Question about Westell Wirespeed LiteLine 6100 (B9961001002) Modem
Westell 6100 ethernet
I can connect to the internet just fine when using the USB port/cord, but now, I want to use my new belkin G router, so I need to use the ethernet cord. It just won't work. I haven't even hooked up the router, because the modem won't recognize my computer when using the ethernet cord. Does anyone have ANY idea how to make this work??
  • 1 more comment
  • Anonymous Aug 05, 2008
    I have the identical problem. I had the same problem on my old computer using XP and now on my new computer using Vista
  • lbab Sep 22, 2008
    same problem here
  • armymom7 May 11, 2010
    same here except my dsl light blicks fast and no internet This can go on for hours. I use the belkin g router too. whats going on?
The prob may b with the ethernet adapter on the computer or the ethernet port on the modem or the ethernet cable.....
to check ethernetadaptor  ping 127.0.0.1
to check the ethernet port on the modem...if u plugin the cable u should have a light lid up on the modem ..
to check the ethernet cable  try with an alt cable which is proved to be working
Posted on Sep 14, 2008
2 Suggested Answers
Panth3on
  • 71 Answers
SOURCE: Connect 2 PCs to Westell 6100 DSL modem
well depends on if you want to hookup wirelessly with one or not. If the modem has a USB connection as well as ethernet, then you can hook up 1 computer to usb and 1 to ethernet with no problems. If you do want a wireless hookup then yes, you need a wireless router. I would just go with a router because of the convenience of being able to go wireless if you decide to. I would suggest a Linksys WRT-54GL with a 3rd party firmware (DD,-WRT, Tomato, etc.) Hope this helps.
Posted on Sep 14, 2007
How do I turnon the USB on the westell 6100 modum?
f you reformatted your Windows on your pc, there's no need to change the settings of your network connections. The Westell 6100 can either be connected to your pc using the Ethernet port or the USB port if you're using the combo cable or Y-cable. It's more stable to use the Ethernet port for your Lan connection. For the USB, to reinstall the USB connection properly, you'll need the Verizon Installation CD. Make sure the USB is not connected to your PC first before you install it. You just need to follow the CD because it will tell you when to hook up the USB cable to the pc. If you still have the CD, after it runs, you have to select existing customer and then select connect new modem. After that you just to have follow the steps to install the USB connection properly and then your modem will work fine afterwards. If the problem still persists, you can try replacing the cable. If all else fails, it could be a modem problem already. You also need to check your Network Interface Card of NIC as we call it, it's built in your pc. it's the device that allows your pc to communicate with the modem. Normally after reinstalling windows, the NIC is forgotten, make sure you also install the drivers and utilities Cd for your windows.
Sep 06, 2011 | Westell Wirespeed ProLine 6100 Router...
How do i connect my verizon dsl westell 6100 to my belkin g rtr?
Wellll....since it seemed an impossible task, I tried the next best thing.
I bought a wireless adapter for the other pc and voila! they are on the internet, and I am returning the router.
Westell modem + Verizon DSL w/usb = No connection to router.
Dec 28, 2009 | Belkin Wireless G Plus MIMO (F5D9010)
I need help connecting a westell 7500 router/modem,i want to get a notebook on line. i didnt receive any intsructions.i need help connecting the westell 7500 to my pc and notebook thanking you.
Westell makes a line of broadband home networking products that enable residential customers and users in small businesses to access and share broadband services. These inexpensive DSL router/modems offer multi-users Internet LAN access for home or business applications. The Westell router/modems allow you to have the benefits of the "always on" high-speed broadband Internet connection without losing the ability to receive voice calls over the same phone line.
  1. Step 1 288254_thumb.jpg Connect one end of the Ethernet cable to the computer's Ethernet port. Connect the other end to the Ethernet port on the back of the Westell router.
  2. Step 2 Connect the barrel end of the router's power cord to the connector labeled "12 v" on the back of the router. Plug the other end of the power cord into a wall outlet.
  3. Step 3 Connect one end of the DSL phone cable to the DSL line jack on the back of the router. Connect the other end to the wall jack.
