Question about Electrical Supplies
Ryobi electic weed wacker
Hello
my weed wacker switch is bad. It is a FA3-4 and I can not find one to replace it. I know this switch is also used in angle grinders but do not know what makes or models.
Call Ryboi at 1-800-525-2579. Their part # is Ut41002A-36
Posted on Aug 19, 2008
Why is my ryobi 18 volt trimmer smoking? I have had this 2.5 years and using it on lawn edges only.
The motor is failing. Most likely the brushes have failed, but this is all sealed and they cannot be replaced alone.
Jun 10, 2014 | Ryobi 18 Volt 18v Cordless String Trimmer...
Removing the clutch from my ryobi weed wacker to replace/repair the recoil spring
remove spark plug put a piece of rope in hole to stop piston from moving there is a torx screw in center of clutch bell where drive shaft would go re move screw to remove bell use large channel locks or brass hammer to remove clutch assm still with rope in spark plug hole hope this helps
Aug 09, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Have a Ryobi weed wacker 725r 31cc click link Trimmer Plus. No more line-can't figure out how to remove bottom to replace the line or what kind of line to replace with. Deceased husband lost directions...
i also have a ryobi weed wacker. if it is the same. you don"t have to remove the button. line up the 2 arrows one on wheel with bumpy edges and one by the button. you should see 2 holes feed a 2-3 foot piece of line into the hole the line comes out of for cutting and it should come out of a curved holw on the bottom by the button .tuck the end into a small round hole . pull line tight (tug on the section that you cut with). wind the string by turn the ring around the button. til desired length. if this doesn't work. google you model # and look for a manual (manual for ryobi weed wacker model # ------------.)
Jun 09, 2010 | Garden
How do I restring my Ryobi weed wacker I do not know which end of the string to start with?
Start in the center ,snap the center in place. than put the ends out through the holes.
Jul 10, 2009 | Ryobi Garden
Replace pull cord on ryobi model cs30 weed wacker
Good fix, mrfixit-jerr! Also, if you remove the rear cover (4 screws) you can stabilize the crankshaft by inserting a screwdriver between the lobe of the shaft and the counterweight.
Apr 03, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
How do you put the weed wacker "string" in mine keeps flying out when I rev it up to weed wack
You need to give close attenttion to the string wrap" arrows" or guides and see if there are holes the size of the string your using is correct size to fit into these "grip holes inside the casing.
Please rate
tk u
JJ
Mar 17, 2009 | Ryobi Garden
Electrical Supplies Logo
385 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
