Question about Sega Dreamcast Console
Wont spin My dreamcast will turn on and everything works fine but the disk does not spin!! i cant find out whats wrong but the dc will not spin my disk please help
  • Exialath Aug 12, 2008
    I turn on my dreamcast and it will start fine and show the dreamcast swirly emblem. Then i hear the disk stop spinning and it goes to the menu screen. My disk never starts to spin again. It does this with every game that i have. I tried to clean the lense, but that didn't work. Then i tried to clean the connentor to the circit board but that didn't work either. I also tried to spin the proessor or something like that clockwise to make the game spin faster but that didn't work either!!!!!!!! someone plz help!! ASAP! THX
  • 659 Answers
You will either have to have the DC Laser Lens Big Motor or the complete DC Laser Collectivity replaced. other then that try cleaning the laser and any parts you can and using air to blow the system out those are my only suggestions for you hope that helps.
Parts for them are fairly cheap on ebay and other online shops.
Good luck
Posted on Aug 01, 2008
Dreamcast shows logo then goes blank
Definately the DC. Try ensuring that the connections are properly made first, and if that fails, try wiping the laser lens (very carefully) and the disc with a smooth cloth.
Jul 18, 2009 | Video Game Consoles & Games
Dreamcast wont read games more detailed problem
you need to replace the hdd[hard drive]
Jun 20, 2009 | Sega Dreamcast Console
Dreamcast wont power on
sounds like a fuse gone
there's one on the plug? (In uk there is)
There is a glass fuse inside the machine
So take it apart and look at it (close to the where the power goes into the machine
If there is no wire in the glass take it out and get a replacement at an electric shop.
DO NOT JUST PUT ANY OLD BIT OF WIRE IN THERE!
Aug 18, 2008 | Sega Dreamcast Console
DC stops and starts games periodically
~Open up the dreamcast
~remove the Powerboard (located to the left houses power supply)
~get baby wipes or facial wipes and clean the pins
~dry with toilet paper
~put it all back together
That will fix it ^_^. i had this problem as well and didn't play my DC for years then i stumbled on a youtube video and now it works great never restarts. have fun playing old games again.
Jun 04, 2008 | Sega Dreamcast Console
No Display
the surface mounted fuse on the motherboard might be fried up if you have a technical background try to override the blown fuses by soldering a wire on it
i'll post more information about that tomorrow because my notes are at home (i'm at work hehehe)
May 08, 2008 | Sega Dreamcast Console
Dreamcast turned off when there's a disk in it
madarchod band kar de ......from ayush yadav lps lko
Apr 08, 2008 | Sega Dreamcast Console
Sega Dreamcast console problem
First off, NEVER store a game console on top of a subwoofer. It is like a giant magnet, and electronic devices do not handle magnetics. I don't think i've ever heard of a VGA box, Sega brand or not, killing a console. Millions use aftermarket AV cables and adaptors on all consoles without problem. I think it likely died from being on top of the sub. Relocate it and you should be fine. Running it for a few hours isnt likely either unless you had the vents entirely blocked.
To the guest who's drive isnt spinning, I would say your drive motor has burnt out. This doesn't indicate a defect in Dreamcasts, per se, it just means bad luck or excessive dust which killed it. Either buy a different Dreamcast or see if you can find a drive replacement.
Hope this helps.
Feb 28, 2008 | Sega Dreamcast Console
Dreamcast Loading problem
you can get disks relayered at game stores.
there was a long period where this happened to me.
some games worked for a while, some didnt.
its the dreamcast.
you might wanna get anew power cable or just clear out the dust because that is the main problem with the dreamcast.
try playing with the console upside down
it sounds crazy but it worked for me.
Dec 18, 2007 | Sega Dreamcast Console
My DC will read my games but it wont play them!!!
ok guys i have 4 dreamcasts the problem is people beat the crap out of em. try holding the lid partially closed with a weight on top it should read the disk and play good. the sensor that tells it there is a disk in there is probaly a little screwed up. Also get a clean cue tip and some 91% rubbing alcohol and gently clean the lens on the laser and it sould work like new. so get to the browser with the lid open all the way put a disk in and slowly close the lid at about 80 percent closed it should say reading disk put a weight on the lid to keep it where it is and try the game if it works your good. permenent solution. remove modem and the 4 screws at the bottom of the dreamcast without a disk in there pull the top off. now look at the part of the lid that hits the little black flapper (it's on the top right of the main board) now tape or glue a small amount of anthing to the part of the lid that hits the switch about 4 mm thick of paper taped to it will push the switch further in and it should recognize disks better now and all will be well in the world e-mail me for pix if you want apple225@juno.com
Jun 09, 2007 | Sega Dreamcast Console
Sega Dreamcast Console Logo
262 people viewed this question
Top Sega Video Game Consoles & Games Experts
DROPNDEAL
DROPNDEAL
Josh Whitehead
Josh Whitehead
Reggie brown
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
