Question about XION (XON-500F8X2-201) (XON-500F8X2-201) Power Supply
Pc stoopped working, replaces supply, Pc works
Originally built PC with Xion 600 W , XOn-600F14T-201, bar code P0603 02140, Machine stopped powering up, I replaced the power supply and now the machine works. Can I get an RMA to get this supply repaired?
  • 83 Answers
Here is an RMA request form. Its is in pdf format.
Posted on Jul 27, 2008
JUST bought a xion amp solaris pc case and can't figure out how to get the front panel off
At a guess, you'll have to take one side off then look inside, behind the front panel, look for sprung plastic lugs at the bottom, middle and top of the case.
The front may be hooked in one side so there will only be clips for the other.
Sep 12, 2010 | XION Solaris (XON-409) ATX Mid-Tower Case
Whining sound with xion 800 watt power supply.
There is a fan insine the power supply, and also a fan on the CPU. Occasionally there is also a fan on the chassis of the computer itself.
Turn on the computer, take the case off, and listen to identify the source of the noise. If it's inside the PSU, return it and get a new one.
Feb 20, 2009 | XION PSU XION|XON-800R14N 800W RT
Power Hiccups and Cycles
Faulty electrolytics in the power supply. Buy a new one or get it serviced.
Sep 27, 2008 | XION PowerReal 600 (XON600F14T201)...
Light on Front of Case
looks like the cable for the light isnt plugged in, turn your pc off and open the box to see if you can see the cable so you can connect it.
Aug 30, 2008 | XION Onyx (XON-301P) ATX Case
XION Case and Supply
Try unplugging, then plugging back in the 20/24pin power connector. When you plug in the power connector, make sure the power supply is OFF and the switch in the back is OFF and nothing is plugged into the computer.
Jul 21, 2008 | XION (XON-500F8X2-201) (XON-500F8X2-201)...
Can't turn on PC, Presario SR2163WM
You sound like you know what you're doing, so I expect you've made all the motherboard connections(Same as the original PS). Does the switch work when you test it? If so, it sounds like the PS is DOA. I've had bad luck with cheap power supplies.
Sep 17, 2007 | XION (XON-500F8X2-201) (XON-500F8X2-201)...
Power on Problem!!
Did you plug the cables for the front devices and buttons into the motherboard at the right locations? Are the polarities correct on for your cables?
Jun 26, 2007 | XION Onyx (XON-301P) ATX Case
XION (XON-500F8X2-201) (XON-500F8X2-201) Power Supply Logo
131 people viewed this question
Top XION Computers & Internet Experts
Jax Planet
Jax Planet
Farokh Merek
Farokh Merek
JonSnell Electronic
JonSnell Electronic
Are you a XION Computer and Internet Expert? Answer questions, earn points and help others
