Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Just replaced dlp lamp
I just replaced dlp lamp. the old one is burned out(can see that clearly when looking at bulb). put new bulb in old housing. put everthing together correctly and plugged in and now red lamp light still comes on.
  • seemoore2 Aug 03, 2008
    just replaced dlp lamp. red light for advising of bad lamp starts blinking again as soon as tv is plugged in.
From what I remember, when you turn on the tv, use the remote and when it asks if you replaced lamp say yes.
Posted on Jul 28, 2008
Do I need to order the housing with the lamp after burn-out?
you can order just the bulb then install that in your housing. Being careful not to touch the new bulb with your bare hands as the oils from your finger tips will cause the lamp to fail prematurely.
Feb 07, 2012 | Mitsubishi WD-60735 Projection Television
your model uses the Mitsubishi 915061010 Lamp assembly with housing which is available from under the Mitsubishi DLP Lamp category. The lamp comes with installation instructions and is a simple plug in , It includes the housing so you dont need to remove the old bulb from your housing to reuse since the new lamp already has the housing with it.
Aug 22, 2011 | Mitsubishi WD-65733 65" HDTV
The model you listed is a rear projection DLP set that uses a lamp and not a CRT. The part number for the lamp is 6912B22007A and is just the bulb itself. Meaning when your go to replace it you have to remove the old lamp from its housing and carefully install the new bulb in the old housing. You will want to use latex gloves so you don't leave fingerprints on the new lamp as it will shorten the life if it.
Sep 08, 2010 | LG RU-44SZ63D Television
Put new bulb in hitachi ultravision dlp tv and lamp light flashes and tv will not turn on. Have reinstalled old build and works fine. Is there any type of reset that needs to be set. New bulb no tv, old...
hey there it sounds like the problem is coming from your ballast board, the ballast board is the power source to the lamp. with time this part starts to wear out and get weak your old lamp is already burning out there for it does not need that much voltage to turn on but the new lamp has not been worn out or used there for it needs the ballast to be working at 100%
hope this solution helps
Sep 03, 2010 | Hitachi UltraVision CineForm 55VG825 55"...
Please Help. I have a 56" DLP Samsung and the lights just flash
Sounds like the lamp might be burned out. The Lamp should be replaced every couple years. If they are not replaced they will eventually burn out. Replacement is not that difficult and just requires a screwdriver. The lamp is located at the back of the DLP TV on the left side. The lamp can be purchased online from Samsung for about $130 dollars. You might be able to find a aftermarket one for less. Just use your telivision's model number located on the right side of the TV on sticker to cross reference the bulb that is needed or there might be a sticker on the back at the lamp housing that has the lamp part number. And make sure to spend the extra money and get the Lamp with the housing together. You can buy just the lamp for cheaper but that will require you to remove the old lamp from the housing and they are fragile. Much easier installation with the housing/lamp combo.
Jan 12, 2010 | Samsung DLP HL-P5663W 56" TV
How to install a SONY LAMP XL2400 into your TV
remove 2 screws from bottom back of tv(plillips) now carefully remove front unclips,sometimes you have to pry it off.take out screws from lamp cover,remove cover,take screws out of lamp, remove lamp.reverse process to put it back together.
Sep 19, 2009 | Televison & Video
Samsung 50" DLP - Lamp Light Blinking after bulb replacement
Listen closely. The tv should make a high pitch whine as it turns on. If it does wait and see if it tries this a few times. If yes then check the bulb, I have seen cases where the lamp shoves the power connector back into the set. If the tv starts with a grown or heavy vibration noise, then your color wheel may have broken and needs replaced.
Jul 11, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Mitsubishi WT-42311 DLP Bulb Replacement
Your access should be a a panel near the back or side. You will see that it is somewhat easily removed and should have maybe one or two screws. You will see the casing to the lamp. Go ahead and remove it. Now unscrew the old bulb and replace it with a new one. There is not a lot of screws holding it together. It's a fairly easy process once you find the lamp. You should see the lamp once the panel is removed.
Jan 14, 2009 | Mitsubishi WT-42311 42" Rear Projection...
I've got a replacement lamp for a Samsung HLR 5067. The old lamp is a BP610125A. I was told that the new replacemet lamp is a BP96-00826A. The problem is the new Lamp's housing seems too big for my Hd...
I have the same bulb and was told by Replacement Lamps the same thing. No you can not switch the housings. I tried. The bulb is too large and does not fit in the old housing. It is the wrong lamp all together.
Aug 22, 2008 | Televison & Video
Replacement bulb
Check this website for the lamp. The cost is for the lamp only without the housing, but you could re-use the lamp housing by removing the old lamp and installing the new one.
Good Luck.
Jun 05, 2008 | Televison & Video
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
118 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
