Question about Blaupunkt Car Audio & Video
I need the code for my blaupunkt santa fe dcm42 radio
  • amqn Jul 26, 2008
    the serial number is bp0254p1538695
Kindofcheap
  • 241 Answers
SOURCE: need code for my hyundai
· Turn the Vehicle ON
· Go in the fuse panel
· Remove the memory Fuse
· Remove the Radio Fuse
· Look in the Owners manual to locate the # position then Turn on the Vehicle
· Wait for about 5 minutes then with the vehicle still ON put back the Fuses
If this does not work then follow the next step!
· Turn the key to the ACC position
· Turn On the radio
· After 1 hour
· The radio should give you another chance to enter in 3 more codes.
Press the Eject button and keep it pressed while
you also press the power on button.
Remember keeping the eject button pressed, press the power on button.
“When the radio lets you put I the codes again try this putting in
in these codes in the order that I give You ok”
1. 4712
2. 4323
3. 2537
4. 2283
  If this still does not work you need to call the dealer!
If your Vehicle was not purchased at a hyundai Dealership do not tell them
so they do not refer you to the car dealer . If you describe your problem they should give you the Code over the phone… Make sure you call the 1-800 number
Remove the stereo and look along the top edge of your stereo and you will see a small sticker with your serial number on it. Write this number down.
If you did buy your vehicle from hyundai Dealership
Write down your VIN #. Call your local dealership and give them your information They SHOULD give you your code,
Thank You
Please rate this
Solution
Jayson
Posted on Sep 29, 2008
emissionwiz
  • 77499 Answers
SOURCE: PROGRAM KEYFOB FOR HYUNDAI SANTA FE
This is from the factory service manual of your car:
There is no onboard programming procedure for this vehicle. This vehicle requires special equipment be connected to the vehicle to program the keyless remote. Translation you need the dealer to do this.
Posted on May 22, 2009
jmgldsmth
  • 1906 Answers
SOURCE: 2007 Hyundai Santa Fe Headlight
you need a torx screwdriver
Posted on May 29, 2009
ghost4548
  • 776 Answers
SOURCE: DO i NEED TO CHANGE TIMING BELT ON 2005 sANTA FE AT 60,000?
Do you want to replace the Go to belt yourself? Go to http://www.hmaservice.com/ and register (vehicle by VIN). Afterward, you'll have access to technical information (manuals, wiring diagrams, service bulletins, etc) about your vehicle.
Posted on Jun 06, 2009
  • 4889 Answers
SOURCE: audi.A6 radio code
Unfortunately the majority of AUDI codes (including yours ) are not available for free from anywhere on the Internet.
Only available from your Main Audi Dealer ....or a Decoding Service who will connect it to a laptop to read/recode the memory chip (EEPROM)
Posted on Sep 06, 2009
What is the pinout for this radio that was in a Hyundai Santa Fe 2005?
Do you need Wiring Diagram for hyundai santa fe.Or you need where the radio fits in hyundai santa.The connector of radio.
Please Check the link mentioned below it has all wiring diagram for hyundai santa fe radio.Also it has details for how to connect radio connector.
http://www.allcarhelp.com/2016/05/hyundai-santa-fe-radio-wiring-diagram.html
If you need anything else,please reply.
Thanks.
May 11, 2016 | Hyundai Cars & Trucks
After replacing the battery in my 2005 Hyundai Santa Fe; the radio doesn't work. I have no code in the car manual.
there is a site I heard of (free radio codes) but you need the code off back of radio ,check out site and see if you can get directions on how to.
Oct 01, 2014 | 2005 Hyundai Santa Fe
Santa fe radio code
When you disconnect your battery and then reconnect itagain, it disables the radio. This is an anti-theft protection for your carradio.
The enable your radio the activation code is in your vehicle owner's manual. Ifyou do not have this code you need to go to your vehicle manufacturer's servicecentre and get them to enter this code for you.
May 09, 2012 | Hyundai 07 08 Santa Fe Audio Equipment...
I need the code for a blaupunkt/santa fe dcm 42 se# bp0254n1533861/cass . car stereo
This is an old radio that cannot be decoded by Serial Number
Try asking here for further free advice...CLICK HERE
If they cannot help then try your Main Dealer or a Radio Decoding Service
May 13, 2011 | Blaupunkt Car Audio & Video
Need 4 digit code for a aftermarket blaupunkt radio with warranty number B692400168 serial number 69001114. It is a SCR 475 cassette player.
This is an older Blaupunkt with a different type of Security Code system.
Try here for free further advice and code ....CLICK HERE
Apr 21, 2011 | Blaupunkt Santa Cruz CD31 CD Player
How do I reset the radio
look for 4 digit security code in owners/maintenance books enter into radio.you have 3 attempts before lockout. if this occurs disconnect battery again
Mar 09, 2010 | 2004 Hyundai Santa Fe
Change the battery and the radio does not work? 2005 santa fe
You have an internal security code in the radio. You need to put that code in. If you don't have it, contact your dealer.
Apr 26, 2009 | 2005 Hyundai Santa Fe
How to remove a blaupunkt santa cruz mp36
I'm afraid its a little bit late for corsamad11 but I've just spent hours finding that too much messing about taking a Blaupunkt Santa Crux MP36 in and out of your dashboard will almost render this great quality radio almost useless. Not being securely fixed in the dasboard.
The radio is held inside the mounting bracket by a metal strip each side which are supposed to spring closed to secure the unit. When the two keys are inserted each side of the radio they are supposed to push out these metal strips and at the same time hook onto each side of the radio behind two little lugs. This may work a few times but thats about all. The metal strips don't spring closed and the removing keys don't hook on the unit to pull it out.
Fiddle about with the keys inserted in each slot and at the same time try to push the unit further inside the dash. When this is achieved the mounting bracket lugs can be straightened out and the bracket can be removed with a narrow screwdriver as installed.
Just a very poor and flimsy design on a much loved radio.
May 31, 2008 | Blaupunkt Santa Cruz MP36 CD Player
How do I enter code into my blaupunkt radio/cassette?
HY ACORDING TO THE MANUAL YOU SHOULD TURN THE IGNITION ON SWITHCH THE RADIO OFF PRESS THE AS BUTTON WHILE YOU TURN THE RADIO ON,AFTER 5 SECONDS YOU SHOULD HER A BEEP AND ON DISPLAY YOU CAN SEE 10SAFE AFTER 5 MORE SECONDS YOU SHOULD BE ABLE TO ENTER YOUR CODE USING FIRST FOUR BUTTONS FOR 0-YOU PRESS ONCE AND SO ON WITH THE OTHER DIGITS.
Jan 30, 2008 | Car Audio & Video
Car Audio & Video Logo
64 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
