Question about Aiwa XR-MS3 Shelf System
The Buttons are not registering with the correct button
My system will power up just fine but when i want to listen to a cd of switch it to the radio i cant because the buttons are not registering in the configuration that it origionally was supposed to
4 Suggested Answers
  • 319 Answers
SOURCE: receiver
Sounds like micro-processor is locked up or defective. Try unplugging unit for an hour, then power up. If this is not a fix, have pro-tech check it out.
Posted on Apr 12, 2008
  • 6784 Answers
SOURCE: None of the buttons work. No music, can't eject and doesnt play the cd. Thanks in advance
HI, this is totally main board failure. try to unplug for 3 minutes then, plug back in after the three minute shutdown. if this continues, replace the main board(control).
Posted on Jun 03, 2009
  • 175 Answers
SOURCE: None of my buttons work. I tried to reset it and
check connection between face and unit make sure it is clean, pull apart face and clean circut with metho(make sure it is dry before testing and see how u go this should fix it
Posted on Apr 27, 2010
My Philips FWC550 automatically keeps switching to a radio station and has volume issues!
You have a bad Rotary Encoder or Display Microprocessor(computer inside your Philips). If you are interested in having it repaired, please visit my website at You may contact me there. Thank you.
Jun 20, 2015 | Philips FWC550 Shelf System
How can I get my car radio unstuck from one station?
Try disconnecting the negative ground (-) cable from the battery. That will disconnect power to everything including your radio. It might reset it self when you restore power by reconnect the negative ground cable to the battery.
May 19, 2014 | Pioneer Deh-4100 Single Din Cd Player...
Every Button Switches Between Radio and CD
Reset the radio by pressing a sharp object (pin, pen, etc.) into the small reset hole on or behind the face. If it doesn't have one, disconnect the negative cable from the battery for two minutes and reconnect. If you still have this problem, the radio is bad.
Apr 18, 2014 | Panasonic CQ-DF203U CD Player
2007 Corolla radio not working correctly
Faulty radio, grounded out on the inside.
Dec 06, 2013 | Cars & Trucks
Cant switch on radio - says: ''code 1''
The radio alarm has been tripped. Any loss of power to the system will cause this to happen. It wants you to input the 4 digit code to reset the radio. If you do not have it, you can pull the stereo and get the serial numbers, and ask the VW dealer for the code. It should be free info if you supply the serial numbers.
With the power on and SAFE showing on the display, press and hold the MODE and SCAN button together until SAFE changes to 1000. Release the buttons and using the first four station buttons enter the radio code.
Use button #1 to change the 1 to the correct code, pressing once will change to 2 twice to 3 etc
Use button number 2 to change the next number etc.
When you have entered the correct code; press and hold the SCAN and MODE buttons together until code disappears and radio comes on.
I hope this may help.
Good Luck!
Feb 21, 2010 | 2003 Volkswagen Jetta TDI
I can't change the time on my Pioneer mofset 50w4 radio/cd player. Pressed all the buttons and can't get it in the time change mode. Any suggestions?
Usually most car radios need to be in "STANDBY MODE". Make sure your radio is not on(playing or listening music) and if you have a menu button, make sure you hold down at least 3 to 4 seconds. Hopefully this helps.
Dec 11, 2009 | Computers & Internet
Stereo Says Safe and Can't listen to it
Get the code from your dealer with the car's VIN if the system is OEM. Chances are the code is somewhere in the owners manual package that came with your much for theft proofing...if you or the PO haven't removed it.
If you have the code, like 0095, you press and hold two buttons on the RHS of the Bose Symphoney II, the PSCAN and RBDS buttons IIRC for about 3-5 seconds...the SAFE should go out and 0000 appear on the screen. You then use the first four program buttons to cycle each number (1 for first 0, 2 for second 0, etc.) to the program code. When you've entered the program code, press the PSCAN and RBDS buttons again to start the radio. I don't think the ignition has to be on.
Next time use a battery jumper...I prefer the portable kind that can be recharged through the power socket/lighter. I just replaced my battery ($153 genuine Audi OEM vice $300 installed) and had no issues with the radio. BTW, the auto up on the drivers and passenger windows probably has to be reset. Lower the window(s) all the way, raise them up and HOLD the switch up for 3 seconds...the auto up will reset.
Jun 27, 2009 | 2000 Audi A6
hi im using pioneer DEH-5750MP pnly sound is working and no other button is working ,cd is working fine but cant acces the radio as no other button is working
Jun 08, 2009 | Car Audio & Video
2005 Dodge Caravan Radio CD Player & Clock Not Working
Try checking the RDO/IP IGN fuse in the fusebox in the engine compartment, ours was blown
Jul 31, 2008 | 2005 Dodge Caravan
Freezes control, but keeps playing
over heating cheak back fan is it in very well vented area if not get sterio fans off ebay on it 4 for 20 u plug in wall ok llike pc fans
Sep 15, 2007 | Samsung HT-Q40 System
Aiwa XR-MS3 Shelf System Logo
95 people viewed this question
Top Aiwa Audio Players & Recorders Experts
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