  4. Step 4 Wait for the Ready and the Link LEDs to glow steady green. The router is now ready to use.
Nov 15, 2009 | Westell Wirespeed VersaLink...
How To: USB hookup for computer while having ethernet hookup to Xbox 360.
USB to PC is fine, make sure you have the original installation disk for it. Then you can connect the Xbox via network cable. There shouldn't be any problem as your modem can take 2 connections by the sound of it.
May 21, 2009 | Westell Wirespeed LiteLine 6100...
Resuming verizon dsl usb internet connection
If you reformatted your Windows on your pc, there's no need to change the settings of your network connections. The Westell 6100 can either be connected to your pc using the Ethernet port or the USB port if you're using the combo cable or Y-cable. It's more stable to use the Ethernet port for your Lan connection. For the USB, to reinstall the USB connection properly, you'll need the Verizon Installation CD. Make sure the USB is not connected to your PC first before you install it. You just need to follow the CD because it will tell you when to hook up the USB cable to the pc. If you still have the CD, after it runs, you have to select existing customer and then select connect new modem. After that you just to have follow the steps to install the USB connection properly and then your modem will work fine afterwards. If the problem still persists, you can try replacing the cable. If all else fails, it could be a modem problem already. You also need to check your Network Interface Card of NIC as we call it, it's built in your pc. it's the device that allows your pc to communicate with the modem. Normally after reinstalling windows, the NIC is forgotten, make sure you also install the drivers and utilities Cd for your windows.
May 18, 2009 | Westell Wirespeed ProLine 6100 Router...
Desktop and two laptops won't work with modem & router now
Probably you used the wrong type of ethernet cable, a crossover one. Try another Ethernet cable but this time a straight one.
Mar 11, 2009 | Westell Wirespeed ProLine 6100 Router...
Connecting modem via ethernet cable
I'm not an expert in window based units but since it worked with Vista OS and not with XP. Sounds like you might try re-installing XP again. Take note on any windows that refer to the ethernet port during installation. It is likely you might of hit "next" without reading all the text. I know I have in the past. I changed over to mac and I know longer have any problems only at work but give then I give it to the IT Dept and wait and wait and wait.
Sep 05, 2008 | Westell Wirespeed LiteLine 6100...
Connecting another computer
HI,
Im not sure what model of westell you are using but if you say that it has a USB port then it must be a westell 6100. With this type of modem { 3 ports } w/c are USB port , ethernet port and a phone port. Connecting another computer is technically a no-no for that device. It will create a conflict and the other computer wont work at all vice-versa. Youd experience slow connection too.
I would recommend you to just use 1 PC for this device OR you would consider on purchasing a router for that.A router is a separate device where-in you can connect multiple computers. modem --> router ----> computers { wired and wireless}. Routers are more secured and is very efficient when it comes to home networks.
Hope that helps and if you may have additional questions pls feel free to post it in FIxya.
Good Luck .
Jun 10, 2008 | Westell Wirespeed LiteLine 6110 Modem
USB Connection
Hi floinmist .
Westell 6100 modem by default can only be used for 1 PC . It cannot orit is not enabled to use for 2or morer computers as it creates a conflict within. Ethernet connection is the BEST connection for you to use.> your USB is sent to you by you provider { ISP} or by westell packages. Its is only a spare cable just in case your PC doesnt support ethernet connection ,  nothing else.
To resolve this issue you might want to upgrade your modem to a router w/c is westell versalink . You can connect 2 or more computers  { wired or wireless connection } and is more stable compared to your westell 6100.
Connecting 2 computers could cause slow, intermittent and NO connections at all problems.
IF you have other questions pls feel free to ask and let me know if theres anything ii can assist you with .
Best wishes.
Prince
May 02, 2008 | Westell Wirespeed LiteLine 6100...
Adapters Compatible with the Westell E90-610014-06 Router?
run the modem to the router with Ethernet cable and then use one of the other Ethernet ports on the router and another Ethernet cable to connect desktop
Mar 04, 2008 | Westell Wirespeed LiteLine 6100...
Westell Wirespeed LiteLine 6100 (B9961001002) Modem Logo
481 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
