Back to:
Tags:
HP DeskJet 640c InkJet Printer
Problems in Downloading & installation of Driver...
posted by deepakrites on Jul 26, 2008
I downloaded the Driver for Window XP,but while installing the Error massage says the Current O.S: Window XP, but the required O.S: Window XP (64 bit) and finally had to cancel the installation.
--------------Deepak Sinha, New Delhi -30
Comment by deepakrites, posted on Jul 29, 2008
I downloaded the Driver for Window XP (64bits) too,but while installing the Error massage again says the Current O.S: Window XP, but the Supported O.S: Window XP (64 bit) and finally had to cancel the installation.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Provided by HP STAFF
Best Solution
posted on Jul 28, 2008
Thanks for Trying (70)
Riztech
STAFF
Rank:Guru Guru
Rating: 88%, 116 votes
Hi Deepak,
I think you have downloaded the driver for windows XP 32 bit OS, and i think that your PC supports Windows XP 64 bit Operating System.
Click here to download the software for Windows XP 64 bit Operating System.
DOWNLOAD (x64Drv5.64.0.17.exe)
Installation Instructions: USB Connection
1. Download the x64Drv5.64.0.17.exe file.
2. Once downloaded, choose Open or just run the x64Drv5.64.0.17.exe.
3. Follow onscreen instructions listed below.
Note: There may be a long pause between each of the steps below.
4. Choose Direct Connect.
5. Power on the printer, and connect it to the computer when prompted.
6. The "Found New Hardware Wizard" will be displayed.
7. Select No, not this time.
8. Select Install the software automatically (Recommended).
9. Depending on your product, you might see one or more Windows' warning screens.
10. Click Continue anyway or Yes each time these Windows warning screens appear.
11. Click Finish.
12. Reboot your computer (Highly Recommended).
Installation instructions: Wired and Wireless Network
2. Once downloaded, choose Open or just Run the x64Drv5.64.0.17.exe.
3. Follow onscreen instructions listed below:
4. Choose Network.
5. Choose your printer after the installer has identified it on the network.
11. Click Finish.
Thanks
Rizz
Comment by Riztech, posted on Jul 28, 2008
Im sorry Deepak, the link above provided was invalid...
Download the correct software below.
DOwnlaod
thank you
Rizz
Rating Locked! (?) deepakrites has rated this solution as Thanks for Trying
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Problems in Downloading & installation of Driver 640c.:
I don't want to Accept this solution
Can you Help with these Printers problems?
have a z 640 lexmark printer and have donwloaded the soft...
paper won't load and the orange light keeps on blinking
hi guys, wen i give the print command my printer reacts to...
After printing one project, the printer starts flashing...
Hi The HP 640C is working well, but once I finish...
Loading problems.
Repair Service
Find Printer Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
