DUAL CD CASE
I HAVE BEEN LOOKING FOR A CD CASE THAT CAN HOLD TWO DISK. DO U OR DO U KNOW OF ANYONE WHO CARRIES A DUAL CD CASE?
  • MARYSOLGOT Jul 26, 2008
  • 163 Answers
I get all my stuff from http://supermediastore.com/. I buy in bulk but shipping is usually free.
MM85
Posted on Jul 26, 2008
RCA am-fm steroe radio / dual cassette recorder & compact disc player model rp-9518A. when I try to play a disk it stops and then restarts again at all 5 stations need to know what may be the cause...
I assume that the problem occurs on the cd player. If this problem occurs only at this cd it's a disk problem. If it occurs on various disks try using a cd cleaner set, a wet one is better. Follow the instructions on the set. The main idea is to put one drip of the included liquid at the set (usually isopropyl alcohol) at a specific place (like small brush) on the disk surface and play this disk. This way the "brush" will clean up the laser lens and after that the cd player will be able to read the disks. BE CAREFULL not to put too much liquid on the "brush". In case you can, use a Q-tip with isopropyl alcohol to clean up the cd lens manually. In case this doesn’t solve your problem, the cd player needs laser lens replacement by a technician.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 07, 2010 | Audio Players & Recorders
I had vista and was installing windows 7 and got to the network part of the install and the system went to resart and it went to a black screen with a fashing curser and now i can not access anything on my...
guess u were trying to install Win7 over Vista...it does not work that way....Win7 need to be a clean install...that is...it must be installed in a new partition after doing a full low level format....so you will have dual boot at start up...and u chose what u want vista or Win7 to work with for that specific session....
Dual boot helps in many ways...
1 - it helps file management better
2 - it helps to boot from one OS in case the other gives trouble
3 - virus attack are removed from either OS
etc etc
the best way to getback you system is to
1 download KILLDISK (DOS) utility program, get the DOS version
2 copy it on to a CD
3 get hold of a Win98 CD (bootable)
4 boot from Win98 cd, dont chose to install Win98,
5 press ESC and let Win98 quit installing, it will lead to a drive letter of you CDROM (say D or E as the case may be)
6 insert the CD that has the KILLDISK DOS utility
7 Run the program by typing KILLDISK at the CD drive letter prompt.
8 Read all the options available there...and kill the drive in which you had VistaOS/Win7 (C)...this will make all you C: drive sectors to "0"
i.e. it will wipe your C: drive clean and u can start with a clean slate....
if u r not concerned with the data in you disk...wipe all drives and disks in the PC....a 20GB disk will take aprox 1 hr to finish
for all this u must have the BIOS enabled to boot from CDROM drive...
once killdisk has finished doing the wiping process....
insert the Vista or Xp cd and install either...in the partition option make 3 or more partitions....C, D, E of at least 30 GB min for each...as Win7 will take aprox 18 GB....
in C: drive install Vista or XP as the case may be.....
once done....let the system boot and let it load Vista or XP
once in Desktop you can insert the Win7 cd and install it on the D or E: drive....the CDROM drive letter will change accordingly....when you make the partition....so be carefull to
let me know....
reg
Jul 17, 2010 | Computers & Internet
Howto get a serial number?
Depends on what serial number you are looking for. If you are looking for the serial number of your computer - e.g. for insurance purposes - then it will be on the back of the case.
If you are looking for your windows cd-key that should be on the side of the case on a microsoft sticker.
Apr 05, 2010 | Dell Inspiron 530s Desktop Computer...
Won't detect Dual Layer disk
Make sure that there are no incompatibility issues between the Sony DRX and your dual layer disk.
Try using another dual-layer disk or try loading the PROBLEM disk into another dual-layer burner for isolation.
Hope this helps and have a great day!
Aug 28, 2009 | Sony DRX-810UL DVD RW Dual Layer Burner
HL-DT-ST DVDRAM GSA-T20L ATA andDual DVD's
HellO:
I have this same unit. And yes it does support dual layer. I used it to make my restore disk.
also lightscribe.
Sep 30, 2008 | Intel (AXXSCD) Internal CD-ROM Drive
Cd player
Sounds like the laser slid is sticking. it's not the CD that's the issue, but solidified grease on the CD laser rail. The sled motor has to work harder to push the laser past the lump of grease but once it does the sound continues. Does it get better after you've played 3 or 4 cd's? Same time into a CD each time? If so it's easy to fix by cleaning the old grease off the laser rails and re-greasing.
Jan 23, 2008 | Audio Players & Recorders
Problems
You have a jammed disk - that sometimes happens, and requires that the case be opened, and the disk manually removed.
Sep 22, 2007 | Sony VRD-VC10 DVD±RW Dual Layer...
Need location of internal battery
Hi, Couldn't get a hold of the manual for the pdf1007 but I did find the 1009's manual which is more or less semiliar. http://www.pioneerelectronics.com/pna/manuals/search/results/0,,2076_4277,00.html?keywords=pdf1009 GoodLuck
Feb 02, 2006 | Pioneer PD-F1007 301-Disc CD Changer
Computers & Internet Logo
143 people viewed this question
David Payne
David Payne
