Question about Humax DRT800 TiVo 80-Hours Video Recorder
GETTING CONNECTED I BOUGHT A HUMAX DTR800 AND DID NOT KNOW THAT I NEEDED A PHONE LINE.I HAVE A COMPUTER BUT I DON'T KNOW WHAT USB ADAPTER IS NEEDED OR ROUTER,MODEM,NOT SURE.I SEE THE USB HOOK-UP IN THE BACK BUT MY COMPUTER IS IN THE OTHER ROOM.HOW DO I GET CONNECTED? PLEASE HELP!!
  • 1 more comment
  • WIZHER Jul 26, 2008
    YES,I FOUND OUT THAT I NEED TO HAVE A PHONE LINE TO DOWNLOAD THE SOFTWARE,AND I DON'T HAVE A PHONE LINE.SO I FOUND OUT THAT I NEED TO HOOK-UP A WIRELESS CONNECTION.
  • Tim Babcock
    Tim Babcock May 11, 2010
    Are you trying to hook up your Tivo to your network?
  • Anonymous Mar 30, 2014
    need to know which usb wireless network adapters will work with humax dtr800
  • 2,794 Answers
Tivo uses a wireless USB adaptor. They sell for around $45 - $60 dollars at most electronic stores. They use them to update the tv guide as well as download additional programming such as tivocasts. It's better to use than the phone linew.
Posted on Jul 26, 2008
I just bought the DANE-ELEC Micro SD. It comes with the Micro Card and the USB and the SD Adapter. I am trying to get the pictures from my phone to my computer. There are no instructions so I do not...
Put the Micro SD card into your phone and transfer the pictures to it. Once you have transferred the pictures, take the card out of your phone and put it into the SD Adapter and then into the USB Adapter. Once you have done that plug the USB Adapter into your computer and wait for it to load. After waiting a few seconds, click start, my computer, then double click on the SD card icon. Your pictures should load and you should be able to transfer them to your computer.
Jul 29, 2011 | Computers & Internet
When i put the USB cable and connect to the LAP, its not getting charged. How can i solve the problem? do i need to install any software?
Hi - when you say "LAP" I assume you mean laptop or notebook computer. Some computer USB ports do not have sufficient power to charge (or operate) devices like cellphones, GPS, large external hard drives, etc. You may be able to charge if you disconnect all other USB devices that aren't needed to run the computer. In order to get around the problem without having to do all that, either purchase an external charger for the GPS (which may be fairly expensive) or purchase a powered USB hub.
An external powered USB hub looks like a traditional USB hub, except for the fact that it has a power cord to connect to your home power outlets. The power cord will often look like AC adapter. The powered USB hub is ideal because they provide additional USB ports, are fairly inexpensive, they provide all the power for the USB devices that are connect to them (the computer's internal power supply is not used) and it can power or charge devices connected to them without needed the computer to be powered on. Simply plug the USB hub into a USB port, and AC power source - then connect the devices that need a large amount of power to the hub's USB ports instead of the computer's USB ports.
The parts included with powered USB hub (clockwise from left): USB hub, USB connecting cable and AC power adapter.
Many powered hubs will work without the power adapter - however they will supply power to the devices connected from the computer's internal power supply.
I hope this helps and good luck! Please rate my reply. Thank you.
Jun 08, 2011 | GPS
I BOUGHT AND INSULTED THE BELKINS N WIRELESS USB ADAPTER ON MY DESKTOP COMPUTER THAT USES WINDOWS XP. I ALSO BOUGHT A $1300.00 VAIO SONY LAPTOP WITH WINDOWS 7 AND TRIED TO DOWNLOAD THE SAME WIRELESS...
Hi bobbie ....
I got your issue ...
I think your adapter is not getting installed with the cd
So please go to this link www.belkin.com/support
Thanks.......
With regards ...
Priya
Oct 20, 2010 | Belkin N1 Wireless USB 2.0 Network Adapter...
Netgear wg111 - I am connected to wireless network
i have seen issues with wireless USB adapters. Can you try another USB port on the computer? Also delete the adapter and let it br reinstalled. If this does not help, I would suggest returning it and getting a Linksys adapeter.
Jun 15, 2009 | NetGear WG111 802.11g/b Wireless Adapter
My sony ericsson w550i isn't getting connected to my pc
When you insert your usb cable to your phone, is it give you phone and file transfer mode. If yes then reinstall pc suite. If no then your usb cable is defective or usb port to computer is properly connected.
Please if you have more any question then reply to this solution if your problem is solved then mark as answer.
Thanks
Nov 28, 2008 | Sony Ericsson W550i Cellular Phone
Trouble recording records
When recording from a phonograph, I use the following items.
Depending on the phonograph whether or not it's MC or MM makes a difference in sound although most can't tell the difference. Also, you need to know if your phonograph requires a pre-pre amp or if that pre-pre amp is built in and the line coming out is at line level. The Rolls item is a pre-pre amp unit which takes to older phonographs signal level to that of input levels which allow the phonograph to be connected to any aux line in.
On the back of the computer, you can plug the RCA jacks from the phonograph into the adapter and directly into your computer via the MIC (usually pink) input. Most of the time this is sufficient. If the volume is too loud, or sounds horrible, chances are you have a pre-pre amp and you then plug it into the line in (usually blue)
First I would connect the RCA's from the phonograph to the adapter and plug it into the mic and see how the sound is.
Keep in mind that you do not use the ROLLs unit when connecting this way. If it's too loud or distorted, plug it into the line in.
For recording, you can download Audacity which is free and a wonderful editing program.
Nov 26, 2008 | Televison & Video
The phone is not getting connected
Try Installing the drivers for it.
This way the computer can recognize your phone once plugged via the USB cable. make sure to download the drivers and place them on your desktop. This way you know where they are if windows ask for them.
Here is the link to download the drivers: USB Drivers
If any help needed reply back to this message.
Jan 13, 2008 | Motorola Mobility ROKR E6 Smartphone
Humax Tivo will not record to DVD
After the update to 1.15 I had to delete EVERY recording on the unit. After that, any new recordings would burn just fine. However, some have found that same failure even after a hard reboot (repower). Called Humax level-1 support and they suggested a replacement unit so I swapped it out. But I've since learned that TiVo "pushes" a DVD firmware patch (possible supplied by Humax) from 1.08 to 1.15 and that patch is the culprit. That patch is suppose to make the DVD burn at a higher spin rate. After talking with level-2 Humax support they heard of the problem and said "the unit is working as designed", meaning, the DVD drive manufacturer specs say the drive is capable of a faster burn rate. So now I have Humax DTR800 #2 and so-far-so-good, but TiVo hasn't pushed the patch onto the box yet!
Nov 10, 2007 | Humax DRT800 DVD Recorder w/ 80 hr Tivo
Open Questions:
Humax DRT800 TiVo 80-Hours Video Recorder Logo
130 people viewed this question
Top Humax Televison & Video Experts
Andy Fraser
Andy Fraser
Tony
Are you a Humax Televison and Video Expert? Answer questions, earn points and help others
