Question about Jl Audio 1000/1 Car Audio Amplifier
Jl 1000/1 amp not working w7 like it should
I tried switching my lanzar amp to my jl 1000/1 amp myself last night and as i plugged in the ground.. some smoke came up from where the ground and 12v cords meet the sub.. it wasnt much smoke, just a little. so i plugged my lanzar back in and today at lunch went to get it installed and it seemed to be hittin when i left the car audio place.. but its not hitting like it should. the lanzar hits harder. what went wrong? what does that smoke mean? how do i fix it? thanks. i am worried sick. those amps arent cheap.
Also you can call the jl service they will help you they will charge you like $115 to fix it
Posted on Oct 10, 2008
  • 631 Answers
If you see smoke, it's virtually always the power supply transistors. There are several things that can cause it but sometimes, they simply fail. I will generally work with people who want to repair their own amplifiers but the this JL amplifier is complex and not always an easy amplifier to repair.
If you can't find a local repair shop to repair it, you'll have to go through an authorized JL retailer to have it repaired by JL.
Let me know if you have any other questions.
Posted on Jul 27, 2008
Tip
Jl 1000/1 amp problem
i tried switching my lanzar amp to my jl 1000/1 amp myself last night and as i plugged in the ground.. some smoke came up from where the ground and 12v cords meet the sub.. it wasnt much smoke, just a little. so i plugged my lanzar back in and today at lunch went to get it installed and it seemed to be hittin when i left the car audio place.. but its not hitting like it should. the lanzar hits harder. what went wrong? what does that smoke mean? how do i fix it? thanks. i am worried sick. those amps arent cheap.
on Jul 26, 2008 | Jl Audio 1000/1 Car Audio Amplifier
No sound
ok if u have a radio with sub controll make sure its on an make sure that you have the gain bassboost turned up an if it has a crossover switch make that its on
Jul 24, 2010 | Jl Audio 1000/1 Car Audio Amplifier
Jl 1000/1 popping fuse
well you need to check to see if nt no shottage with the amp and also check if the fuse is not to low amp 20,,,, 25 if not put the amp in a separet 12 volt battery
Dec 10, 2008 | Jl Audio 1000/1 Car Audio Amplifier
If I buy 2 12 inch jl audio w7 subs would it be better to get 1 or 2 jl audio 1000 watt amps
two amps and get a 2 farad cap please because if u dont u could melt wires together cause a fire or toast ur alt.
Oct 30, 2008 | Jl Audio Car Audio & Video
If I'm not mistaken, the blue light is the low voltage indicator. You need to confirm that the voltage ON THE POWER SUPPLY TERMINALS of the amp never drops below 11 volts. If it does, the amp will shut off. It's possible that you have a bad connection or even a defective fuse that's causing the problem.
JL recommends a 100 amp fuse for the amp. If you use a fuse that's too large and something goes wrong, the amp may be very severely damaged (possibly beyond repair).
May 08, 2008 | Jl Audio 1000/1 Car Audio Amplifier
JL audio hook up problems!!??
your w7 13's are dual 1.5 Ohm, but according to JL website, are 2.41 Ohms when the coils are in series. Each 13 connceted to each amp with voice coils in series is your best bet. The amps are designed to put out the same amount of power from 1.5 to 4 Ohms. If you parallel the voice coils, you end up with .6 Ohms and the amp will go into protect mode. You'll be drawing a lot of current, so you may want to think about 1/0 guage power wire, upgrade the wire from the alternator to battery (usually only 8 guage) and think about multiple batteries.
Feb 09, 2008 | Jl Audio 1000/1 Car Audio Amplifier
JL Audio 1000/1 power LED is On But no Sound
my amp did same shit, its the rca cabbles, check them out at the back of the head unit. the input jack is probably bad on the head unit
Dec 31, 2006 | Jl Audio 1000/1 Car Audio Amplifier
Fuse keeps blowing when sub volume is turned up
the amp draw rating on the amp is 100 you need to put a larger fuse in, such as a 150 amp, it would be a good idea to go to 0 ga but not needed. you might also want to upgrade your altenator.
Nov 29, 2006 | Jl Audio 1000/1 Car Audio Amplifier
Jl Audio 1000/1 Car Audio Amplifier Logo
253 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
