Noisy transformer oon logik lcd tv model lcxw 32 hd1 power panel amo1 2004/02 version 1
  • 372 Answers
Hi.
Providing the noise is not causing any picture or sound problems then the noise from the transformer is from the windings vibrating at A high frequency.
To prove this remove back from set & switch set on IF YOUR UNSURE OF YOUR COMPETANCE TO TOUCH LIVE CIRCUITS PLEASE TKE YOUR TV TO A REPAIR SHOP.
With an insulated item eg plastic pen or piece of wood push against transformer can you alter the pitch of the noise or make it stop alltogether by doing this.
If yes This can be cured by applying an epoxy resin type adhesive over the windings this will cure & pot the transformer which if done correctly will stop making the noise,
http://dysonmanuals.llc.nu/
Posted on Jul 26, 2008
No power to lg tv
step 1 : At first test your A.C. power cord
step 2 : A.C. transformer test
step 3 : at first test your fly back transformer
Jul 30, 2011 | LG 32LD550 32 in. LCD HDTV
32" polaroid hdtv turn on but there is no picture,
You have a bad capacitor or two in the lighting of your LCD screen. I have not worked on this particular unit. I have had a smaller version of this TV. On the smaller version there were two capacitors in the power supply. The transformer that lights the LCD panel ,yes, is in the power supply.There were two of them and I think the values were 35 volts at 1000Mfs. I hope this will clue you into a fix. Yes, I really think you have a couple of bad capacitors. If you pull this TV apart, by all means inspect all the capacitors in the signal board (has the RF connections and all your RCA connections). You will find several bad capacitors by now. I do repair TVs, so this is good advice for repair. Thanks for asking and show all hands of support!l
Jun 15, 2011 | Polaroid TDA-03211C 32 in. LCD HDTV
My 32" Philips LCD TV makes a annoying buzzing
The main cause off buzzing from these sets is the transformers on the psu. This can be solved by sealing the transformers with a sealant spray.
Jan 21, 2011 | Philips 32PF5531D 32 in. LCD Television
Functional Noise
Not normal, top right back corner have inverter board and power supply board. It may be the transformer making noise. you are better to exchange it.
May 26, 2010 | Sony KDL-32EX400 32 in. HD-Ready LCD TV
Logik 32'' lcd tv dead
hello check the glass fuse inside the tv it will be in the power supply
regards
shaun
Mar 11, 2010 | Televison & Video
No picture, no sound. tv less than oone year old. toshiba 32" HD TV. Failed without warning
GO IN TOUCH WITH TOSHIBA AS THE SET WILL BE UNDER WARREN TIE ........SO FREE REPAIR AND SERVICE
Nov 19, 2009 | Toshiba REGZA 32XV515DG 32 in. LCD HDTV
Logik LCD 32 Signal problems
Have you tried having your outdoor antenna upgraded? and do you have an antenna booster in the back of the tv where all the antenna cables connect into.
Nov 05, 2009 | Televison & Video
It being emerson 32" hdtv lcd turns on but immediately turns off
This is Emerson's #1 problem.
The Inverter Transformer on the power supply/backlight inverter board goes bad. It's what powers up the screen for your TV. When the part goes bad, it doesn't have enough juice to power the screen and the TV automatically turns off. You have 5 Inverter Transformer on your board.
You can fix the problem by replacing the whole board or replace the bad Inverter Transformer.
Here's where you can get a new board for a good price:
http://www.shopjimmy.com/catalogsearch/result/?q=lc320em9+inverter
Or, here's where you can get replacement Inverter Transformers:
http://www.partstore.com/Part/Funai%20Corporation%20Inc/Funai/LTZ2PC0MS008.aspx
http://www.encompassparts.com/products/?LTZ2PC0MS008
Jun 17, 2009 | Emerson LC320EM9 32 in. LCD HDTV
Mikomi TV power pack/transformer/AC adapter replacement
Power Plus Online sell a replacement ac adapter 'PSU 1' at www.power-plus.tv we purchased one recently for £29.95 and this works fine.
Regards Steve
Oct 06, 2008 | Televison & Video
23 inch lcd tv by dell wont turn on as if no power
if this is a DELL W3201C read this.
Have the same model and same problem
probably It is a bad inverter board, in my case one of the 16 transformers is burnt out on the inverter board. still trying to find a replacement component. if not replacing the board is the only option or getting the inverter board repaired.
by the way, this TV has a Samsung panel: model LTA320W2-L03. so it needs parts for a Samsong not a DELL.
DELL does not manufacture or fix them becuase they don't make them
Dec 04, 2007 | Dell W3201C 32 in. LCD Television
Televison & Video Logo
109 people viewed this question
Top Televison & Video Experts
