Refrigerators Logo
Posted on Feb 20, 2011
We have a 18.2 cu ft. top freezer that is about 3 years old. The problem is the freezer doesn't get cold enough to freeze ice cream but the ice maker/ice works properly. Sometimes,, (this is my opinion) it sounds like the refrigerator runs and then goes into a "resting" mode...and then starts again. The temp on both the freezer and refrig is on as cold as they can go. Thanks for your help.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Feb 20, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
10
Questions
0
Helped
2317
Points
26
Have you checked and cleaned the condenser?
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
What setting do I use to make the freezer freeze food
When you are freezing something, set your freezer on its highest setting. However, if you are going to leave your freezer empty for a long time, you should change the setting to a lower one. Here's a great tip for ice cream: place a tub of ice cream in a ziplock bag before putting it in the freezer; it prevents freezer burn. You know when your ice cream gets so cold, it's hard to scoop out? Doing this stops that, it's keeps the ice cream just soft enough for easy scooping!
A 10 year old kenmore bottom freezer will not freeze ice-cream
have a taken off the kick plate at the bottom of the unit and cleaned the dust,it is something that should be done at least 2 timesa year
The ice cream gets to hard and we have to take the big cartons out for 2 hrs before we can scoop it. (How can we bring the tempreture up about 10 or 15 deg.?)We can't find any controls on it. We have no...
Hi, I think you have tell wrong model . Please try find out the temperature controller. Your freezer should able to adjust temperature from 0 - 18 Deg. F
Chest freezer of caravell has 2 model i.e :
1. Caravell SST-5213.7 cu ft Chest Freezer With Solid Sliding Doors
  • Durable white powder coated, baked on enamel finish
  • Solid sliding top doors
  • Cord and plug included
  • Self-contained refrigeration system
  • Temp. range 0 to -18 degrees F
  • 13.7 cu ft capacity
  • Heavy duty casters included
  • Dual drain plugs for easy cleaning
  • Environmentally friendly CFC-free R-134a refrigerant and insulation
  • 115V, 4.5 Amps
  • 51 1/2"W X 25 3/4"D x 34 3/4"H
  • One year parts, 90 days labor warranty plus 3 year compressor warranty
  • & 2. Caravell GST-5213.7 cu ft Chest Freezer With Glass Sliding Doors
  • 115V, 4.5 Amps
  • Regards, jay
    Freezer not cold enough
    check to see if the coilf has a full frost pattern
    Loading
    You need to remember heat rises and cold air falls. The best way to load a freezer is to put meats on the bottom. They take alot longer to freeze and thaw and can save your stock if you have a power failure. Keep non-critical things like ice cream, ice, and other thing towards the top for quicker access.
    2answers
    Frigidaire twin freezer not working
    Check the freezer back wall for snow or frost.If it's there you have a defrost problem.
    Icemaker quit working
    Hello.
    First of all you need make sure that your freezer is freezing enough. Sometimes everything will seem to be freezing ok, but it won’t be cold enough to make the icemaker work. The best way is to squeeze your ice cream, if you have any that is.
    Then you need to make sure that the ice level sensing arm is in the down/on position.
    If all of this checks out ok, then you need to make sure that nobody turned off the water supply that is sometimes located under the kitchen sink. Also make sure that the ice bucket is positioned properly so as to trigger the ice bucket sensing switch.
    If all of this checks out ok, let me know and I can guide you through an icemaker diagnosis by forcing it into a harvest mode.
    Top Frigidaire Refrigerators Experts
    Mike Cairns
    Mike Cairns
    ZJ Limited
    ZJ Limited
    john h
    Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
