Question about E-Machines eMachines Desktop PC
Restoring Windows programs like Word, etc. on Emachines T294
We had to delete our hard drive and start over-we reinstalled the Emachines disk but did not get all the programs we had originally. Can you advise how to proceed from here? We have downloaded some Windows programs but they charge for the main ones-thanks
Pat
  • 2,794 Answers
Contact Emachines and see if they have a restore set of disks for you.
Posted on Jul 26, 2008
Toshiba not responding
--Clean the disk space..
--Stop auto starting programs.Click Start > Run and type "msconfig" at the prompt. Click the Startup tab and look at all that junk that loads when you launch your PC.
--Clean up the registry.
--Upgrade RAM.
--Reinstall Windows. If the above tricks haven't helped, it may be time to wipe the slate clean and start again, reformatting your hard drive, reinstalling your applications, and restoring your data files from a backup.
--Upgrade your hard drive. This is a more complicated solution, but if you're reinstalling Windows (per the prior tip) you might consider upgrading to a bigger and possibly faster hard drive, too.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Dec 11, 2012 | Toshiba Computers & Internet
Disk read error
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Sep 26, 2012 | eMachines Computers & Internet
How do you remove corrupt files from your hard disc
By right clicking the mouse to the selected corrupt file, and selecting delete. If it so happen that one of your program has a corrupt file like movie maker or so, you can delete them thru add and remove software. This is how--- Click start, select control panel, then select add or remove program. Now this will display all installed program in your computer. search for the program that does not run anymore, then click remove. Be careful when doing or selecting a program to delete, for windows might need itto run properly. Have a nice day Friend, hope this would help you.
Aug 26, 2011 | Computers & Internet
How do you go about to format a toshiba l650 and reinstall windows 7
Hi! If you have the Windows 7 disc just insert it restart the computer. It will boot directly from the disc. Then follow the step by step instructions here.
If you don't have the Windows 7 disc, you have two ways to reformat your Toshiba computer.
Using Toshiba HDD Recovery Utility from the recovery partition
In case of a hard disk drive failure, you may be able to restore the drive to the factory default state using the on-disk Toshiba HDD Recovery Utility (in a special partition on the hard disk drive).
You can select restoring the entire hard disk drive to the factory default state, or restoring only the C: drive -- without affecting other partitions (for example, a D: drive) -- or changing the size allocated to your C: drive, and then restore it.
To recover your hard disk drive from a system failure using the utilities stored on your computers HDD, follow these steps:
  1. If the computer is running, shut it down -- by clicking Start, Shut Down, and again Shut Down.
  2. Press and hold the 0 (zero) key on your keyboard and then press the computers power switch. When the computer turns on, the Toshiba HDD Recovery Utility screen will appear, presenting three options:
Sample TOSHIBA HDD Recovery Utility screen
Restore Original Factory Image (Recommended)
CAUTION:
Restoring a hard disk drive to its factory default state deletes all partitions on the hard disk drive and all data stored on those partitions. All of your files and information will be lost! Be sure to back up all important files first.
  1. Press 1 to restore your hard disk drive to its original factory default state. A confirmation message will appear, indicating that all data will be overwritten and lost during the restore process. Be sure to back up all important files before proceeding.
  2. Click Yes to begin the recovery. A message will appear once the operation is finished, indicating the HDD has been restored.
  3. Press any key to restart the computer.
* The options 2 & 3 are for advanced users.
Hard Disk Drive Recovery using Recovery CDs or DVDs
You may also wish to to run the Toshiba HDD Recovery Utility from Recovery CDs or DVDs that you have created.
Insert the first Recovery CD or DVD into your CD/DVD drive, and turn on the computer. Once the computer is running, the TOSHIBA HDD Recovery Utility screen will appear, presenting the same three options above. Again Press 1 to
restore your hard disk drive to its original factory default state. Click Yes to begin the recovery. Press any key to restart the computer.
