I just got an xbox360 game of the internet and its not copying because the region is differnet what shall i do
Maybe1)The Xbox 360 does not recognize a disc in the DVD drive
2)Disc is "unreadable" to the Xbox 360
3)DVD drive tray will not respond or move
Every issue has its own unique cause. A disc with scratches could be an issue. You should have no problems getting this issue fixed. See if another disc does the same thing.
It most likely says "Unable to read disc" because it probably can't read the disc! If I were you, I would try cleaning off the disc you are using, then putting it back into theXbox 360 and try again. It may also be scratched repetitively, which cannot be fixed and you may need to buy a new copy of the disc.The disc is the incorrect region - DVDs come in formats called "regions." These regions match the region specified in the software of the DVD player. Some games also have these regions. If the region of the DVD and that of the player do not match, the disc will not play.
SOURCE: Xbox 360 wont read disc
Though i fixed the Disc Read Error myself within
an hour but please test the below method at your OWN Risk. Please
also note that microsoft is no longer providing Extended warranty for
E74Error.
Check out this DIY Video Guide,that
explains step by step instructions to fix Disc Read Error
yourself within an hour. It also provides the money back guarantee in
case you are not satisfied. As i fixed my Xbox myself so i thought to
share it with you guys.
SOURCE: My XBOX 360 elite is not reading discs.
sounds like your Disc Drive has taken a **** I have had the same issue and I had to open it up to make the drive start to spin again
SOURCE: Xbox wont read discs, unless i hit it....
open tray right??
-check the time and date settings,even the time zone as well
-try to load the disc without the hard drive or memory unit
-look for corrupted files at the memory, delete it
-do the system maintainance,
system settings>>memory>>hardrive, press y for device options, press this in sequence x, x, Lb, Rb, x,x>>yes
This is a problem occurring in all the xbox 360 consoles.......
this is mainly because of the poor quality of the disc.....as a result it leads
to the damage of ur xbox 360 lens..............use good original
discs........the heating effect is due to the long usage of pirated discs ...
check your lens if its working good then better
download this Repair Guide for further information .........
CLICK HERE to download
