Question about Dell (F2273) Motherboard
Dell latidue D610
Anyone help me please. My laptop Dell Latidue D610 has its power button sometimes doesn t work and the charging indicator flashing red when using both AC Adapter and batery itself.
  • new_sun202 Jul 27, 2008
    Thank you very much. So sad hic hic. I'm going to try fixing it myself. I tried to find document saying about mainboard circuit but I found nothing. Do you have any suggestion?
    Genius:
  • 2,028 Answers
The light indicator for the battery is; green-charging, yellow-battery failure, and red-charging system failure. The charging system failure happens when the power management chip fails. The pm chip regulates and controls the power input & usage, allows the machine to switch from AC to battery, and cotrols the charging. This will also cause the problem with the power button not workin or being hard to start. Unfortunately, the motherboard will have to be replaced in order to fix this.
Posted on Jul 26, 2008
When i try to turn on my dell latitude d610... the num lock flashes for a few seconds then shuts off... please help!!!
I just fixed a D610 belonging to a customer. Before when i press the power button the caps-lock led flasshes 10X then goes off again. I opened the memory compartment beneath the laptop and replaced the memory and this time the power came on but the screen has lines and the writings can't be seen so i opened the keyboard and there is another memory there too so i removed it and this time the pc came on well and booted. So this problem is from the memory. Anyone having a 10X-CAPS-lock flash should check and replace both memories.
Jan 20, 2012 | Dell Computers & Internet
My dell latitude d610 ac power is work is properly but battrey is not charging plz tell me soulition.
If the D610 works when attached to the AC Power Cord, it is likely that your battery is not capable of taking a charge and needs to be replaced. I have 2 D610 Dell Latitudes and they are very good laptops.
Please vote if my information is helpful or not. Recommend me. Thanks UAW 974
Jun 26, 2011 | Dell Latitude D610 Notebook
I have d610 battery indicator flashes orange and green alternately i used ac adaptor to have power , once i plug out it turns off. i try a new battery do same thing? pls help
It may be that the power brick your using is damaged. You may just need a new power cord. Sometimes power cords can be damaged quite easily.
Mar 01, 2011 | Dell Latitude D610 Notebook
PLEASE HELP!! I am going on a business trip tomorrow and ALL of my requisite files are on my Dell Latitude D610 that won't power on. PROBLEM: once I removed it from my docking station at work, it won't...
When you say you "tried turning it on with the battery removed", did you leave it plugged into the wall with the charging adapter at the time? Please clarify that you tried to use it while plugged in without the battery and it would not power up? When you plugged it in without the battery, was the green charging light on? Or did you get no power light at all?
With your battery in, try using a different outlet to plug into. Plug it into another outlet and when the green charging light comes on press and hold your power button on your keyboard and do not release it for 30 to 45 seconds. Tell me if this boots up the pc even if just for a moment?
There are three lights on your keyboard that should come on when the laptop is plugged in and turned on. One is the power light, the other is the battery charging light and the last one is the hard drive indicator that looks like a round cylinder on the picture. Tell me when you plug it into the outlet and the battery charge light is on, does the hard drive light come on and/or flicker when you try to power up the laptop? How many lights come on when you press and hold down the power button with the cord plugged into the wall?
Jan 09, 2011 | Dell Latitude D610 Notebook
Dell Latitute D610 is no longer working under AC Power
Please check the AC adapter with another system and confirm if it is working fine. Else get it replaced.
Thank you for using Fixya
Oct 08, 2009 | Dell Latitude D610 Notebook
Dell inspiron 2200 green LED battery Indicator flashing
sounds like your charging circuit isn't working or the adapter isn't putting out enough power or amprage to fully charge the battery, or you battery went bad. if the charging circuit is bad then so is *********** board, time to burry the system and buy a new one
Jun 21, 2009 | Dell Inspiron 6000 Notebook
Battery will not charge on a dell d610 when plugged into outlet
I have seen this with faulty batteries.
Try changing the battery.
Also, check in the BIOS that the adapter you are using is recognised and shows a state of charging with the battery in.
Apr 01, 2009 | Dell (F2273) Motherboard
My Dell Latitude D610 Battery Stopped Working
The battery light flashing RED/AMber is an indication of a failed battery.
Portable batteries have a life expectancy of 300 to 500 recharge/discharge cycles. (roughly 18 months under normal use) After that, the charge life starts to drop off and eventually it will not hold a charge. Because of this, the battery is considered a consumable item and is only warranted for one year from the manufacturer.
Since all the systems listed in the post are D610's (4 to 5 years old) it is not surprising that the batteries are failing.
Dropped Puck, if you replace the battery and a new battery doesn't charge/run the system, then the charging circuit on the MB is failed.
Feb 22, 2009 | Dell Latitude D610 Notebook
Battery stopped working
Hey,
Test your charger, the battery light blinking and the computer not starting up indicates not enough power to start up or not pluged into ac power, check the power adapter or charger. I suspect the battery is fine.
Thanks,
Ekse
Feb 15, 2009 | Dell Latitude D600 Notebook
Dell Inspiron 5160 flashing orange / green power LED
If your Dell notebook battery flashes four orange one green, there might be a problem with your battery.The battery life is also shorten and doesn’t last longer than an hour.gets hot sometimes.
pls see this if it helps
http://www.wareprise.com/2007/07/05/dell-notebook-battery-flashes-four-orange-one-green/
This is directly from the User Manual:
If the computer is connected to an electrical outlet, the Battery light operates as follows:
• Solid green: The battery is charging.
• Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
• Off: The battery is adequately charged (or the computer is turned off).
• Flashing orange: The battery charge is low.
• Solid orange: The battery charge is critically low.
pls do rate me FIXYA if i helped u
Nov 29, 2008 | Dell Inspiron 5160 Notebook
Dell (F2273) Motherboard Logo
445 people viewed this question
Alun Cox
