SOURCE: Samsung DLP HL-R4266W..no sound or picture. TV is completely dead
Assuming the noise is a high-pitched whine, then yes, it is the color wheel. If the color wheel goes out, the TV will turn on for a while, then turn off when it can't establish color wheel sync. The color wheel has to be in sync with the mirrors on the DLP, so if sync can't be established, the TV turns off.
You can order a new color wheel from Sears or partstore.com (among other places) and replace it yourself, if you are so inclined.
SOURCE: loud popping on jvc av56wp74
if the noise is from inside the tv in the back,the high voltage transformer that feeds the anode for the rgb tubes,28000volts probably is arcing.
SOURCE: HL-R5656W
Wait until you get the new bulb to determine that. The old bulb is probably arching as it tries to start.90% of the time the new bulb will do the trick.
Testimonial: "A quick answer back, with good insight. "
SOURCE: Samsung HLR5078W pop sound followed by a loud buzz then shut down
Your lamp burst. This model uses a lamp housing which does not have a filter screen on it. When the lamp bursts, hot pieces of glass and mercury (very toxic) drop straight down into the cooling fan below it. Although FixYa.com (implies I'm suppose to tell you how to fix it) I am going to tell you to call a servicer and have them clean that mess out of there. It's a health issue, I don't want someone unknowingly exposed to mercury on my watch. Let the servicer know what he is getting into. I hope this helps.
SOURCE: TV made a big popping sound, and then a crackling
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php That crackling sound could be of the color wheel:The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is BP9601073A you can find original here:http://www.discount-merchant.com/Samsung-BP96-01073A-lamp-p/samsung-bp96-01073a-lamp-oem.htm?Click=48173 .Have a blessed one!
