Question about Hitachi 43UWX10B 43" Rear Projection Television
C50-F550P My C50-F550P does not come on. The stand by light stays. When I press the power on the green light comes in for about 5 seconds the it goes back to stand by (red light on). The screen never comes on. What could be the problem?
  • 1153 Answers
SOURCE: hitachi 60'' rear projection wont power on
read ctechnicians.com
Posted on Dec 22, 2007
ctf1800
  • 4402 Answers
SOURCE: Hitachi, Projection Color TV,C43-F550,C43-F550p,C50-F550p
what do you mean when you say resistors look like they were dry??
did you try fixing the wires? i would do that first and see if anything else is bad.
Posted on Jan 07, 2008
  • 8 Answers
SOURCE: will not stay on
FIXED IT!!!
So if you have a blinking red protection LED:
Turned out the pico-fuse for the -23V had 130 ohms resistance. Initial continuity test feature on my meter indicated it was good since anything under 200 ohms is continuity. All of this after many hours of frustration... and not understanding why all secondary voltages on the power transformer were at 50% for the 2-3 seconds of power up before shutting down.
The "leaky" pico-fuse turned into resistor allowed enough power to illuminate -23V LED despite voltage being 1/2.
Replaced with new pico-fuse to get true -23V. All other output voltages followed suit and TV is working perfectly.
Don't trust the green LEDs. Measure all voltages and be sure to verify 1 ohm or less for every pico-fuse.
I don't understand how a faulty -23V rail would cause this problem. Feedback is from the +31V rail which powers standby 12V safety regulator, 9v and 5v switched regulators.
Anyways it works now.
Posted on Nov 10, 2008
  • 55 Answers
SOURCE: Is the Hitachi 50
The model is high def compatible, however this set has been made for more than one year. Some of the other yr models might not be depending on the set.
Posted on Apr 16, 2010
  • 8457 Answers
SOURCE: No sound/picture and red power light always on (Hitachi 43FDX15B)
When u turn the tv on,u hear alot of clicking?That mean the Ballast that help the projection bulb to work is dead.Change the Ballast,might as well change the bulb too.U don't know what is the condition of the projection bulb in.
Posted on May 29, 2010
We have a 2007 Sony Bravia 46" KDL-46VL130. There is not sound or picture. When we power it on the green light comes on blinking once and then the red light blinking once and then the green light stays on....
Does the front light stays green ? Or goes back to red ? The back-light going on/off maybe the problem, but it shoul return with a red blinking led (4 times ?) and if so it can be a power inverter problem.
Oct 09, 2013 | Sony Bravia KDL-46VL130 TV
I am attempting to instal a Canon iP4700. Step 3 in the instruction booklet states 'Make sure the Power lamp lights green' After connecting to mains and pressing power button the green light comes on for a...
First try taking the inks out and the printhead and see if power stays on. If so you need a new printhead. the part number is on the side. If not, sounds like a bad power supply.
Nov 06, 2009 | Office Equipment & Supplies
Delll Inspiron 2200 Laptop does not power on
You have all the simpthoms of an overheating laptop.
For starters, get a vacuum and **** all the dirt from the fan or fans on the back/ bottom of your laptop.
Then turn on your laptop. It should stay longer than 5 seconds.
If this solves your problem, then you are lucky.
If not, you'll need to have your laptop serviced, and clean the heat sink, and have reapplied the heat transfer compund on the processor.
Not a big deal, and not that expensive either.
If this answer helps, please don't forget to rate.
Jun 22, 2009 | Dell Inspiron 2200 Notebook
I have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray...
same equql problem....?????
Can you help?
i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. Can you help? thanks thanks
Dec 21, 2008 | Televison & Video
Won't come on
hy i got a toshiba 42" LCD tv ,when i press the power boton
iget the red light,& it stay that way ontil i pressthe power back off
thanks for any help
Jun 26, 2008 | Toshiba 62HM95 62" HDTV
My Sony comes on then both sound and picture goes black.
After being on a little while, the screen goes black (no audio as well) for 20 to 30 seconds. Green light stays on. Then, picture comes back on and takes a couple of seconds to get up to full brightness. About 5 seconds or so after the video comes back, the audio returns.
Until this morning, has only happened a couple of times a day, now happening more often. About 3 times in last 20 minutes.
KDF-E55A20 is about 3 years old.
May 03, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Feb 10, 2008 | NEC VT460 Multimedia Projector
Jan 07, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi 43UWX10B 43" Rear Projection Television Logo
35 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
