then it pulls the tape out of the cassette and puts it up against the drum with the video heads-----many of these are belt driven and a bad belt or belts will cause this----it is called the loading and or transport mechanism.......when it fails the arms come back but the tape does not get rewound back into the cassette so it mangles it when the cassette door on the tape closes----most likely a belt or the drive idler which also rewinds and fast forwards the tape.
Oct 16, 2012 | Philips Magnavox DVD/VCR Dual Player
Power goes off when a cassette is inserted. Tried cleaning heads but it won't even run that. When power is turned back on the cassette is immediately ejected.
Good day!!!
Most common problems
  • VCR refuses to FF or REW and shuts off.
  • VCR shuts off entering PLAY or REC or at random during PLAY or REC.
  • VCR eats tapes.
  • VCR doesn't accept tapes or ejects them without cause.
  • Sound is wavery, fluctuating, or muddy.
The cause for all of these is very often a bad idler tire or other dirty, worn, or tired rubber parts
Sep 12, 2011 | Philips Magnavox DVD/VCR Dual Player
Looking for user manual for philips magnavox tv. 9P6044 C104, 3911Q1716. Trying to find out how to hook up my VCR to this tv. It has s viedo, video, L audio & R audio holes on front side of tv. I want...
Barb..be sure you run a TV signal through the VCR first. And then a coaxial from the VCR to the TV. This is the easiest solution for now. And set the vcr to tv/video {channel your movie is on}hit record and hit tv/video and watch your tv for another movie!
Feb 06, 2010 | Philips 9P6044C 60" Rear Projection...
The VCR cassette shuts off the unit Even if you want to watch DVD The only solution is to begin the tape then stop so it wont shut off the unit....Then watch a DVD
Fixing this problem should be a simple solution.
The instructions should have a factory reset included for when the product malfunctions.
This should not be a pay per fix item.
Don't you think so
Kenny Krahwinkel
Kenk@insightbb.com
Dec 25, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Magnavox DV220MW won't record.
You need to plug a red, white, and yellow cord from the red, white, and yellow OUT of your cable or satellite box into the red, white, and yellow labelled VCR IN/LINE 1 on the Philips. To view what you are trying to record, make sure there is another red, white, and yellow cable plugged from the DVD/VCR OUT of the Philips to your television. Make sure the television is on the appropriate source channel (AUX 1, AUX 2, VIDEO 1, VIDEO 2, etc). Then press the VCR button on the Philips. You should now see your cable or sat channel (as long as it's not an HD Satellite box) on the television screen. Press record, and you are on your way. Good luck!
-Tha Mp3 Doctor
Dec 28, 2008 | Philips Magnavox DVD/VCR Dual Player
VHS picture won't work but DVD is fine
VHS part of your machine got video head dirty / clogged. use good quality VHS head cleaning cassette to see picture again.
Sep 30, 2008 | Philips Magnavox DVD/VCR Dual Player
Dvd/cd player Video Cassette player
try cleaning your video head, use a VHS tape cleaner.. use a wet type cleaner
May 04, 2008 | Philips Magnavox DVD/VCR Dual Player
My vcr won't play back
I have a Magnavox zv457mg9 DVD&VCR combo ,and the vcr records for a short period(10minutes) and then cuts off. This happens each time I try to record on the VCR. Any suggestions??
Feb 26, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Televison & Video Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
