Question about Intel Desktop Board D850GB Motherboard
D850GB power problem
I have problem with D850GB motherboard. When I connect the power, the fans in the SMPS, AGP card, and all drives are powering. But the Motherboard and processor are not functioning. Just all fans and drives are running. Front power on switch have no use. Also no beeps nothing even after removing all boards and drives. When I remove the processor, then the symptom is not occuring.
  • 2 more comments
  • anishpsla Jul 27, 2008
    There is no screen. As I say the Mb doesn't powerup. But the fan in AGP card and all drives are working. But the fan in processor is not working. All are happening when I put the plug into power even without I press the switch for powering up.
    P4 1.4Ghz.
    Please help. I urgently need help from experts in this case.
  • Anonymous Oct 02, 2008
    I have problem with D850GB motherboard. When I connect the power, all the fans in the SMPS, AGP card, and all drives are powering. But the Motherboard is not functioning. Just all fans and drives are running. Front power on switch is lighting. Also no beeps nothing even after removing all boards and drives. There is no screen. As I say the Mb doesn't powerup. But the fan in AGP card and all drives are working. and the fan in processor is working also.
  • David
    David May 11, 2010
    does it bring up the booting screen
  • Madhav Suresh May 11, 2010
    What processor are you using?
I have this same problem also. I will add that the computer does light the cdrom light , the drive is spinning, the key board light and the floppy light., when first started up, nothing is going to the moniter to see whats going on!
Posted on Feb 19, 2010
  • 99 Answers
The reason that your AGP card fans are on and your drives are on is simple because those devices have power.
If the fan on the processor isn't working, then look for the wire that rut ns out of the fan and into the motherboard. Make sure that's plugged in. If it's not, then plug it in, but if it isn't this most likely means that your Heat Sink/Fan is broken. I woulnd't start your computer if the fan isn't working because your processor might overheat. One thing, if it doesn't beep, that means that it's not posting, which means start up tests are failing. Right now it seems like your processer is the problem right now, but I would take it to a repair center just to be sure.
Posted on Jul 27, 2008
Fist sorry for bad english i will try my best ASUS P4P800-VM Motherboard not have video output Singal the agp card that i used dont start fan and make sound so i think it broken or is it a...
Hello
Try using the onboard video chip to run your graphics.This will tell you if the agp card is bad or not.
Remove agp card first.
Also if there is another power supply for agp card fan, try using it.
I have used circut board cleaner on vid cards to get the fan working again with sucsess.
A few ideas.
Sep 18, 2011 | ASUS P4P800-VM Motherboard
I have an Intel D850GB board, could I add a PCI SATA port card, to use a larger HDD, sau 1TB?
yes.
but see if your psu(power supply unit) have a sata power cord. on that case you can buy a converter.
Jul 17, 2011 | Intel Desktop Board D850GB Motherboard
Fan stops working and overheats and shuts down
Hello, its seems the fan on your card is faulty, because of this it your card overheats and then has to shut down to prevent damage to your computer. You should get it replaced.
Thanks for sharing
Jul 05, 2011 | ATI RADEON X1650 Graphic Card
Dont know what type of power supply to buy and if theres an agp vga card that can fit to this motherboard
you never need to buy any power supply for using an AGP card... you can still continue to use the same SMPS... the SMPS may sometimes get short-out if it is unable to withstand the AGP card... in such case you can go for a 500W SMPS, that should help...
Jan 15, 2011 | Computers & Internet
I just bought a used (or refurbished) MSI 845GE MAX MOTHERBOARD (478 pin, etc) and plugged in my Radeon 9550XL AGP 8x (4x compatible) card, (2) 512MB Sticks of Mushkin DDR2 (PC3200) RAM, Random IED HD, DVD...
Did you try another graphics card? If this motherboard does not have onboard graphics then try another card. AGP slots go bad sometimes too. I've had that happen.
Sep 18, 2009 | MSI 845GE Max-L Motherboard
Upgrade to an AGP Graphics card
Hi hes61, have you ever been to TigrerDirect? Here is an AGP 8x 1.5v card.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1892411&CatId=318
& this card
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4297004&CatId=318
Here is the hole page of AGP cards from TigerDirect.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=318&name=AGP&
The 3.0volt AGP cards are much older. All these voltages refer to the AGP slot. Many AGP cards support the 1.5v AGP slot & some AGP cards may need more power. The AGP cards that need more power to run will have a power port. Some use a power port just like a floppy disk drive & others will use a standard 4-pin power plug just like a hard disk drive. It varies between cards & some may not need the extra power.
Good luck hes61!
Thank you for using fixa.
Mike
Jan 03, 2009 | Intel Desktop Board D875PBZ (BOXD875PBZLK)...
Graphic card problem
Hi BIOS21, I know this much. I know you're motherboard can not use a PCI-Express video card. You're board can not support SLI. I know from looking & reading the manual for the MSI KM4-L you're board supports an AGP video card. I also know some AGP video cards need extra power for them to function. This varies from card to card. You did find an open power port on you're AGP NVIDA 6600 256MG 128bit card. So plug in the power cord. Every AGP card receives power from the AGP port. Enough to run the fan. Depending on the card it may also need more power provided by the system to function. This is you're case. The power connector would not be on the card if it was not needed. Other AGP cards use the same power cord as a floppy drive. (Just so you know).
Mike
Jun 11, 2008 | MSI KM4M-L Motherboard
Beep: 6 seconds on, 3 seconds off
Pull all the cards out. Put in the CPU and fan, just one memory chip, the video card and the hard drive. Plug in just the power supply and the powerbutton switch to motherboard. Don't connect anything but the monitor, mouse and keyboard. If you still get beeps, try another memory chip (just one). I don't know the beep codes for your motherboard so we have to do this one step at a time.
Jun 30, 2007 | FIC VC19 Motherboard
Intel Desktop Board D850GB Motherboard Logo
134 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