Installing Drivers and Applications
The TOSHIBA Application Installer allows you to reinstall the drivers and applications that were originally bundled with your computer.
To reinstall drivers and applications:
  1. Double-click the "Toshiba Application Installer" icon on the Windows desktop. This utility may also be launched by clicking Start -->All Programs --> Hard Disk Recovery Utilities.
  2. Click "Next".
  3. Click the item(s) you wish to install. To select multiple items, hold down the Ctrl key as you click your selections.
  4. Click "Install".
  5. Follow the on-screen prompts to complete the installation process.
Hope this helps.
Jun 19, 2011 | Toshiba Computers & Internet
How to restore to factory settings
  • Use a memory device such as a rewritable DVD or external hard drive to back up the data you need to save from your eMachines computer. Any data that isn't saved to an external source will be erased when the computer is restored to factory settings.
  • Remove any discs that are in the optical drive and unplug the computer's peripheral devices, such as an Ethernet cable or scanner. Do not disconnect the keyboard and mouse. Bring up the "Start" menu and choose "All Programs."
  • Navigate to "eMachines" and then "eMachines Recovery Management." Click the tab labeled "Restore," which is located at the top of the window.
  • Click "Password Settings" if you have not already set a recovery password. Type a new password in the text box and then click "OK." Click "Restore System to Factory Default."
  • Type the recovery password and click "OK." Click "Next" to wipe the eMachines computer's hard drive and begin the recovery process.
  • Select "Finish" and wait for the eMachines computer to restart. Use the series of installation prompts that appears on the screen to create a new user account for your operating system, set the system date and time, and set up your Internet settings.
  • Mar 10, 2011 | E-Machines (T2958) PC Desktop
    My Laptop is running very slow and it is often giving problems with my sound.
    http://www.piriform.com/
    try running ccleaner, download and install from above web page.
    run the cleaner to delete old files and clutter, run registry to tune windows.
    In tools section go into start-up and disable all programs, and then any programs that need to start on switching on will still start, but normally lots of other programs start up that dont need to, stopping these from starting up will speed up your laptop. Don't woory about disabling programs, when you want to use them they will start as normal
    Oct 20, 2010 | Acer Aspire 5920-6727 Notebook
    I need help restoring my pc to factory settings
    Back up all of your photos, documents, folders, files, favorites (bookmarks) and anything else you would like to keep and reinstall after the system recovery. Use a CD, DVD, flash drive, MP3 or external hard drive to store your data temporarily.
    Click on the "System Recovery" icon (usually found within the start menu) and begin the process by following the on-screen prompts.
    Click on "restore" and note the warnings about losing all of your data. Wait for the computer to complete the process of erasing the hard drive and creating a new partition.
    Insert the emachines recovery disk in the CD tray when prompted. This will start the process. There are usually one or two disks involved and the computer will let you know which ones to insert when and will even eject the tray automatically in most cases. You may have to restart at least three times, do not be alarmed by this and keep the disk in until you are prompted otherwise.
    do-emachines-system-recovery--1.5-120x120.jpg Example of Windows Installation Install Windows on the new partition and follow the prompts on your screen. Be sure to choose the largest partition, the one with the most kb available. There are usually two to choose from, as you have deleted the other ones in the steps prior.
    Reinstall all of your backed up data and any software programs you are currently using, including the printer and Internet, if needed. Be sure all of your drivers and hardware is working properly, as they have been reinstalled as well during the recovery process.
    Mar 04, 2010 | E-Machines eMachines Desktop PC
    Kika633@yahoo .com
    you need to reinstall windows, put in floppy boot up disk set the cd to run have your windows cd in tipe d: install
    Dec 24, 2007 | E-Machines eMachines Desktop PC
    E-Machines eMachines Desktop PC Logo
    35 people viewed this question
    Top E-Machines Computers & Internet Experts
    Alun Cox
    Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
